Matrix convergence - part 2
billy at dem.uminho.pt
Mon Oct 30 22:39:03 CST 2006
When I use the option -sub_pc_type ilu or no option, I can't lower the residual
of the pressure which is derived from a Laplace equation to the specified
tolerance of 1E-8:
Matrix p Number of iterations: 8 Residual: +3.971771E-01
On the other hand if I use option -sub_pc_type lu, I get:
Matrix p Number of iterations: 1 Residual: +6.174315E-24
Since this only happens in some cases, I would like to switch between ILU and LU
preconditioning.
I tried that by adding the following code:
PCASMGetSubKSP(pc, &nlocal, &first, &subksp);
KSPGetPC(subksp, &subpc);
PCSetType(subpc, SubPrecondProc);
Being SubPrecondProc = PCILU or SubPrecondProc = PCLU. However I get the
following error:
0]PETSC ERROR: PCASMGetSubKSP_ASM() line 488 in src/ksp/pc/impls/asm/asm.c
[0]PETSC ERROR: Operation done in wrong order!
[0]PETSC ERROR: Need to call PCSetUP() on PC (or KSPSetUp() on the outer KSP
object) before calling here!
[0]PETSC ERROR: PCASMGetSubKSP() line 786 in src/ksp/pc/impls/asm/asm.c
[0]PETSC ERROR: KSPGetPC() line 1135 in src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: Corrupt argument: see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Corrupt!
[0]PETSC ERROR: Invalid Pointer to Object: Parameter # 1!
[0]PETSC ERROR: PCSetType() line 61 in src/ksp/pc/interface/pcset.c
[0]PETSC ERROR: Invalid argument!
[0]PETSC ERROR: Wrong type of object: Parameter # 1!
Matrix s Number of iterations: 0 Residual: +0.000000E+00
[0]PETSC ERROR: PCASMGetSubKSP_ASM() line 488 in src/ksp/pc/impls/asm/asm.c
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably
memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or try http://valgrind.org on linux to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------- Stack Frames ---------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] KSPGetPC line 1134 src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: [0] PCASMGetSubKSP_ASM line 486 src/ksp/pc/impls/asm/asm.c
[0]PETSC ERROR: [0] PCASMGetSubKSP line 782 src/ksp/pc/impls/asm/asm.c
[0]PETSC ERROR: --------------------------------------------
[0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR: !
Anyone knows why?
Billy.
