SNES Problem
Nils Erik Svangård
nilserik at gmail.com
Mon Mar 20 03:26:52 CST 2006
The timestep doesnt change dramaticly just before the values get
strange. The term diff from last is:
a=new_value(L)/old_value(L)+a
Diff from last=a/L
To me it seems as something petsc does supplies strange values.
The output berfore crashing:
Iterering: 667.000
H2T
Timestep: 1.000000000000000E-007
H1T
Diff from last: 0.901112485562141
AUXVR
ROMIN,ROMAX= 1.22541 1.22657
UMIN ,UMAX = -4.016098E-02 0.278343
VMIN ,VMAX = -1.853829E-03 3.289763E-02
WMIN ,WMAX = -1.852430E-03 1.855088E-03
PMIN ,PMAX = 101283. 101416.
QMIN ,QMAX = 0.815285 0.816229
EMIN ,EMAX = 4.07643 4.08175
V3
Hello CONV4
RUS: 12.2556
V4
DIFF3
F3
Iterering: 668.000
H2T
H1T
AUXVR
V3
Hello CONV4
RUS: 12.2556
V4
DIFF3
F3
Iterering: 669.000
H2T
H1T
Diff from last: 1.785767662774350E-006
AUXVR
Petsc Release Version 2.3.0, Patch 32, April, 26, 2005
See docs/changes/index.html for recent updates.
See docs/faq.html for hints about trouble shooting.
See docs/index.html for manual pages.
./withrk on a linux-gnu named sethnx004.vac.com by yy26539 Mon Mar 20
10:17:33 2006
Libraries linked from /home/yy26539/work/NISSE/petsc-2.3.0/lib/linux-gnu
Configure run at Thu Oct 13 08:23:56 2005
Configure options --with-cc=gcc --with-fc="f77 -N109"
--download-mpich=1 --download-mpich-pm=gforker
--download-f-blas-lapack=1 --with-shared=0
[0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
Exception,probably divide by zero
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------- Stack Frames ---------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] SNESComputeFunction line 788 src/snes/interface/snes.c
[0]PETSC ERROR: [0] MatMult_MFFD line 235 src/snes/mf/snesmfj.c
[0]PETSC ERROR: [0] MatMult line 1368 src/mat/interface/matrix.c
[0]PETSC ERROR: [0] SNESLSCheckLocalMin_Private line 19 src/snes/impls/ls/ls.c
[0]PETSC ERROR: [0] SNESSolve line 1656 src/snes/interface/snes.c
[0]PETSC ERROR: --------------------------------------------
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR: !
aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
/nisse
On 3/18/06, Nils Erik Svangård <nilserik at gmail.com> wrote:
> On 3/18/06, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > So you are saying that TS is feeding "reasonable" input
> > for a while? That basically matches (in scale) the values feed in
> > from the old rk code? Then SUDDENLY? it inputs values with a very
> > different size?
> Yes.
> > Does the TS time-step size? also change dramatically at
> > that point?
> No, I dont think so. However I'm not 100% sure what the timestep
> hasent changed dramatically for the last iteration when it crashes
> (but 95% sure). I can check that on monday.
> /nisse
> > Barry
> > On Sat, 18 Mar 2006, Nils Erik Svangård wrote:
> > > On 3/17/06, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >> Based on my understanding. This is correct.
> > > I was almost hoping I had missed something fundamental.
> > >> Suggest you run a TINY problem with your "old" code
> > >> and the TS (and or SNES one). Print out everything. The
> > >> current solution the result from calling Get_DRO() and
> > >> compare the runs, when and why do they change? This will
> > >> help understand what is going on.
> > > Well, Get_DRO() is exactly the same in the old and new code, and they
> > > start with the same initial values. Get_DRO() is not producing strange
> > > values, it is crashing because it get strange values fed into it.
> > > A normal run for the formfunction f(in,out) in TS would look something
> > > like this if printed:
> > > in=25560 <- Start value
> > > out=0.0001 <- du/dt
> > > in=25560 <- Value fed into formfunction after some TS magic
> > > out=0.0001 <- du/dt
> > > ... <- (a couple iterations)
> > > in=25451 <- Input value after a couple of iterations
> > > out=0.0001 <- du/dt
> > > in=0.23151 <- Value fed into formfunction decided by TS
> > > Petscerror divide by zero...
> > > The problem seems to be that TS decides that the input values to
> > > formfunction should be (in this case) 0.23151 which makes Get_DRO()
> > > crash because of for example sqrt(in-1).
> > > I have no idea how to fix this. The values from Get_DRO() in TS match
> > > the values when running the old rk code.
> > > /nisse
> > >> Barry
> > >> On Fri, 17 Mar 2006, Nils Erik Svangård wrote:
> > >>> Ok, I managed to compile and link rk.c to my fortran program, I forgot
> > >>> that in C you need a ; in the end of every statement. (stupid mistake
> > >>> I have just added one line to see if it works.
