Programming in *.f90 free format with PETSc
Ben Tay zonexo at gmail.com
Thu Aug 9 19:41:43 CDT 2007
Ok, I understand now. I just tested your recommended code on my school's
linux server which uses ifort. It works w/o any error. Here's the code:
#define PETSC_AVOID_DECLARATIONS
#include "include/finclude/petsc.h"
#include "include/finclude/petscvec.h"
#undef PETSC_AVOID_DECLARATIONS
module foobar
Vec abc
contains
subroutine xyz()
implicit none
Vec fbar
integer ierr
call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
end subroutine
end module
Everything is similar to your recommended format except the "use foobar"
is removed. The strange thing is when I try to compile on my windows's
visual fortran, it gives lots of error. The errors all point to mpif.h.
Some errors are:
d:\cygwin\codes\MPICH\SDK\include\mpif.h(1) : Error: Syntax error, found
END-OF-STATEMENT when expecting one of: ( : % . = =>
C
d:\cygwin\codes\MPICH\SDK\include\mpif.h(2) : Error: Syntax error, found
C
d:\cygwin\codes\MPICH\SDK\include\mpif.h(3) : Error: Syntax error, found
INTEGER_CONSTANT '1993' when expecting one of: ( % . = =>
C  (C) 1993 by Argonne National Laboratory and Mississipi State University.
My include directory uses d:\cygwin\codes\MPICH\SDK\include. So how
should I deal with this mistake?
I do all my code writing and basic debugging on the visual fortran and I
only run my working code on linux. Hence, I did not try your
recommendation on the linux. When I reduced the errors to just 3 (none
explicit declaration of PETSC_NULL_CHARACTER etc), I thought I'm going
in the right direction. But in fact I was on the wrong track.
Thank you very much and sorry for the inconvenience.
Satish Balay wrote:
>> However, doing this gave me more errors. Hence, I've followed
>> another
> If you get errors with the recommended model - you sould report the
> erros [not silently try something else - and then report erros with
> this something else]
> I can't help you anymore unless you can report problems with a
> reproduceable test code that I can comiile locally.
> Satish
> On Thu, 9 Aug 2007, Ben Tay wrote:
>> Hi Satish,
>> I am sorry if I have made you angry. I may have missed out some important
>> points which you tried to highlight. I was converting several of my .F fixed
>> format files to .f90 (or .F90) free format and some files which don't need
>> declaration of PETSc type variable worked while some don't.
>> However, I must clarify that the .f90 or .F90 did not bother me after a while
>> since in visual fortran or ifort, using the option -fpp enables the .f90 files
>> to be preprocessed too. Of course, if .F90 was used, -fpp is not required.
>> In my sample file shown just now, I did not have any include statments in my
>> subroutine. They're only present in the module 's section. Checking your prev.
>> email, you indeed mention that the PETSc includes files must be in each and
>> every subroutine. However, doing this  gave me more errors. Hence, I've
>> followed another user (Paul T Bauman) 's recommendation which states that only
>> preprocessed statements not inside the module needs to be placed inside the
>> subroutine. With this, I only has 3 errors, which concerns PETSC_COMM_SELF,
>> PETSC_NULL_INTEGER and PETSC_NULL_CHARACTER not having an explicit type. I
>> figured out that using:
>> MPI_Comm PETSC_COMM_SELF
>> will eliminate 1 error, although it was not required before. However, what
>> about the other 2? Should I defined them as integer or character and give them
>> a value using parameter? What value should I give them? You mention this in
>> your prev email:
>> integer NORM_MAX
>> parameter NORM_MAX=3
>> You also give a template to follow. I also tried to cut and paste and use it
>> but it gave lots of error. I had used it in visual fortran :
>> module foobar
>> Vec abc
>> contains
>> subroutine xyz()
>> use foobar
>> implicit none
>> #include "include/finclude/petscvec.h90"
>> Vec fbar
>> end subroutine
>> end module
>> As said above, upon removing the include files in the subroutine and the "use
>> foobar" statement, everything's ok. You can give it a try too.
>> Lastly, I understand that you have been helping a lot of users and there's
>> really a lot of stupid users around (I know I'm one of them ;-) ). Thank you
>> for your patience.
>>>> Hi,
>>>> Guess I'm too used to typing .f90 ;-) .... I've changed it to .F90 before
>>>> but
>>>> perhaps at that time the error I got didn't disappear so I didn't bother
>>>> after
>>>> that.
>>> I'm sorry - but you can't keep silently discarding the sugestions we
>>> make and keep reporting the same issues multiple times..
>>> This is frustrating.
>>>> I'm working in windows so I thought the capital letter doesn't really
>>>> matter.
>>> I've indicated this before. Most compilers use .F90 for prerpocessed
>>> free form.  And you keep indicating this is what you require. [Most
>>> compilers don't preprocess .f90 files]
>>>> Moreover, .f90 also works with my ifort in linux. Is it really
>>>> important? If so, I'll change all my .f90 to F90. Thanks for highlighting.
>>>> Here's a sample code test.F90:
>>> I'll need a test code that can reproduce the problems you report.
>>>> module global_data
>>>> implicit none
>>>> save
>>>> #include "include/finclude/petscmat.h"
>>>> #include "include/finclude/petscksp.h"
>>>> #include "include/finclude/petscpc.h"
>>>> integer :: size_x,size_y
>>>> Mat    A_mat      !  /* sparse matrix */
>>>> !MPI_Comm PETSC_COMM_SELF   -   commented out will result in error
>>>> contains
>>>> subroutine allo_var
>>> Again you are ignoring the sample template I sent you. You need to
>>> include PETSc include files in every subroutine.
>>> I'm sorry I can't repeat this anymore.
>>> Satish
>>>> !allocate memory for variables
>>>> integer :: status(2),ierr,k
>>>> size_x=10;size_y=10
>>>> call
>>>> MatCreateSeqAIJ(PETSC_COMM_SELF,size_x*size_y,size_x*size_y,13,PETSC_NULL_INTEGER,A_mat,ierr)
>>>> end subroutine allo_var
>>>> end module global_data
>>>> I got "Error: This name does not have a type, and must have an explicit
>>>> type.
>>>> [PETSC_NULL_CHARACTER]". Same for PETSC_NULL_INTEGER and PETSC_COMM_SELF.
>>>> It was ok when I'm programming in fixed format.
>>>> Thanks
>>>>>> Hi,
>>>>>> when I changed my global.F to global.f90,
>>>>> Any perticular reason why you keep using .f90 suffix even though I've
>>>>> recommended using .F90 suffix [for preprocessed free form] a few
>>>>> times?
>>>>>> I was told that PETSC_COMM_SELF, PETSC_NULL_INTEGER and
>>>>>> PETSC_NULL_CHARACTER does not have a type.
>>>>> Please send a test code that demonstrates this problem.
>>>>> Satish
