Comparing between a PETSc matrix and a standard fortran array in compressed row format
Ben Tay zonexo at gmail.com
Fri Aug 3 22:17:19 CDT 2007
I realised that the matrix storage format of NSPCG is actually ITPACK
storage format. Anyway, I tried to insert the values into a PETSc
matrix, use MatAXPY with the scalar a = -1 and then use MatNorm on the
output matrix.
Using NORM_1, NORM_FROBENIUS and NORM_INFINITY
<../Vec/NORM_FROBENIUS.html#NORM_FROBENIUS>, I got ~543, 3194 and 556
respectively. Does this mean that the matrix are different? How "much"
different does that means?
So what is the next step? Is there anyway to find out the location of
the value which is different?
This is my comparison subroutine:
subroutine matrix_compare
    !compare big_A & PETSc matrix
    integer :: k,kk,II,JJ,ierr
    Vec    xx_test,b_rhs_test
    Mat    A_mat_test
    PetscScalar aa
    PetscReal nrm
    aa=-1.
    call
MatCreateSeqAIJ(PETSC_COMM_SELF,total_k,total_k,10,PETSC_NULL_INTEGER,A_mat_test,ierr)
    call VecCreateSeq(PETSC_COMM_SELF,total_k,b_rhs_test,ierr)
    call VecDuplicate(b_rhs_test,xx_test,ierr)
    call VecAssemblyBegin(b_rhs_test,ierr)
    call VecAssemblyEnd(b_rhs_test,ierr)
    call VecAssemblyBegin(xx_test,ierr)
    call VecAssemblyEnd(xx_test,ierr)
    do k=1,total_k
        do kk=1,10
            II=k-1
            JJ=int_A(k,kk)-1
            call
MatSetValues(A_mat_test,1,II,1,JJ,big_A(k,kk),INSERT_VALUES,ierr)
            call VecSetValue(b_rhs_test,II,q_p(k),INSERT_VALUES,ierr)
        end do
    end do
!    call MatCopy(A_mat,A_mat_test,DIFFERENT_NONZERO_PATTERN ,ierr)
    call MatAssemblyBegin(A_mat_test,MAT_FINAL_ASSEMBLY,ierr)
    call MatAssemblyEnd(A_mat_test,MAT_FINAL_ASSEMBLY,ierr)
    call MatAXPY(A_mat_test,aa,A_mat,SAME_NONZERO_PATTERN,ierr)
    call MatNorm(A_mat_test,NORM_INFINITY,nrm,ierr)
    print *, nrm
    end subroutine matrix_compare
Thanks!
Barry Smith wrote:
>   You can use MatCreateSeqAIJWithArrays() to "convert" the NSPCG matrix into
> PETSc format and then MatAXPY() to difference them and then MatNorm() to
> see how large the result is.
>   Make sure the PETSc or hypre solver is always converging. Run with
> -ksp_converged_reason and or -ksp_monitor. My guess is that the matrix is
> becoming very ill-conditioned so the solvers with the default options are
> failing.
>     Barry
> On Fri, 3 Aug 2007, Ben Tay wrote:
>> Hi,
>> I used 2 packages to solve my poisson eqn, which is part of my NS unsteady
>> solver. One is the NSPCG solver package which uses the compressed row format
>> to store the A matrix. The other is PETSc. I found that using both solvers
>> gave me similar answers for a number of time step. However, after that, the
>> answer will suddenly change drastically for the PETSc case. This does not
>> happen for the NSPCG solver.
>> For e.g. time step 1-315, oscillating airfoil case, pressure changes smoothly,
>> similar answers in both cases
>> at time=316, pressure changes from -3.22 to -3.2 for NSPCG, but pressure
>> changes from -3.21 to -60.2 for PETSc
>> This happens when I use HYPRE's AMG or PETSc's direct solver LU.
>> I have been trying to find out what's the cause and I can't find the answer in
>> debugging. I would like to compare the values of the matrix of the 2 different
>> solvers and see if there's any difference. However, NSPCG's matrix is in
>> compressed row format while PETSc's one is just an address and it can't be
>> viewed easily. Moreover, it's a big matrix so it's not possible to check by
>> inspection. I'm thinking of subtracting one matrix by the other and find if
>> it's zero. What's the best way to solve this problem? Btw, I'm using fortran
>> and there's no mpi
>> Thank you.
