Programming in *.f90 free format with PETSc
Ben Tay zonexo at gmail.com
Tue Aug 7 03:26:27 CDT 2007
I can compile and run with visual fortran by putting all the declarations
inside a subroutine e.g.
module ada
subroutine ddd
#define PETSC_AVOID_DECLARATIONS
#include "include/finclude/petsc.h"
<other includes>
#undef PETSC_AVOID_DECLARATIONS
end subroutine ddd
end module ada
However, on my school's server which uses ifort, I get errors both using
your way and my way e.g.
#include "include/finclude/petscvec.h"
#include "include/finclude/petscmat.h"
#include "include/finclude/petscksp.h"
#include "include/finclude/petscpc.h"
#include "include/finclude/petscmat.h90"
program test
implicit none
integer :: x,y
Vec test_vec
x=1
print *, x
end program test
I compile using
ifort -r8 -132 -fPIC -g -c -static-libcxa -O3  -I/lsftmp/g0306332/petsc-
2.3.3-p0 -I/lsftmp/g0306332/petsc-2.3.3-p0/bmake/atlas3
-I/lsftmp/g0306332/petsc-2.3.3-p0/include -I/lsftmp/g0306332/petsc-2.3.3-p0
/externalpackages/hypre-2.0.0/atlas3/include
-I/lsftmp/g0306332/mpich2/include temp.f90
and get the error msg:
fortcom: Warning: Bad # preprocessor line
fortcom: Error: temp.f90, line 18: Syntax error, found IDENTIFIER 'TEST_VEC'
when expecting one of: => = . ( : %
Vec test_vec
fortcom: Error: temp.f90, line 18: This name does not have a type, and must
have an explicit type.   [VEC]
Vec test_vec
have an explicit type.   [TEST_VEC]
Vec test_vec
compilation aborted for temp.f90 (code 1)
I also tried shifting the declarations after the "program test" line but it
also failed. There is no problem if I changed the code to fixed format.
Thanks
On 8/6/07, Satish Balay <balay at mcs.anl.gov> wrote:
> This is incorrect usage.
> If you are getting errors with the correct usage, send us the error
> messages, with your code, and we can sugest fixes.
> - one issue could be
> > > #include "include/finclude/petscvec.h90"  <--- This should be removed
> from here..
> > > <other includes>
> > > moudle foobar
> > > <other module stuff>
> > > end module
> Satish
> On Mon, 6 Aug 2007, Ben Tay wrote:
> > Hi,
> > I tried to use
> > <other includes>
> > module ada
> > subroutine ....
> > end module ada
> > but the compiler says that the module is placed in the wrong order.
> Anyway, I
> > just move the top 4 lines into the subroutine instead and it worked.
> Thanks
> > module ada
> > subroutine ddd
> > <other includes>
> > end subroutine ddd
> > Satish Balay wrote:
> > > you can use .F90 suffix for free-from preprocesed code. [or use
> > > compiler options to force it always use free-form]
> > > And when using fortran modules use the following organization:
> > > <other includes>
> > > moudle foobar
> > > end module
> > > subroutine xyz()
> > > use foobar
> > > implicit none
> > > <other includes>
> > > <code>
> > > end subroutine
> > > Satish
> > > > Hi,
> > > > I've no problem writing out codes in fortran fixed format with
> PETSc.
> > > > However,
> > > > is it possible to do it in fortran free format as well?
> > > > I'm using visual fortran and there's error.
> > > > original :
> > > > test.F
> > > > module global_data
> > > >    implicit none
> > > >    save
> > > >    Vec    xx,b_rhs
> > > > How can I change this code to fortran free format *.f90?
> > > > Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070807/bacd3076/attachment.htm>
