Modifying the MSDdev *.dsw *.dsp files to run without mpi
Fri Nov 24 19:45:15 CST 2006
We are not able to generate MSDev files, so you will have to alter them
yourself. You need to take out the references to MPI.
   Matt
On 11/24/06, Ben Tay <zonexo at gmail.com> wrote:
> Hi,
> yes I did that. There is no problem if I run the example in cygwin. However,
> if I use the project files for MSDev given in the petsc package, it gives me
> errors during linking. Compiling works though.
> I tried to recompile the whole Petsc with mpich1 and there is no such
> errors.
> Thank you.
> On 11/25/06, Matthew Knepley <knepley at gmail.com> wrote:
> > You need to configure using --wih-mpi=0.
> > Matt
> > On 11/24/06, Ben Tay < zonexo at gmail.com> wrote:
> > > Hi,
> > > I've managed to compile and run the examples in MSDev when i use MPICH.
> > > However, if I compile without MPI, I 'll get errors during linking. How
> > > should I modify my configuration file in MSDev so that I can run without
> > > mpi?
> > > Thank you very much!
> > "Failure has a thousand explanations. Success doesn't need one" -- Sir
> > Alec Guiness
Alec Guiness
