petsc I/O
Barry Smith
bsmith at mcs.anl.gov
Fri Sep 15 15:15:44 CDT 2006
Matt,
if the element lives on my process then use VecGetArray() to access
the value and call
PetscSynchronizedPrintf()
Not completely canned but easy to do.
Barry
On Fri, 15 Sep 2006, Matt Funk wrote:
> Hi,
> thanks for the answers first of all. I have another question though ... :)
> Say, i want to print a specific element from a PETSc global vector. Is there a
> function (PetscSunchFPrintF does not do this i believe) to which i simply
> pass the file handle, communicator, the vector and the element and it writes
> the value to the file?
> thanks
> mat
> On Wednesday 13 September 2006 17:13, Berend van Wachem wrote:
> > Hi Matt,
> > > i need to read in an input file. So to open my file i use PETSCFOpen
> > > which works fine. But then my problems begin ... :)
> > > I guess i need to tell only the first proc in the communicator to fscan.
> > > But is there a PETSC function that returns me the processor id?
> > > And when i read the parameters in on the first proc i need to broadcast
> > > them to the other procs. Does PETSC have anything for this?
> > For both issues you can use standard MPI:
> > to get the processor ID:
> > ierr=MPI_Comm_rank(MPI_Comm Communicator,int *rank);
> > to broadcast information:
> > ierr=MPI_Bcast ( void *buffer, int count, MPI_Datatype datatype, int
> > root, MPI_Comm comm )
> > If possible, I would recommend you to use the PetscViewer interface for
> > your IO handling; it is very easy.
> > Good luck,
> > Berend.
