Testing only 'vec' folder
Sumit Vaidya sumit_vaidya at persistent.co.in
Wed Aug 8 04:04:51 CDT 2007
I want to test the source files present in 'src\vec\vec\examples\tests'
folder.
How to achieve it? Like the command 'make ACTION=lib tree', is there any
other command to test the examples of particular source directory?
I know 'make test' command. But this command tests all the examples. I want
to test the examples of only 'vec' directory.
How to do this?
Sumit
DISCLAIMER
This e-mail may contain privileged and confidential information which is the property of Persistent Systems Pvt. Ltd. It is intended only for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you are not authorized to read, retain, copy, print, distribute or use this message. If you have received this communication in error, please notify the sender and delete all copies of this message. Persistent Systems Pvt. Ltd. does not accept any liability for virus infected mails.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070808/aa5fb7b8/attachment.htm>
