Using -pctype mg -pcmgtype PC_MG_MULTIPLICATIVE
Ben Tay
zonexo at gmail.com
Thu Aug 16 04:10:28 CDT 2007
Can you tell me what's the option to download and use ML? Is it
--download-ml=1? Also what is the option if I want to use ML?
Thank you.
Matthew Knepley wrote:
> The multigrid PC needs information about the grid and discretization. If you
> cannot provide this, use AMG through Hypre or ML. Or if you have a
> structured grid, consider using DMMG.
> Thanks,
> Matt
> On 8/15/07, Ben Tay <zonexo at gmail.com> wrote:
>> Hi,
>> I found that there's a multigrid option in the manual which can be used
>> by adding -pctype mg -pcmgtype PC_MG_MULTIPLICATIVE.
>> However, it seems that I am actually just using LU since with or without
>> this option, I got exactly the same answer. Am I using multigrid the
>> wrong way?
>> Thanks
