Modifying the MSDdev *.dsw *.dsp files to run without mpi
Ben Tay zonexo at gmail.com
Fri Nov 24 18:46:23 CST 2006
I've managed to compile and run the examples in MSDev when i use MPICH.
However, if I compile without MPI, I 'll get errors during linking. How
should I modify my configuration file in MSDev so that I can run without
mpi?
Thank you very much!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20061125/2f8201c1/attachment.htm>