> > >>> /* computing new dt */
> > >>> dt = dt * dt_fac;
> > >>> /* Start Nisse stuff */
> > >>> ierr = PetscPrintf(PETSC_COMM_WORLD,"Nisse prints dt: %f\n",dt);
> > >>> /* End nisse stuff */
> > >>> if(ts->ptime+dt > ts->max_time){
> > >>> dt = ts->max_time - ts->ptime;
> > >>> I just try to print the current timestep, however this is never
> > >>> printed. And I'm not really sure that it is the timestep that is
> > >>> causing the problems.
> > >>> I have used call TSGetTimeStep(ts,timestep,ierr) to monitor what
> > >>> timestep TS uses and it seem ok. However after the first iteration of
> > >>> FormFunction everything seems ok, but in start of the second iteration
> > >>> all values are really strange.
> > >>> I see the same thing when using SNES and my back euler implementation,
> > >>> it iterate many more times however, but all of a sudden the all "in"
> > >>> values are in the range 0.2-0.7 (for all 7 equations) and my code
> > >>> bombs because of the strange values.
> > >>> When using TS and running with -snes_mf -ts_type beuler -ksp_rtol
> > >>> 1.e-10 this is what printed just before producing strange values:
> > >>> KSP Object:
> > >>> type: gmres
> > >>> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> > >>> Orthogonalization with no iterative refinement
> > >>> GMRES: happy breakdown tolerance 1e-30
> > >>> maximum iterations=10000, initial guess is zero
> > >>> tolerances: relative=1e-10, absolute=1e-50, divergence=10000
> > >>> left preconditioning
> > >>> PC Object:
> > >>> type: none
> > >>> linear system matrix = precond matrix:
> > >>> Matrix Object:
> > >>> type=mffd, rows=70000, cols=70000
> > >>> SNES matrix-free approximation:
> > >>> err=1e-07 (relative error in function evaluation)
> > >>> Using wp compute h routine
> > >>> Computes normA
> > >>> And just to make sure that I havent misunderstood how SNES and TS work:
> > >>> If the original 3-stage RK uses (my numbering):
> > >>> 1. RO0(L)=RO(L)
> > >>> Get_DRO(RO(L))
> > >>> RO(L)=RO0(L)+CFL*DRO(L)
> > >>> 2. RO0(L)=.5*(RO0(L)+RO(L))
> > >>> Get_DRO(RO(L))
> > >>> RO(L)=RO0(L)+.5*CFL*DRO(L)
> > >>> 3. Get_DRO(RO(L))
> > >>> Then this should be in TS which should return du/dt which is DRO:
> > >>> RO(L)=xx(1,L)
> > >>> Get_DRO(RO(L))
> > >>> ff(1,L) = DRO(L)
> > >>> And in SNES with back euler:
> > >>> (Old RO from previous iteration ORO(L)
> > >>> RO(L)=xx(1,L)
> > >>> Get_DRO(RO(L))
> > >>> ff(1,L)= RO(L)-OLD(1,L)-TSF(L)*DRO(L)
> > >>> This became a long mail, I hope this shows if I missed something vital.
> > >>> /nisse
> > >>> On 3/16/06, Nils Erik Svangård <nilserik at gmail.com> wrote:
> > >>>> Barry,
> > >>>> the problem is making the objectfile, but I'll try again when I have
> > >>>> the code. I will check the makefile for the c-examples.
> > >>>> /nisse
> > >>>> On 3/16/06, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >>>>> Nisse,
> > >>>>> Just list it in your makefile with all your other object
> > >>>>> files (that come from Fortran). Send the output if this fails.
> > >>>>> Barry
> > >>>>> On Thu, 16 Mar 2006, Nils Erik Svangård wrote:
> > >>>>>> I havent managed to get rk.c compiled with changes. how do I compile
> > >>>>>> it in my working directory to get a object file. I just realised that
> > >>>>>> I probably forgot to link it against $TSLIB but should I need to that
> > >>>>>> when I dont do any linking, the linking is done when linking the
> > >>>>>> fortran and the c code?
> > >>>>>> Or what am I doing wrong (I not that good with C++ and linking).
> > >>>>>> /nisse
> > >>>>>> On 3/15/06, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >>>>>>> Both
> > >>>>>>> On Wed, 15 Mar 2006, Nils Erik Svangård wrote:
> > >>>>>>>>> Sorry, I forgot. Is the linear solver converging? If not, then that
> > >>>>>>>>> is the problem? Use a tolerance like -ksp_rtol 1.e-10 and see if the
> > >>>>>>>>> nonlinear solver converges.
> > >>>>>>>> I'll try that when I have access to the code. I havent checked if the
> > >>>>>>>> linear solver converges is thera a -kspmonitor or -kspconvergedreason
> > >>>>>>>> I should use?
> > >>>>>>>> /nisse
> > >>>>>> Nils-Erik Svangård
> > >>>>>> E-Mail: nilserik at gmail.com
> > >>>>>> MSN: schweingaard at hotmail.com
> > >>>>>> Skype: schweingaard
> > >>>>>> Mobil: +46-(0)70-3612178
> > >>>> Nils-Erik Svangård
> > >>>> Skype: schweingaard
> > >>> Nils-Erik Svangård
> > >>> Skype: schweingaard
> > > Nils-Erik Svangård
> > > Skype: schweingaard
> Nils-Erik Svangård
> Skype: schweingaard
Nils-Erik Svangård
Skype: schweingaard
