using hypre through petsc
Yaron Kretchmer
yaronkretchmer at gmail.com
Fri Sep 29 16:14:57 CDT 2006
If the latter (Petsc not configured to use Hypre), wouldn't Matt get an
error when specifying hypre as preconditioner?
Yaron
On 9/29/06, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Either you are not calling KSPSetFromOptions() in your
> code (or SNESSetFromOptions() OR PETSc was not configured
> to use hypre. To configure PETSc to use hypre you
> must use the additional config/configure.py option
> --download-hypre
> Good luck,
> Barry
> On Fri, 29 Sep 2006, Matt Funk wrote:
> > This might be a pretty stupid question, especially since i did this a
> while
> > back and it worked.
> > However, how do i specify thsis? Do i run my executable do and then
> simply
> > append -pc_type hypre -pc_hypre_type boomeramg -help and it will print
> out
> > the options?
> > Because when i do that i get:
> > Options for all PETSc programs:
> > -on_error_abort: cause an abort when an error is detected. Useful
> > only when run in the debugger
> > -on_error_attach_debugger [gdb,dbx,xxgdb,ups,noxterm]
> > start the debugger in new xterm
> > unless noxterm is given
> > -start_in_debugger [gdb,dbx,xxgdb,ups,noxterm]
> > start all processes in the debugger
> > -on_error_emacs <machinename>
> > emacs jumps to error file
> > -debugger_nodes [n1,n2,..] Nodes to start in debugger
> > -debugger_pause [m] : delay (in seconds) to attach debugger
> > -stop_for_debugger : prints message on how to attach debugger manually
> > waits the delay for you to attach
> > -display display: Location where graphics and debuggers are displayed
> > -no_signal_handler: do not trap error signals
> > -mpi_return_on_error: MPI returns error code, rather than abort on
> internal
> > error
> > -fp_trap: stop on floating point exceptions
> > note on IBM RS6000 this slows run greatly
> > -malloc_dump <optional filename>: dump list of unfreed memory at
> conclusion
> > -malloc: use our error checking malloc
> > -malloc no: don't use error checking malloc
> > -mallocinfo: prints total memory usage
> > -malloc_debug: enables extended checking for memory corruption
> > -options_table: dump list of options inputted
> > -options_left: dump list of unused options
> > -options_left no: don't dump list of unused options
> > -tmp tmpdir: alternative /tmp directory
> > -shared_tmp: tmp directory is shared by all processors
> > -not_shared_tmp: each processor has separate tmp directory
> > -memory_info: print memory usage at end of run
> > -get_total_flops: total flops over all processors
> > -log[_all _summary]: logging objects and events
> > -log_trace [filename]: prints trace of all PETSc calls
> > -info <optional filename>: print informative messages about the
> calculations
> > -v: prints PETSc version number and release date
> > -options_file <file>: reads options from file
> > -petsc_sleep n: sleeps n seconds before running program
> > but nothing about hypre .... ?
> > mat
> > On Tuesday 19 September 2006 17:05, Yaron Kretchmer wrote:
> > > Hi Matt
> > > You can start experimenting by using
> > > which will give you all the boomeramg options.
> > > When I use it I get intermittent segfaults, which I couldn't resolve
> with
> > > the Hypre guys, so good luck.
> > > Yaron
> > > On 9/19/06, Matt Funk <mafunk at nmsu.edu> wrote:
> > > > Hi,
> > > > i am trying to use boomeramg from hypre in petsc. What i am doing
> right
> > > > now is
> > > > simply do:
> > > > m_ierr = PCSetType(m_pc,PCHYPRE);//CHKERRQ(ierr)
> > > > m_ierr = PCHYPRESetType(m_pc,"boomeramg");
> > > > then i do my kspsetup etc...
> > > > i was wondering what other things i need to configure/set to
> properly use
> > > > the
> > > > hypre preconditioner with petsc. This is new to me, so i am not
> really
> > > > experienced with this (that is using external packages through
> petsc).
> > > > Also,
> > > > these are the only hypre calls i found in the manual pages.
> > > > Maybe somebody with more experience can share some of their wisdom
> > > > or point to a place where i can read up on it?
> > > > thanks
> > > > mat
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060929/95f71074/attachment.htm>
