petsc and matlab
Barry Smith
bsmith at mcs.anl.gov
Mon Aug 20 15:37:46 CDT 2007
Is the matrix "A" the same for all groups (and the only thing
different for each group is b)?
Barry
On Mon, 20 Aug 2007, Alejandro Garzon wrote:
> Hi, I wrote a code for solving a time dependent pde. In each time step
> I have to solve a linear system. I first wrote a prototype in matlab
> and then a C version using Petsc. To my surprise for some input
> parameters the matlab version runs faster than the Petsc code (on the
> same single processor). I did
> the performance comparison by timing 20 groups of 40 iterations. The
> times for Petsc and matlab are shown bellow
> group Petsc matlab
> 1 0.244981 1.110283
> 2 0.244995 1.112919
> 3 0.241305 1.113608
> 4 0.244542 1.114669
> 5 7.534417 1.112450
> 6 0.242212 1.115867
> 7 0.246327 1.111135
> 8 0.241105 1.113442
> 9 0.244468 1.111215
> 10 0.241113 1.111334
> 11 0.244541 1.112467
> 12 0.241400 1.113525
> 13 0.245020 1.114077
> 14 0.241303 1.113409
> 15 0.244380 1.116238
> 16 0.241372 1.109931
> 17 0.244108 1.100667
> 18 0.240419 1.096030
> 19 0.244337 1.096293
> 20 17.139999 1.097120
> total 29.0523 22.1967
> time
> As can be seen in the table, although in most of the groups the time
> spent by the Petsc code is lower than that of matlab
> (0.24 compared to 1.1) there are two groups (5 and 20) in the Petsc column that
> take a long time and make the total for the Petsc code bigger than
> that for matlab.
> In Petsc and matlab the method used is bicg and the relative residual
> is the same: 1e-8. The preconditioners are different, though. In petsc
> I used the default preconditioner and in matlab I used incomplete LU
> decomposition with drop tolerance. The code that solves the linear
> system in matlab is
> [L,U] = luinc(A,droptol); <---- this is done only once before the
> first iteration, droptol = 1e-12
> x = bicg(A,b,relres,maxsteps,L,U);
> I know incomplete LU decomposition as a preconditioner is available in
> Petsc but in order to use it one must provide two arguments in
> addition to the drop tolerance and I didn't know what values to give
> to them.
> My question is this: what options should be chosen so that the
> preconditioner and method use by Petsc are the same as those shown in
> the two lines of matlab code above? (could you contact the authors of the
> matlab functions?) A comparison of the performace of Petsc and matlab
> makes sense only if they are using the exact same methods.
> Thanks.
> Alejandro
