PETSC debug
Barry Smith
bsmith at mcs.anl.gov
Wed Nov 15 14:39:54 CST 2006
Look at the vector entries earlier and earlier in the code
until you find the point when they are not nuts. Then you know the
small piece of code that is making them nuts.
Also use -malloc_debug (-trmalloc in old versions of PETSc) or
better valgrind www.valgrind.org to make sure that it is not
memory corruption making the crazy values.
Barry
On Wed, 15 Nov 2006, billy at dem.uminho.pt wrote:
> Hi,
> How do you suggest I track the origin of the problem. Which data should I look at?
> Thanks,
> Billy.
> Quoting Barry Smith <bsmith at mcs.anl.gov>:
> > These numbers are all garbage (tiny numbers like this very, very, very
> > rarely
> > appear). It looks like the vector or the array you are using is not being
> > initialized or is getting totally written over incorrectly.
> > Barry
> > > x has very small values and some zeros. Is this a problem?
> > > (gdb) p *x at 1710
> > > {5.6661805945484757e-226, -1.1627609243420647e-234,
> > > -3.0191454638161275e-228, 4.9827910759046858e-233,
> > -2.0736747864315411e-242,
> > > -6.2486892875076229e-236, 7.936938687044959e-240,
> > -2.7194212807360601e-249,
> > > -8.588425549413817e-243, 2.3024631606271122e-243,
> > -5.9846691224557681e-252,
> > > -2.2335202330567468e-245, 9.7831244726432479e-236,
> > -1.3552548630405792e-244,
> > > -3.495520937088327e-238, 5.4989262786345397e-243,
> > -1.3210098902792841e-252,
> > > -3.8682663837382384e-246, 8.8387035435575233e-250,
> > -1.8090256621813952e-259,
> > > -5.4716023064278407e-253, 3.588000018861786e-253,
> > -6.2458537296193104e-262,
> > > -2.3148026340361519e-255, 1.0977920182613153e-245,
> > -1.0249411693868054e-254,
> > > -2.6419424389659324e-248, 3.9853740743647345e-253,
> > -5.4255411897492446e-263,
> > > -1.5685468152877737e-256, 6.4972881272145346e-260,
> > -7.7132606040774855e-270,
> > > -2.2883458301363077e-263, 3.7376905182602783e-263,
> > -4.3589162441629927e-272,
> > > -1.6122153535564706e-265, 5.4679961341990742e-256,
> > -3.4946761363871895e-265,
> > > -9.0506057005070676e-259, 1.2625051605987276e-263,
> > -9.8127138874528815e-274,
> > > -2.8171459920204651e-267, 2.1144094764316537e-270,
> > -1.4661783326174102e-280,
> > > -4.3021011674687748e-274, 1.7171839888390158e-273,
> > -1.355360583021068e-282,
> > > -5.0256495711998189e-276, 2.3441225393534538e-275,
> > -1.4167665839646082e-284,
> > > -9.5098664261506559e-276, 5.8664086258683721e-265,
> > -5.2303663615699708e-274,
> > > -3.4638320353774473e-265, 7.1774245671418306e-255,
> > -9.5315249514698032e-264,
> > > -6.22580454316614e-255, 4.3135135163622493e-245,
> > -8.6106571400568118e-254,
> > > -5.54411948811998e-245, 1.2782302660591342e-235,
> > -3.8700430138360975e-244,
> > > -2.4540088843175776e-235, 1.8714298666616161e-226,
> > -8.667061714016371e-235,
> > > -5.4046157807505651e-226, 1.3558688389339507e-217,
> > -9.6883371298320722e-226,
> > > ---Type <return> to continue, or q <return> to quit---
> > > -5.9285856500623996e-217, 4.8468289723098665e-209,
> > -5.3857466678811828e-217,
> > > -3.2242188218384035e-208, 8.4534293726532241e-201,
> > -1.4738192384650725e-208,
> > > -8.5980759783639217e-200, 6.907091796675751e-193,
> > -1.9033438119138147e-200,
> > > -1.0763770568701642e-191, 2.6478532383011193e-272,
> > -1.4903005865209107e-282,
> > > -7.7998156143119667e-274, 9.305780800265163e-262,
> > -8.8839704462246742e-272,
> > > -4.5901635372628567e-263, 1.6034530482636144e-251,
> > -2.6131364216028464e-261,
> > > -1.3303679068670779e-252, 1.3592022238328847e-241,
> > -3.7997620105273078e-251,
> > > -1.9017131279478928e-242, 5.6792247063849799e-232,
> > -2.7364107576938111e-241,
> > > -1.3423648502867758e-232, 1.1692077782649843e-222,
> > -9.7510387600061777e-232,
> > > -4.6696270174942923e-223, 1.1853783027581269e-213,
> > -1.7218922665317482e-222,
> > > -8.0083000299810735e-214, 5.8785159049366656e-205,
