Programming in *.f90 free format with PETSc
    Ben Tay
    zonexo at gmail.com
    Mon Aug  6 03:07:34 CDT 2007
I tried to use
#define PETSC_AVOID_DECLARATIONS
#include "include/finclude/petsc.h"
<other includes>
#undef PETSC_AVOID_DECLARATIONS
module ada
subroutine ....
end module ada
but the compiler says that the module is placed in the wrong order.
Anyway, I just move the top 4 lines into the subroutine instead and it
worked. Thanks
module ada
subroutine ddd
<other includes>
end subroutine ddd
Satish Balay wrote:
> you can use .F90 suffix for free-from preprocesed code. [or use
> compiler options to force it always use free-form]
> And when using fortran modules use the following organization:
> <other includes>
> moudle foobar
> <other module stuff>
> end module
> subroutine xyz()
> use foobar
> implicit none
> <other includes>
> <code>
> end subroutine
> Satish
> On Mon, 6 Aug 2007, Ben Tay wrote:
>> Hi,
>> I've no problem writing out codes in fortran fixed format with PETSc. However,
>> is it possible to do it in fortran free format as well?
>> I'm using visual fortran and there's error.
>> original :
>> test.F
>> module global_data
>>    implicit none
>>    save
>> #include "include/finclude/petscvec.h"
>> #include "include/finclude/petscmat.h"
>> #include "include/finclude/petscksp.h"
>> #include "include/finclude/petscpc.h"
>> #include "include/finclude/petscmat.h90"
>>    Vec    xx,b_rhs
>> How can I change this code to fortran free format *.f90?
>> Thanks
