using hypre through petsc
Matt Funk
mafunk at nmsu.edu
Fri Sep 29 15:45:11 CDT 2006
This might be a pretty stupid question, especially since i did this a while
back and it worked.
However, how do i specify thsis? Do i run my executable do and then simply
append -pc_type hypre -pc_hypre_type boomeramg -help and it will print out
the options?
Because when i do that i get:
Options for all PETSc programs:
-on_error_abort: cause an abort when an error is detected. Useful
only when run in the debugger
-on_error_attach_debugger [gdb,dbx,xxgdb,ups,noxterm]
start the debugger in new xterm
unless noxterm is given
-start_in_debugger [gdb,dbx,xxgdb,ups,noxterm]
start all processes in the debugger
-on_error_emacs <machinename>
emacs jumps to error file
-debugger_nodes [n1,n2,..] Nodes to start in debugger
-debugger_pause [m] : delay (in seconds) to attach debugger
-stop_for_debugger : prints message on how to attach debugger manually
waits the delay for you to attach
-display display: Location where graphics and debuggers are displayed
-no_signal_handler: do not trap error signals
-mpi_return_on_error: MPI returns error code, rather than abort on internal
error
-fp_trap: stop on floating point exceptions
note on IBM RS6000 this slows run greatly
-malloc_dump <optional filename>: dump list of unfreed memory at conclusion
-malloc: use our error checking malloc
-malloc no: don't use error checking malloc
-mallocinfo: prints total memory usage
-malloc_debug: enables extended checking for memory corruption
-options_table: dump list of options inputted
-options_left: dump list of unused options
-options_left no: don't dump list of unused options
-tmp tmpdir: alternative /tmp directory
-shared_tmp: tmp directory is shared by all processors
-not_shared_tmp: each processor has separate tmp directory
-memory_info: print memory usage at end of run
-get_total_flops: total flops over all processors
-log[_all _summary]: logging objects and events
-log_trace [filename]: prints trace of all PETSc calls
-info <optional filename>: print informative messages about the calculations
-v: prints PETSc version number and release date
-options_file <file>: reads options from file
-petsc_sleep n: sleeps n seconds before running program
but nothing about hypre .... ?
mat
On Tuesday 19 September 2006 17:05, Yaron Kretchmer wrote:
> Hi Matt
> You can start experimenting by using
> which will give you all the boomeramg options.
> When I use it I get intermittent segfaults, which I couldn't resolve with
> the Hypre guys, so good luck.
> Yaron
> On 9/19/06, Matt Funk <mafunk at nmsu.edu> wrote:
> > Hi,
> > i am trying to use boomeramg from hypre in petsc. What i am doing right
> > now is
> > simply do:
> > m_ierr = PCSetType(m_pc,PCHYPRE);//CHKERRQ(ierr)
> > m_ierr = PCHYPRESetType(m_pc,"boomeramg");
> > then i do my kspsetup etc...
> > i was wondering what other things i need to configure/set to properly use
> > the
> > hypre preconditioner with petsc. This is new to me, so i am not really
> > experienced with this (that is using external packages through petsc).
> > Also,
> > these are the only hypre calls i found in the manual pages.
> > Maybe somebody with more experience can share some of their wisdom ...,
> > or point to a place where i can read up on it?
> > thanks
> > mat
