MatCreateMPIAIJ
Xiaoxu Wang
xiwang at dragon.rutgers.edu
Tue Oct 3 13:03:53 CDT 2006
The error is at line 1023 of "plog.c".
An unhandled exception of type 'System.NullReferenceException' occurred
in Unknown Module.
Additional information: Object reference not set to an instance of an
object.
The matrix I am trying to initialize is the stiffness matrix K of finite
element methods. Later the dynamical system is solved as (I + Dt*K)
U(t+1) = U(t) + Dt.F(t) by calling KSPSolve. Any idea how to set the
number of local rows? I am running the code on PC now, but want to keep
MatCreateMPIAIJ in it.
Xiaoxu
----- Original Message ----- From: "Barry Smith" <bsmith at mcs.anl.gov>
To: <petsc-users at mcs.anl.gov>
Sent: Tuesday, October 03, 2006 8:32 AM
Subject: Re: MatCreateMPIAIJ
> On Mon, 2 Oct 2006, Xiaoxu Wang wrote:
>> Hi,
>> I am a beginner on PETSC. This is my question about
>> MatCreateMPIAIJ. I
>> have a sparse matrix and only know the total number of nonzeros each
>> row. The
>> number of local rows and the number of local columns has been set to
>> PETSC_DECIDE. Therefore I don't know the size of each portion and it
>> is hard
>> to tell d_nnz and o_nnz. I use the total number of nunzeros as d_nnz
>> and get
>> an allocation error.
> It would be helpful to know the exact error message:
>> How to deal with this problem? Should I explicitly
>> specify the number of local rows and the number of local columns and
>> calculate
>> d_nnz and o_nnz? Or let PETSC decide the number of local rows and the
>> number
>> of local columns, and then use another function to get these values?
>> Any
>> other better solution?
> You should specifically set the number of local rows and columns and
> then
> compute the values of d_nnz and o_nnz. How you determine d_nnz and
> o_nnz is
> problem dependent and depends on what type of discretization you are
> using:
> finite differences, elements etc.
> Barry
>> Thanks a lot,
>> Xiaoxu
