Programming in *.f90 free format with PETSc
Ben Tay
zonexo at gmail.com
Tue Aug 7 11:20:50 CDT 2007
Thanks Paul. I finally realised where my problem lies. It's becos I
forgot to add -fpp to the ifort option. It's working now.
However, why can't I include
#include "include/finclude/petscmat.h90"
in the declaration? It seems to cause some conflicts...
Thanks
Paul T. Bauman wrote:
> Hi Ben,
> Here is the format I use in my .f90 modules. Note I do not know what
> the standard is, but this "style" has worked with ifort, gfortran, g95
> and Visual Studio (so I'm told).
> module IAmAModule
> implicit none
> private !(you don't need this if you don't want it)
> #PREPROCESSING STATEMENTS HERE (these will be seen by all subroutines
> contained in the module)
> public :: whatever needs to be public
> integer :: declare variables you want in the module
> contains
> subroutine IAmASubroutine (note this format works for a subroutine not
> in a module
> implicit none
> #PREPROCESSING STATEMENTS NOT INCLUDED IN THE MODULE
> variable declarations
> code here...
> end subroutine IAmASubroutine
> end module IAmAModule
> It looks like in your case below, the preprocessing statements are
> before the program - they must be inside the program. Put them after
> implicit none and before any variable declarations (in case you use a
> PETSc type variable).
> Good Luck,
> Paul
> Ben Tay wrote:
>> Hi,
>> I can compile and run with visual fortran by putting all the
>> declarations inside a subroutine e.g.
>> module ada
>> subroutine ddd
>> #define PETSC_AVOID_DECLARATIONS
>> #include "include/finclude/ petsc.h"
>> <other includes>
>> #undef PETSC_AVOID_DECLARATIONS
>> end subroutine ddd
>> end module ada
>> However, on my school's server which uses ifort, I get errors both
>> using your way and my way e.g.
>> #include "include/finclude/petsc.h"
>> #include "include/finclude/petscvec.h"
>> #include "include/finclude/petscmat.h"
>> #include "include/finclude/petscksp.h"
>> #include "include/finclude/petscpc.h"
>> program test
>> implicit none
>> integer :: x,y
>> Vec test_vec
>> x=1
>> print *, x
>> end program test
>> I compile using
>> ifort -r8 -132 -fPIC -g -c -static-libcxa -O3
>> -I/lsftmp/g0306332/petsc-2.3.3-p0
>> -I/lsftmp/g0306332/petsc-2.3.3-p0/bmake/atlas3
>> -I/lsftmp/g0306332/petsc-2.3.3-p0/include
>> -I/lsftmp/g0306332/petsc-2.3.3-p0/externalpackages/hypre-
>> 2.0.0/atlas3/include -I/lsftmp/g0306332/mpich2/include temp.f90
>> and get the error msg:
>> fortcom: Warning: Bad # preprocessor line
>> fortcom: Error: temp.f90, line 18: Syntax error, found IDENTIFIER
>> 'TEST_VEC' when expecting one of: => = . ( : %
>> Vec test_vec
>> fortcom: Error: temp.f90, line 18: This name does not have a type,
>> and must have an explicit type. [VEC]
>> Vec test_vec
>> and must have an explicit type. [TEST_VEC]
>> Vec test_vec
>> compilation aborted for temp.f90 (code 1)
>> I also tried shifting the declarations after the "program test" line
>> but it also failed. There is no problem if I changed the code to
>> fixed format.
>> Thanks
>> On 8/6/07, *Satish Balay* <balay at mcs.anl.gov
>> <mailto:balay at mcs.anl.gov>> wrote:
>> This is incorrect usage.
>> If you are getting errors with the correct usage, send us the error
>> messages, with your code, and we can sugest fixes.
>> - one issue could be
>> > > #include "include/finclude/petscvec.h90" <--- This should be
>> removed from here..
>> > > <other includes>
>> > > moudle foobar
>> > > <other module stuff>
>> > > end module
>> Satish
>> On Mon, 6 Aug 2007, Ben Tay wrote:
>> > Hi,
>> > I tried to use
>> > <other includes>
>> > module ada
>> > subroutine ....
>> > end module ada
>> > but the compiler says that the module is placed in the wrong
>> order. Anyway, I
>> > just move the top 4 lines into the subroutine instead and it
>> worked. Thanks
>> > module ada
>> > subroutine ddd
>> > <other includes>
>> > end subroutine ddd
>> > Satish Balay wrote:
>> > > you can use .F90 suffix for free-from preprocesed code. [or use
>> > > compiler options to force it always use free-form]
>> > > And when using fortran modules use the following organization:
>> > > <other includes>
>> > > moudle foobar
>> > > end module
>> > > subroutine xyz()
>> > > use foobar
>> > > implicit none
>> > > <other includes>
>> > > <code>
>> > > end subroutine
>> > > Satish
>> > > > Hi,
>> > > > I've no problem writing out codes in fortran fixed format
>> with PETSc.
>> > > > However,
>> > > > is it possible to do it in fortran free format as well?
>> > > > I'm using visual fortran and there's error.
>> > > > original :
>> > > > test.F
>> > > > module global_data
>> > > > implicit none
>> > > > save
>> > > > Vec xx,b_rhs
>> > > > How can I change this code to fortran free format *.f90?
>> > > > Thanks
