Petsc + BlockSolve95
    Matthew Knepley
    knepley at gmail.com
    Wed May 17 06:18:11 CDT 2006
My guess is somehow you are passing the wrong integer for the option
because I am looking at the code and it is fine. However, it is easy to
clear up. Go to
  $PETSC_DIR/src/mat/impls/rowbs/mpi/mpirowbs.c:1411
and replace it with
  SETERRQ1(PETSC_ERR_SUP,"unknown option %d",op);
and then in that directory
  make
  make shared
This will tell us what integer was passed in for the option. I have already
made
this fix in the dev version.
    Matt
On 5/17/06, Boulahya Faïza <F.Boulahya at brgm.fr> wrote:
>  Ok but the error does not come from parallell ICC. It's from the
> MatSetOption().
> Moreover, when I tried with MATMPIROWBS , it's the same problem :
> [0]PETSC ERROR: MatSetOption_MPIRowbs() line 1411 in
> [0]PETSC ERROR: No support for this operation for this object type!
> [0]PETSC ERROR: unknown option!
> [0]PETSC ERROR: MatSetOption() line 4137 in src/mat/interface/matrix.c
> Faïza
> -----Message d'origine-----
> De : Satish Balay [mailto:balay at mcs.anl.gov <balay at mcs.anl.gov>]
> Envoyé : mardi 16 mai 2006 15:39
> À : 'petsc-users at mcs.anl.gov'
> Objet : RE: Petsc + BlockSolve95
> > [0]PETSC ERROR: MatSetOption_MPIAIJ() line 1251 in
> > src/mat/impls/aij/mpi/mpiaij.c [0]PETSC ERROR: No support for this
> AIJ matrix does not support parallell ICC. BlockSolve provides parallel
> ICC - and to use it one must use MatType MATMPIROWBS
> Satish
> On Tue, 16 May 2006, Boulahya Faïza wrote:
> > Is there something new about it?
> > De : Vaz, Guilherme [mailto:G.Vaz at marin.nl <G.Vaz at marin.nl>]
> > I have exactly the same problem as Faiza...
> > In sequential it runs ok but in parallel not.
> > -----Original Message-----
> > From: owner-petsc-users at mcs.anl.gov
> > [mailto:owner-petsc-users at mcs.anl.gov <owner-petsc-users at mcs.anl.gov>]
> > On Behalf Of Boulahya Faïza
> >  I tried something else :
> >     - creation of the matrix with MatCreateMPIAIJ
> >     - initialization
> >     - adding of the options MAT_SYMMETRIC and MAT_SYMMETRY_ETERNAL
> > When solving in sequential CG + ICC, everything is ok. When I tried in
> > parallel the same code the options lead to the same error :
> > Can MatSetOption be only used in sequential?
> > Faïza
> >   _____
> > De : Matthew Knepley [mailto:knepley at gmail.com <knepley at gmail.com>]
> Envoyé : mardi 9 mai
> > 2006 18:19 À : petsc-users at mcs.anl.gov Objet : Re: Petsc +
> > BlockSolve95
> > I believe there is a problem with the option that you specified. All
> > these are integers, and it is complaining that the integer does not
> > match MAT_SYMMETRIC. I will fix the error message to print the
> > offending option, but please check the code.
> >   Thanks,
> >      Matt
> > On 5/9/06, Boulahya Faïza <F.Boulahya at brgm.fr
> > <mailto:F.Boulahya at brgm.fr <F.Boulahya at brgm.fr>> >
> > wrote:
> > Hi All,
> > Has anyone used Conjugate Gradient Solver + Icomplete Cholesky
> > Preconditionner in parallel case? I tried as said in the manual : I
> > use MATMPIROWBS for the storage of the matrice. However I get this
> message :
> > PETSC ERROR: To use incomplete Cholesky
> >                         preconditioning with a MATMPIROWBS matrix you
> > must declare it to be
> >                         symmetric using the option
> > MatSetOption(A,MAT_SYMMETRIC)!
> > So I tried adding this option (even if in the namual it is written
> > that it is not required). Then I obtained this message
> > In advance thanks,
> > Faïza
> > Pensez à visiter le site BRGM sur.... http://www.brgm.fr/
> > Le contenu de cet e-mail et de ses pièces jointes est destiné à
> > l'usage exclusif du
> > (des) destinataire(s) expressément désigné(s) comme tel(s). En cas de
> > réception de cet  e-mail par erreur, le signaler à son expéditeur et
> > ne pas en divulguer le contenu.
> > L'absence de virus a été vérifié à  l'émission du message. Il convient
> > néanmoins de vérifier l'absence de corruption à sa réception.
> > The contents of this email and any attachments are confidential. They
> > are intended for the named recipient(s) only. If you have received
> > this email in error please notify the system manager or  the sender
> > immediately and do not disclose the contents to anyone or make copies.
> > eSafe scanned this email for viruses, vandals and malicious content.
> > l'usage exclusif du
> > réception de cet  e-mail par erreur, le signaler à son expéditeur et ne
> Le contenu de cet e-mail et de ses pièces jointes est destiné à l'usage exclusif du
> (des) destinataire(s) expressément désigné(s) comme tel(s). En cas de réception de cet
>  e-mail par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
> L'absence de virus a été vérifié à  l'émission du message. Il convient néanmoins de
> The contents of this email and any attachments are confidential. They are intended for
> the named recipient(s) only. If you have received this email in error please notify the
> system manager or  the sender immediately and do not disclose the contents to
> anyone or make copies. eSafe scanned this email for viruses, vandals and malicious
> content.
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060517/2d92fedd/attachment.htm>
