memory bleeding
Mon May 8 12:42:33 CDT 2006
If you don't get any output with -trdump - it could mean that all
objects are getting properly destroyed. But the swap usage is a bit
unusual.
You could try the option -trmalloc_log to see how memory is allocate
on the PETSc side. And also -log_summary to see the summary of memory
usage.
Also - is it possible you have malloc() calls in your side of the code
- that could be leaking memory?
you could also comment out all MatSetOption() calls and see if it
makes a difference.
BTW: 2.2.0 is a very old version. You might want to upgrade to the
latest 2.3.1
Satish
On Mon, 8 May 2006, Jordi Marcé Nogué wrote:
> Thanks Barry,
> I'm using petsc 2.2.0. When I run my program ( " ./myprogram -trdump " or with
> -trmalloc, -trinfo...) I don't obtain anything... in the screen the code doesn't
> print
> anything.
> If I use (for example) "./myprogram -start_on_debugger", in my screen apers gdb
> and runs good... and with another options like -log_trace petsc writes messages
> in
> my screen. Would I have to activate something in my internal petsc code?
> best regards,
> jordi
> Missatge citat per Barry Smith <bsmith at mcs.anl.gov>:
> >     See
> http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
> > number 12
> >     You can run for say a few iterations with the options
> > -malloc_debug -malloc_dump (in  PETSc 2.3.1. in early releases it had
> > different names). At PetscFinalize() PETSc will print all the memory
> > it has allocated that has not been freed and where it was allocated.
> > This can help determine what objects are not being freed.
> >     Barry
> > > Hi,
> > > I use PETSc, and after 5000 (more or less) iteations in which i solve a
> > little
> > > matrix
> > > (30x30) my swap is totally used!!! I'm sure that when I create my matrices
> > I
> > > destroy
> > > them. Could you help me about it? What happens? What thing I do bad?
> > > Mat K
> > > MatCreateSeqAIJ(PETSC_COMM_SELF, dim, dim, 9 , PETSC_NULL, &K);
> > > MatSetFromOptions(K);
> > > MatSetOption(K, MAT_SYMMETRIC);
> > > MatSetOption(K, MAT_ROW_ORIENTED);
> > > MatSetOption(K, MAT_IGNORE_ZERO_ENTRIES);
> > > MatSetOption(K, MAT_NEW_NONZERO_ALLOCATION_ERR);
> > > ( I use KSP solve, created and destroyed)
> > > MatDestroy(K);
> > > Thanks,
> > > jordi
> > > Jordi Marcé-Nogué
> > > Dept. Resistència de Materials i Estructures a l'Enginyeria
> > > Universitat Politècnica de Catalunya (UPC)
> > > Edifici T45 - despatx 137
> > > ETSEIAT (Terrassa)
> > > phone: +34 937 398 728
> > > mail: jordi.marce at upc.edu
