question on solving the transpose of a system
Randall Mackie
randy at geosystem.us
Mon Sep 25 14:43:41 CDT 2006
Barry,
Same effect with gmres. I'm going to try using MatTranspose
and transpose both A and P, and use KSPSolve and see what happens.
Randy
Barry Smith wrote:
> Randy,
> Can you try -ksp_type gmres and see if you still get the
> affect?
> Barry
> On Mon, 25 Sep 2006, Randall Mackie wrote:
>> Barry Smith wrote:
>>> Randy,
>>>> Now, if I want to solve (2) above, do I simply make a call to
>>>> KSPSolveTranspose(ksp,b,xsol), where I've set b to the right
>>>> hand side of (2)
>>> Yes, this is the way we intend it to be used. You should not
>>> have to construct the transposed matrices.
>>> Questions:
>>> Are you using KSPSetNullSpace()?
>> No
>>> Are you using right or left preconditioning? Or not setting it?
>> I'm not setting it, just using the default
>>> What KSP method are you using?
>>> What preconditioner are you using?
>> -em_ksp_truemonitor \
>> -em_ksp_type bcgs \
>> -em_pc_type bjacobi \
>> -em_sub_pc_type ilu \
>> -em_sub_pc_factor_levels 3 \
>> -em_sub_pc_factor_fill 6 \
>>> Barry
>>>> I have a situation where I have to solve the following problems:
>>>> 1) Ax=b
>>>> 2) (A)^T u = c
>>>> A is not symmetric.
>>>> After I set up my A matrix and the preconditioner P (which is NOT the same
>>>> as
>>>> A),
>>>> I solve it like so:
>>>> call set_P(da,P,l,m,n,period,resist,x,y,z)
>>>> call set_A(da,A,l,m,n,period,resist,x,y,z)
>>>> call MatSetBlockSize(A,3,ierr)
>>>> call MatSetBlockSize(P,3,ierr)
>>>> call KSPSetOperators(ksp,A,P,DIFFERENT_NONZERO_PATTERN,ierr)
>>>> call KSPSetInitialGuessNonzero(ksp,PETSC_TRUE,ierr)
>>>> call KSPSolve(ksp,b,xsol,ierr)
>>>> call KSPGetIterationNumber(ksp,its,ierr)
>>>> call KSPGetConvergedReason(ksp,reason,ierr)
>>>> hand side of (2), or do I have to create the transposes of both
>>>> A and the preconditioner and just use KSPSolve?
>>>> When I've tried just using KSPSolveTranspose, the preconditioned residual
>>>> norm falls, but not as rapidly as when doing (1), and the true residual
>>>> norm
>>>> seems not to change much at all.
>>>> Thanks, Randy
Randall Mackie
GSY-USA, Inc.
PMB# 643
2261 Market St.,
San Francisco, CA 94114-1600
Tel (415) 469-8649
Fax (415) 469-5044
California Registered Geophysicist
License No. GP 1034
