General matrix interative solver
Julian julvar at tamu.edu
Wed Oct 11 11:22:53 CDT 2006
Hong,
The times are for the solution process alone and the initial guess is the
same, i.e. zero.
As for the algorithm, they are probably different.
Can you tell me how to pass 'runtime options' like -help and -ksp_view from
within the code... I mean, at compile time.
thanks
> Julian,
> When comparing the inhouse solver and petsc solver, you need make sure
> 1. Timings are collected for solution process. The matrix and vector
>    assembly should be excluded.
> 2. They should use same iterative algorithm. By default, petsc uses
>    gmres with restart=30 and ilu(0) preconditioner. Petsc supports
>    symmetric matrices, e.g., runtime option '-ksp_type cg
> -pc_type icc'
>    might give better performance
> 3. They should start from same intial guess. By default, petsc
>    initial guess is zero.
> You can use '-ksp_view' to see what algorithm and options are
> used in petsc.
> Hong
> On Wed, 11 Oct 2006, Julian wrote:
> > Hello,
> > I implemented the iterative sparse matrix solver in PetSc
> into my FEM
> > code recently. I compared the results from a problem with 1317
> > unknowns. I used a direct solver to obtain the reference
> solution. I
> > have another in-house sparse iterative solver that I have
> been using
> > so far. It was written by someone else but I have access to
> the source for that solver.
> > I find the 'error norm' in the solution by taking the
> square root of
> > the sum of the squares of the absolute differences between the
> > solution from the direct solver and the iterative solver. I am
> > ignoring the numerical zeros in the solutions when doing this.
> > I find that in order to get same order of the error norm (1e-13) as
> > the in-house iterative solver, the petsc solver takes a much longer
> > time and larger number of iterations. While the inhouse solver took
> > less than one second, the petsc solver took 13 seconds. The inhouse
> > solver took 476 iterations whereas the petsc solver took
> 4738 iterations.
> > I'm guessing this has to do with different setting of the solver in
> > petsc such as the preconditioner etc.
> > Can you tell me what the different settings are? And how to
> tweak them
> > so that I can atleast get as good as a performance as the
> inhouse code ?
> > Given below is how I have implemented the petsc solver:
> > /////initialization
> >     PetscInitializeNoArguments();
> >         Assert( mat = (double*)malloc(sizeof(Mat)) );
> >     MatCreateSeqAIJ(PETSC_COMM_SELF, L, L,
> >       PETSC_DEFAULT, PETSC_NULL, (Mat*)mat);
> > ////// this is the function I use to populate the matrix
> > MatSetValue(*(Mat*)mat, ii, jj, value, ADD_VALUES);
> > ////// this is how I actaully solve the matrix
> >   MatAssemblyBegin(*(Mat*)mat, MAT_FINAL_ASSEMBLY);
> >   MatAssemblyEnd(*(Mat*)mat, MAT_FINAL_ASSEMBLY);
> >   double iter_error = 1e-10;
> >   int max_iter_num = 10000;
> >   int num_of_iter;
> >         Vec rhs, x;
> >     VecCreateSeqWithArray(PETSC_COMM_SELF, L, b, &rhs);
> >     VecDuplicate(rhs, &x);
> >     KSP ksp;
> >     KSPCreate(PETSC_COMM_SELF, &ksp);
> >     KSPSetTolerances(ksp, iter_error, PETSC_DEFAULT,
> >       PETSC_DEFAULT, max_iter_num);
> >     KSPSetFromOptions(ksp);
> >     KSPSetOperators(ksp, *(Mat*)mat, *(Mat*)mat,
> >       SAME_PRECONDITIONER);
> >     KSPSolve(ksp,rhs,x);
> >     PetscReal r_norm;
> >     KSPGetResidualNorm(ksp, &r_norm);
> >     KSPGetIterationNumber(ksp, &num_of_iter);
> >         cout << "max_iter_num\t" << max_iter_num << endl;
> >         cout << "iter_error\t" << iter_error << endl;
> >         cout << "Matrix solver step " << num_of_iter << ",
> residual "
> > << r_norm << ".\n";
> >         PetscScalar *p;
> >     VecGetArray(x, &p);
> >     for(int i=0; i<L; i++) {
> >         b[i] = p[i];
> >     VecRestoreArray(x, &p);
> >     KSPDestroy(ksp);
> >     VecDestroy(rhs);
> >     VecDestroy(x);
> > cout <<"Iterations for convergence="<< num_of_iter << " -
> Residual Norm = "
> > << r_norm << endl;
> > If this is not the typical method to be used to solve this kind of
> > problem, please let me know what functions I should use.
> > I should mention that the inhouse code is for symmetric
> matrices and
> > from what I understand, the petsc solver works for general
> unsymmetric matrices.
> > But I think for iterative solvers, it should still give around the
> > same performance.
> > I tested the solvers against some other problems as well, and I got
> > the same performance.. In some cases, no matter how many
> iterations it
> > goes through, the petsc solver would not go below a certain
> error norm
> > whereas the inhouse solver would get almost exactly the
> same answer as
> > the direct solver solution. I'm thinking the petsc solver should be
> > able to solve this problem just as easily. It would be
> great if anyone
> > could help me figure out the appropriate settings I should
> use in the petsc solver.
> > Thanks,
> > Julian.
