Comparing between a PETSc matrix and a standard fortran array in compressed row format
Ben Tay zonexo at gmail.com
Sat Aug 4 20:31:27 CDT 2007
Now I'm comparing at every time step. The A matrix and rhs of the NSPCG
and PETSc matrix are exactly the same, NORM is zero. The solutions given
by both solvers are very similar for e.g. from 1-315 time step, and
varying slowly since it is a oscillating body problem.  Then strangely,
at time=316, PETSc's answer suddenly differs by a great difference. e.g.
p=0.3 to 50. I must also add that the flowfield at that time step still
"looks ok". However, the large pressure change of the pressure poisson
eqn caused the computation of the lift/drag coefficient to be erroneous.
Moreover, after that, the pressure slowly "returns back" to the same
answer such that of the NSPCG solver after a few time steps ... then
after a while the sudden change happens again. In the end, I got a cl/cd
vs time graph with lots of spikes.
I hope that the thing can be solved because the NSPCG solver is much
slower and it is not as stable.
Thanks
Barry Smith wrote:
>    Ben,
>     Are you comparing the two matrices at timestep 316? Also compare the
> two right hand sides at 316. Are they similar, totally different??
>    Barry
> On Sat, 4 Aug 2007, Ben Tay wrote:
>> Hi,
>> After using MatAXPY, I used MatGetRowMaxAbs, VecAb and VecMax to get the row
>> with max value, get the absolute of that value and print out the
>> location/value. I managed to find some minor mistakes and corrected them so
>> that the 2 matrix are identical. Unfortunately, the same thing still happens!
>> I've checked for convergence and the iteration no. is 1 and 8 for direct
>> solving and HYPRE's AMG respectively.  So there's no convergence problem. I've
>> also tried to change to the same pc/ksp as that of NSPCG, which is jacobi
>> presconditioning + KSPBCGS but the same thing happens.
>> Any idea what's happening?
>> Thanks
>> Barry Smith wrote:
>>>   Unless the matrix values are huge then this is a big difference. All you
>>> can do is print the difference matrix with ASCII MatView and
>>> look for large entries. This will tell you the locations of the trouble
>>> entries.
>>>    Barry
>>>> Hi,
>>>> I realised that the matrix storage format of NSPCG is actually ITPACK
>>>> storage
>>>> format. Anyway, I tried to insert the values into a PETSc matrix, use
>>>> MatAXPY
>>>> with the scalar a = -1 and then use MatNorm on the output matrix.
>>>> Using NORM_1, NORM_FROBENIUS and NORM_INFINITY
>>>> <../Vec/NORM_FROBENIUS.html#NORM_FROBENIUS>, I got ~543, 3194 and 556
>>>> respectively. Does this mean that the matrix are different? How "much"
>>>> different does that means?
>>>> So what is the next step? Is there anyway to find out the location of the
>>>> value which is different?
>>>> This is my comparison subroutine:
>>>> subroutine matrix_compare
>>>>    !compare big_A & PETSc matrix
>>>>    integer :: k,kk,II,JJ,ierr
>>>>    Vec    xx_test,b_rhs_test
>>>>      Mat    A_mat_test
>>>>    PetscScalar aa
>>>>    PetscReal nrm
>>>>    aa=-1.
>>>>    call
>>>> MatCreateSeqAIJ(PETSC_COMM_SELF,total_k,total_k,10,PETSC_NULL_INTEGER,A_mat_test,ierr)
>>>>    call VecCreateSeq(PETSC_COMM_SELF,total_k,b_rhs_test,ierr)
>>>>    call VecDuplicate(b_rhs_test,xx_test,ierr)
>>>>    call VecAssemblyBegin(b_rhs_test,ierr)
>>>>    call VecAssemblyEnd(b_rhs_test,ierr)
>>>>    call VecAssemblyBegin(xx_test,ierr)
>>>>    call VecAssemblyEnd(xx_test,ierr)
>>>>        do k=1,total_k
>>>>          do kk=1,10
>>>>            II=k-1
>>>>            JJ=int_A(k,kk)-1
>>>>                  call
>>>> MatSetValues(A_mat_test,1,II,1,JJ,big_A(k,kk),INSERT_VALUES,ierr)
>>>> call VecSetValue(b_rhs_test,II,q_p(k),INSERT_VALUES,ierr)
>>>>              end do
>>>>    end do
>>>> !    call MatCopy(A_mat,A_mat_test,DIFFERENT_NONZERO_PATTERN ,ierr)
>>>>    call MatAssemblyBegin(A_mat_test,MAT_FINAL_ASSEMBLY,ierr)
>>>>        call MatAssemblyEnd(A_mat_test,MAT_FINAL_ASSEMBLY,ierr)
>>>>    call MatAXPY(A_mat_test,aa,A_mat,SAME_NONZERO_PATTERN,ierr)
>>>>    call MatNorm(A_mat_test,NORM_INFINITY,nrm,ierr)
>>>>    print *, nrm
>>>>    end subroutine matrix_compare
>>>> Thanks!
>>>> Barry Smith wrote:
>>>>>   You can use MatCreateSeqAIJWithArrays() to "convert" the NSPCG matrix
>>>>> into
>>>>> PETSc format and then MatAXPY() to difference them and then MatNorm() to
>>>>> see
>>>>> how large the result is.   Make sure the PETSc or hypre solver is always
>>>>> converging. Run with
>>>>> -ksp_converged_reason and or -ksp_monitor. My guess is that the matrix
>>>>> is
>>>>> becoming very ill-conditioned so the solvers with the default options
>>>>> are
>>>>> failing.
>>>>>     Barry
>>>>> On Fri, 3 Aug 2007, Ben Tay wrote:
>>>>>> Hi,
>>>>>> I used 2 packages to solve my poisson eqn, which is part of my NS
>>>>>> unsteady
>>>>>> solver. One is the NSPCG solver package which uses the compressed row
>>>>>> format
>>>>>> to store the A matrix. The other is PETSc. I found that using both
>>>>>> solvers
>>>>>> gave me similar answers for a number of time step. However, after
>>>>>> that,
>>>>>> the
>>>>>> answer will suddenly change drastically for the PETSc case. This does
>>>>>> not
>>>>>> happen for the NSPCG solver.
>>>>>> For e.g. time step 1-315, oscillating airfoil case, pressure changes
>>>>>> smoothly,
>>>>>> similar answers in both cases
>>>>>> at time=316, pressure changes from -3.22 to -3.2 for NSPCG, but
>>>>>> pressure
>>>>>> changes from -3.21 to -60.2 for PETSc
>>>>>> This happens when I use HYPRE's AMG or PETSc's direct solver LU.
>>>>>> I have been trying to find out what's the cause and I can't find the
>>>>>> answer in
>>>>>> debugging. I would like to compare the values of the matrix of the 2
>>>>>> different
>>>>>> solvers and see if there's any difference. However, NSPCG's matrix is
>>>>>> in
>>>>>> compressed row format while PETSc's one is just an address and it
>>>>>> can't be
>>>>>> viewed easily. Moreover, it's a big matrix so it's not possible to
>>>>>> check
>>>>>> by
>>>>>> inspection. I'm thinking of subtracting one matrix by the other and
>>>>>> find
>>>>>> if
>>>>>> it's zero. What's the best way to solve this problem? Btw, I'm using
>>>>>> fortran
>>>>>> and there's no mpi
>>>>>> Thank you.
