Running 'make' command in verbose mode
Sumit Vaidya sumit_vaidya at persistent.co.in
Wed Aug 1 08:42:30 CDT 2007
I want to run the 'make' command in verbose mode.
I want to know which files(.c/.f) the compiler(gcc/g77) takes as an input
and which are the libraries that are created as an output.
How to achieve this?
Sumit
DISCLAIMER
This e-mail may contain privileged and confidential information which is the property of Persistent Systems Pvt. Ltd. It is intended only for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you are not authorized to read, retain, copy, print, distribute or use this message. If you have received this communication in error, please notify the sender and delete all copies of this message. Persistent Systems Pvt. Ltd. does not accept any liability for virus infected mails.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070801/9a9effac/attachment.htm>