> > -1.495807982671848e-213,
> > > -6.7077377611273877e-205, 1.4070570606363661e-196,
> > -6.3472382608798458e-205,
> > > -2.7230139900247648e-196, 1.5497123236581113e-188,
> > -1.2485875796131097e-196,
> > > -5.0753617625768587e-188, 1.5434660362531493e-265,
> > -9.6427364575548134e-276,
> > > -4.9469124048614407e-267, 5.5771128650726324e-255,
> > -6.0715211415635001e-265,
> > > -3.0557860054339049e-256, 9.7596266862900188e-245,
> > -1.8630746938040184e-254,
> > > -9.1835699478680429e-246, 8.400502948812723e-235,
> > -2.8372007398618318e-244,
> > > -1.365943291479874e-235, 3.5683163152848973e-225,
> > -2.1529642010355749e-234,
> > > -1.0086136614457182e-225, 7.470797689290204e-216,
> > -8.1244038233290801e-225,
> > > -3.6841086790658924e-216, 7.6946486289534802e-207,
> > -1.5231479988588442e-215,
> > > -6.6343355238597203e-207, 3.8658097394017472e-198,
> > -1.4018784919234662e-206,
> > > -5.7883232195093694e-198, 9.3704091845606854e-190,
> > -6.2833327107970169e-198,
> > > -2.4015591026235036e-189, 1.0604778036924017e-181,
> > -1.3130129893123058e-189,
> > > -4.3944520676710034e-181, 5.3191550180698584e-174,
> > -1.2276467039908345e-181,
> > > 6.582654853774009e-258, -3.6960150023175459e-267,
> > -1.541051696004311e-258,
> > > 1.5081568307026851e-247, -1.2291453940848028e-256,
> > -5.045748607868979e-248,
> > > 1.6985391993644289e-237, -2.0388029995970922e-246,
> > -8.2307676982689932e-238,
> > > 9.31882138782716e-228, -1.6611812318932581e-236,
> > -6.5847692143411066e-228,
> > > 2.4911590486436157e-218, -6.6411748999525368e-227,
> > -2.578412473673239e-218,
> > > 3.2461544324197385e-209, -1.3019895450678336e-217,
> > -4.930407732106102e-209,
> > > 2.0647053899839311e-200, -1.2536927838659388e-208,
> > -4.5973820374997486e-200,
> > > 6.3999453950640209e-192, -5.9162039831540975e-200,
> > -2.0733460339667467e-191,
> > > 9.6386220362933024e-184, -1.3685224770731774e-191,
> > -4.468872196846956e-183,
> > > 6.9383373250314803e-176, -1.5267617834505389e-183,
> > -4.3847638022619328e-175,
> > > 2.2993251811195029e-168, -8.018740019783814e-176,
> > 8.0187312547169491e-280,
> > > -1.9681088822187587e-289, -8.6000837193564188e-281,
> > 2.4418184153863893e-291,
> > > -3.6413466395574048e-301, -1.6520119055708723e-292,
> > 6.2083711391797733e-303,
> > > 0, -2.7166342721641981e-304, 0 <repeats 54 times>,
> > 1.3382706765032754e-300,
> > > 0, -3.7946354577853773e-304, 6.3527319749529548e-289,
> > > -1.0316342902978391e-298, -2.7857994540718757e-292,
> > 1.3926426017545835e-277,
> > > -3.7119818003349503e-287, -9.8649586986765956e-281...}
> > > Billy.
> > > > Billy,
> > > > The x array contains the vector entries. It is either that
> > > > 1) idx == 1710 is not a valid index or more likely
> > > > 2) x[] on input has garbage values in it.
> > > > Can you call VecView() on x right before or after
> > > > it is passed into the MatMult? My guess is it has
> > > > garbage in it from earlier in the code.
> > > > Barry
> > > > On Tue, 14 Nov 2006, billy at dem.uminho.pt wrote:
> > > > > Hi,
> > > > > I was running my code and I got FPE error on alpha machines.
> > > > > Using gdb the output is the following. I am using 4 processors.
> > > > > Program received signal SIGFPE, Arithmetic exception.
> > > > > 0x1202c4e1c in MatMult_SeqBAIJ_1 (A=0x120bbc7c0, xx=0x120be0770,
> > > > > zz=0x120bc9fb0) at baij2.c:260
> > > > > 260 while (n--) sum += *v++ * x[*idx++];
> > > > > (gdb) print n
> > > > > $1 = 0
> > > > > (gdb) print idx
> > > > > $2 = (PetscInt *) 0x120c7aab8
> > > > > (gdb) print *idx
> > > > > $3 = 1710
> > > > > (gdb) print v
> > > > > $4 = (MatScalar *) 0x120c99190
> > > > > (gdb) print *v
> > > > > $5 = 4.0109832449655266e-12
> > > > > (gdb) print x
> > > > > $6 = (PetscScalar *) 0x120be1690
> > > > > (gdb) print x[*idx]
> > > > > $7 = 1.2349520920477556e-308
> > > > > (gdb) print sum
> > > > > $8 = 0
> > > > > Billy
