Programming in *.f90 free format with PETSc
Ben Tay zonexo at gmail.com
Fri Aug 10 01:46:45 CDT 2007
Thanks Satish. It worked.
Satish Balay wrote:
> For now, you can try the following alternative: remove the !MS and
> !DEC lines from mpif.h
>>>      COMMON /MPIPRIV/ MPI_BOTTOM,MPI_STATUS_IGNORE,MPI_STATUSES_IGNORE
> I think this should be ok - as long as you don't use the above MPI
> flags in your code.
> Satish
> On Fri, 10 Aug 2007, Satish Balay wrote:
>> Sorry - I don't know enough about these f90 intricacies with
>> 'DEC$ ATTRIBUTES DLLIMPORT'
>> Looks like you can't include mpif.h inside a module-subroutine.
>> I'll have to check up on this tomorrow.
>> Satish
>> On Fri, 10 Aug 2007, Ben Tay wrote:
>>> Thank you Satish. I followed what you recommended exactly and used
>>> sed -e 's/^C/\!/g'
>>> With the new mpif.h, I got the following error:
>>> global.i90
>>> d:\cygwin\codes\MPICH\SDK\include\mpif.h(174) : Error: DEC$ ATTRIBUTES
>>> DLLIMPORT attribute can appear only in an interface-body.   [MPIPRIV]
>>> !DEC$ ATTRIBUTES DLLIMPORT :: /MPIPRIV/
>>> It points to this error in mpif.h
>>> ! Intel compiler import specification
>>> !MS$ATTRIBUTES DLLIMPORT :: /MPIPRIV/
>>> ! Visual Fortran import specification
>>> !DEC$ ATTRIBUTES DLLIMPORT :: /MPIPRIV/            -   in here
>>>      PARAMETER (MPI_MAX=100,MPI_MIN=101,MPI_SUM=102,MPI_PROD=103)
>>>      PARAMETER (MPI_LAND=104,MPI_BAND=105,MPI_LOR=106,MPI_BOR=107)
>>> Hope you can help again. Thank you very much.
>>>>> The strange thing is when I try to compile on my windows's visual
>>>>> fortran, it gives lots of error. The errors all point to mpif.h. Some
>>>>> errors
>>>>> are:
>>>>> d:\cygwin\codes\MPICH\SDK\include\mpif.h(1) : Error: Syntax error, found
>>>>> END-OF-STATEMENT when expecting one of: ( : % . = =>
>>>>> C
>>>>> d:\cygwin\codes\MPICH\SDK\include\mpif.h(2) : Error: Syntax error, found
>>>>> C
>>>>> d:\cygwin\codes\MPICH\SDK\include\mpif.h(3) : Error: Syntax error, found
>>>>> INTEGER_CONSTANT '1993' when expecting one of: ( % . = =>
>>>>> C  (C) 1993 by Argonne National Laboratory and Mississipi State
>>>>> University.
>>>> Some f90/free-form compilers don't like 'C' for comments. They need
>>>> '!' in the first columns.
>>>> To fix this - you'll have to follow instructions from mpif.h
>>>> C It really is not possible to make a perfect include file that can
>>>> C be used by both F77 and F90 compilers, but this is close.  We have removed
>>>> C continuation lines (allows free form input in F90); systems whose
>>>> C Fortran compilers support ! instead of just C or * for comments can
>>>> C globally replace a C in the first column with !; the resulting file
>>>> C should work for both Fortran 77 and Fortran 90.
>>>> C
>>>> C If your Fortran compiler supports ! for comments, you can run this C
>>>> through sed with
>>>> C     sed -e 's/^C/\!/g'
>>>> Satish
