about MatCreateSeqAIJ and MatCreateMPIAIJ
Yixun Liu
yxliu at fudan.edu.cn
Tue Oct 24 01:31:07 CDT 2006
Thanks.
I need two things to be confirmed. For example, I have 4 processors and the codes are like,
PetscInitialize();
MatCreateSeqAIJ();
PetscFinalize();
Can I draw the conclusion that each code between PetscInitialize() and PetscFinalize() will be called by each processor? So, each processor will have a sequential matrix.
Best,
Yixun
----- Original Message -----
To: "PETSC" <petsc-users at mcs.anl.gov>
Sent: Tuesday, October 24, 2006 11:39 AM
Subject: Re: about MatCreateSeqAIJ and MatCreateMPIAIJ
> On Tue, 24 Oct 2006, Yixun Liu wrote:
>> Hi,
>> I am confused with this two routines.
>> MatCreateMPIAIJ(PETSC_COMM_WORLD,...) creates a parallel
>> matrix,which will be distributed on all the
>> processors. MatCreateSeqAIJ(PETSC_COMM_SELF, ...) creates a
>> sequential matrix. But because this routine will be called by each
>> processor, which processor create this matrix?
> If the routine is called on each processor - then each of them will
> Generally one uses SeqAIJ when running the application on only one
> processor. Also one can think of a case where someone might want to
> store sequential matrices on each processor [the matrix sizes/values
> being different on each proc]
> For eg: We internally store MPIAIJ mat as a collection of SeqAIJ
> matrices on each proc. For additional info - check the 'Example usage'
> section at:
> http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatCreateMPIAIJ.html
> Satish
