Question regarding PCMG
Matthew Knepley
knepley at gmail.com
Tue Aug 14 08:02:32 CDT 2007
On 8/13/07, TsuyoshiKoyama(berkeley) <tkoyama at berkeley.edu> wrote:
> As for the second case, the reason I might not select a coarse solver is
> since I
> am trying to solve a Helmholtz equation and the coarse grid solve might not
> be
> correct enough to apply. Thus, you may just point out that the coarse grid
> should
> be large enough to resolve the so called low frequency error and that if you
> do so
> you should still be able to solve direct, but I was curious on testing
> different types
> of operations at the coarsest level.
The coarse solver can be set to anything you choose. You just extract the
coarse KSP and set the type.
Matt
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
