how to use PetscMap?
    Yixun Liu
    yxliu at fudan.edu.cn
    Thu Nov  2 20:15:22 CST 2006
I use PetscMap as below,
 PetscMap map;
 ierr = PetscMapInitialize(PETSC_COMM_WORLD, &map); CHKERRQ(ierr);
 ierr = PetscMapSetBlockSize(&map,n); CHKERRQ(ierr);
 ierr = PetscMapSetSize (&map, n); CHKERRQ(ierr);
 ierr = PetscMapGetLocalRange(&map,&Istart,&Iend); CHKERRQ(ierr);
The compiler error is :PetscMapSetBlockSize' : undeclared identifier.  I am sure I include "petscksp.h", so I think 2.3.2 does not support PetscMap.
BTW,  I am not clear about the block size.
Best,
Yixun
----- Original Message -----
To: <petsc-users at mcs.anl.gov>
Sent: Friday, November 03, 2006 9:26 AM
Subject: Re: how to use PetscMap?
  Yixun
   Please read the manual pages for PetscMapInitialize, PetscMapGetLocalRange,
PetscMapGetGlobalRange etc.
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Vec/PetscMapInitialize.html
I told you about PetscMapInitialize() over a week ago.
You should not need to broadcast these simple tasks to everyone; you should be
able to use the manual pages to handle this trivial stuff.
   Barry
On Fri, 3 Nov 2006, Yixun Liu wrote:
> Hi,
> For example, if N is known,  I call PetscSplitOwnership(PETSC_COMM, PETSC_DECIDE ,  &N) . However, how to get the start and end value like PetscMapGetLocalRange?
> Best,
> Yixun
> From: "Matthew Knepley" <knepley at gmail.com>
> Sent: Thursday, November 02, 2006 10:27 PM
> > http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Sys/PetscSplitOwnership.html
> >   Matt
> > On 11/2/06, Yixun Liu <yxliu at fudan.edu.cn> wrote:
> >> Hi,
> >> I want to use PetscMap to gets the range of values owned by this process, e.g.,PetscMapGetLocalRange(map,&Istart,&Iend). Then according to Istart and Iend to determine the parameters used by MatCreateMPIAIJ to create a matrix.
> >> Best,
> >> Yixun
> >> Sent: Thursday, November 02, 2006 9:56 PM
> >> > There is no replacement. What are you tring to do here?
> >> >   Matt
> >> >> Hi,
> >> >> I want to change the code, which is based on old version PETSC to version 2.3.2. The old petsc code are,
> >> >> PetscMap map;
> >> >> ierr = PetscMapCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,n,&map);CHKERRQ(ierr);
> >> >> ierr = PetscMapGetLocalRange(map,&Istart,&Iend); CHKERRQ(ierr);
> >> >> ierr = PetscMapDestroy(map); CHKERRQ(ierr);
> >> >> If 2.3.2 does not support PetscMap, which class should I use?
> >> >> Best,
> >> >> Yixun
> >> >> Sent: Thursday, November 02, 2006 9:07 PM
> >> >> > No, in 2.3.2 PetscMap no longer exists.
> >> >> >   Matt
> >> >> >> Hi,
> >> >> >> I reveive the error as,
> >> >> >> [0]PETSC ERROR:
> >> >> >> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> >> >> >> probably memory access out of range
> >> >> >> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> >> >> >> [0]PETSC ERROR: or see
> >> >> >> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC
> >> >> >> ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to
> >> >> >> find memory corruption errors
> >> >> >> [0]PETSC ERROR: likely location of problem given in stack below
> >> >> >> [0]PETSC ERROR: ---------------------  Stack Frames
> >> >> >> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> >> >> >> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> >> >> >> [0]PETSC ERROR:       is given.
> >> >> >> [0]PETSC ERROR: [0] PetscMapInitialize line 41
> >> >> >> src/vec/vec/impls/mpi/d:\MyVC\PETSC-~1.2-P\src\vec\vec\impls\mpi\pmap.c
> >> >> >> [0]PETSC ERROR: --------------------- Error Message
> >> >> >> [0]PETSC ERROR: Signal received!
> >> >> >> [0]PETSC ERROR:
> >> >> >> [0]PETSC ERROR: Petsc Release Version 2.3.2, Patch 3, Fri Sep 29 17:09:34
> >> >> >> CDT 2006 HG revision:
> >> >> >> 9215af156a9cbcdc1ec666e2b5c7934688ddc526
> >> >> >> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> >> >> >> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> >> >> >> [0]PETSC ERROR: See docs/index.html for manual pages.
> >> >> >> [0]PETSC ERROR:
> >> >> >> [0]PETSC ERROR: Unknown Name on a cygwin-cx named DMRC-6700512 by DMRC-user
> >> >> >> Thu Nov 02 16:22:47 2006
> >> >> >> [0]PETSC ERROR: Libraries linked from
> >> >> >> /cygdrive/D/MyVC/petsc-2.3.2-p3/lib/cygwin-cxx-debug
> >> >> >> [0]PETSC ERROR: Configure run at Wed Nov  1 10:08:10 2006
> >> >> >> [0]PETSC ERROR: Configure options
> >> >> >> --with-mpi-dir=/cygdrive/d/MPICH2 --with-cc="win32fe cl"
> >> >> >> --with-fc=0 --with-cxx="win32fe cl" --with-clanguage=cxx
> >> >> >> --with-blas-lapack-dir=/cygdrive/D/MyVC/petsc-2.3.2-p3/externalpackages/w_mkl_serial_p_8.1.001/mkl_serial_8.1/mkl_8.1_serial/ia32/lib
> >> >> >> COPTFLAGS="-MD -Z7" CXXOPTFLAGS="-MD -Z7" --useThreads=0 --with-shared=0
> >> >> >> [0]PETSC ERROR:
> >> >> >> [0]PETSC ERROR: User provided function() line 0 in unknown directory unknown
> >> >> >> file
> >> >> >> unable to read the cmd header on the pmi context, Undefined dynamic error
> >> >> >> code.
> >> >> >> job aborted:
> >> >> >> rank: node: exit code[: error message]
> >> >> >> 0: dmrc-6700512: 59: application called MPI_Abort(MPI_COMM_WORLD, 59) -
> >> >> >> process 0
> >> >> >> I think this error maybe caused by these codes,
> >> >> >>  PetscMap *map;
> >> >> >>  ierr = PetscMapInitialize(PETSC_COMM_WORLD, map);
> >> >> >>  CHKERRQ(ierr);
> >> >> >>  ierr = PetscMapSetSize (map, n);
> >> >> >> CHKERRQ(ierr);
> >> >> >> Is it correct to use the PetscMap like this?
> >> >> >> Best,
> >> >> >> Yixun
> >> >> > "Failure has a thousand explanations. Success doesn't need one" -- Sir
> >> >> > Alec Guiness
> >> > Alec Guiness
> > Alec Guiness
