why i cannot find PetscMapCreateMPI()
Sat Oct 28 22:05:12 CDT 2006
  Parts of the PETSc API changes between releases; this is fundamental
to PETSc development and is clearly stated in the users manual. Thus
when you link against PETSc libraries you have to make sure you
are consistent. In
http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/changes/231.html
you will find the note: PetscMap is no longer a public PETSc object
See the manual page for PetscMapInitialize() for its new usage
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Vec/PetscMapInitialize.html
  Barry
On Sun, 29 Oct 2006, Yixun Liu wrote:
> Hi,
> I read a source code,which is compilered successfully on Linux, Gcc. When I migrate it from Linux to Windows compiler cannot find the routine PetscMapCreateMPI(). I search from the manulpages and cannot find it. Does this routine is only a Linux version?
> Regards,
> Yixun
