Programming in *.f90 free format with PETSc
    Satish Balay
    balay at mcs.anl.gov
    Fri Aug 10 00:24:28 CDT 2007
Sorry - I don't know enough about these f90 intricacies with
'DEC$ ATTRIBUTES DLLIMPORT'
Looks like you can't include mpif.h inside a module-subroutine.
I'll have to check up on this tomorrow.
Satish
On Fri, 10 Aug 2007, Ben Tay wrote:
> Thank you Satish. I followed what you recommended exactly and used
> sed -e 's/^C/\!/g'
> With the new mpif.h, I got the following error:
> global.i90
> d:\cygwin\codes\MPICH\SDK\include\mpif.h(174) : Error: DEC$ ATTRIBUTES
> DLLIMPORT attribute can appear only in an interface-body.   [MPIPRIV]
> !DEC$ ATTRIBUTES DLLIMPORT :: /MPIPRIV/
> It points to this error in mpif.h
> ! Intel compiler import specification
> !MS$ATTRIBUTES DLLIMPORT :: /MPIPRIV/
> ! Visual Fortran import specification
> !DEC$ ATTRIBUTES DLLIMPORT :: /MPIPRIV/            -   in here
>      COMMON /MPIPRIV/ MPI_BOTTOM,MPI_STATUS_IGNORE,MPI_STATUSES_IGNORE
>      PARAMETER (MPI_MAX=100,MPI_MIN=101,MPI_SUM=102,MPI_PROD=103)
>      PARAMETER (MPI_LAND=104,MPI_BAND=105,MPI_LOR=106,MPI_BOR=107)
> Hope you can help again. Thank you very much.
> > > The strange thing is when I try to compile on my windows's visual
> > > fortran, it gives lots of error. The errors all point to mpif.h. Some
> > > errors
> > > are:
> > > d:\cygwin\codes\MPICH\SDK\include\mpif.h(1) : Error: Syntax error, found
> > > END-OF-STATEMENT when expecting one of: ( : % . = =>
> > > C
> > > d:\cygwin\codes\MPICH\SDK\include\mpif.h(2) : Error: Syntax error, found
> > > C
> > > d:\cygwin\codes\MPICH\SDK\include\mpif.h(3) : Error: Syntax error, found
> > > INTEGER_CONSTANT '1993' when expecting one of: ( % . = =>
> > > C  (C) 1993 by Argonne National Laboratory and Mississipi State
> > > University.
> > Some f90/free-form compilers don't like 'C' for comments. They need
> > '!' in the first columns.
> > To fix this - you'll have to follow instructions from mpif.h
> > C It really is not possible to make a perfect include file that can
> > C be used by both F77 and F90 compilers, but this is close.  We have removed
> > C continuation lines (allows free form input in F90); systems whose
> > C Fortran compilers support ! instead of just C or * for comments can
> > C globally replace a C in the first column with !; the resulting file
> > C should work for both Fortran 77 and Fortran 90.
> > C
> > C If your Fortran compiler supports ! for comments, you can run this C
> > through sed with
> > C     sed -e 's/^C/\!/g'
> > Satish
