petsc object hierarchy
Wed Nov 22 07:05:18 CST 2006
There is a classic slides in all the tutorials about control flow, but
it is really simple:
  - Mat uses Vec
  - PC uses (Mat, Vec)
  - KSP use (PC, Mat, Vec)
  - SNES uses (KSP, PC, Mat, Vec)
  - TS uses (SNES, KSP, PC, Mat, Vec)
Very linear.
  Matt
On 11/21/06, Yaron Kretchmer <yaronkretchmer at gmail.com> wrote:
> Hi all
> I'd like to understand the class/object hierarchy of Petsc (i.e. KSP uses a
> MAT , which uses a VEC etc. etc.)- other than digging through the code, how
> can i do this?
> Thanks
> Yaron
"Failure has a thousand explanations. Success doesn't need one" -- Sir
Alec Guiness
