SNES Problem
Wed Mar 15 07:14:25 CST 2006
On Wed, 15 Mar 2006, Nils Erik Svangård wrote:
>>    Just get a copy of rk.c and link it in with your code; you don't have
>> to muck with the actual file that goes into the PETSc library.
> Ok.
>>> In the back-euler implementation, I think I just have to add one line
>>> to get the stability checking of the timestep working.
>>    If it is one line for backward Euler, why isn't one line for RK?
>> You can simply call the code in fortran that computes the time-step,
>> can't you then use MPI_Allreduce to get the min over all processors.
> It is one line to add in the SNES implementation because there I set
> timestep for each iteration. The RK is used via TS which manage the
> timestep, and I am not sure how to manage the timestep myself in when
> using TS,
   I see. Yes, it is a little harder since you have to edit rk.c
but it is still pretty easy.
>>    Here is the issue: the ONLY reason to use an implicit method is to
>> increase the timestep which you cannot do with the explicit code due
>> to stability constraints. But if you use the same time-step with the
>> implicit code as with the explicit code you gain nothing over using
>> the explicit code (in fact you do worse because the implicit code
>> is more expensive per timestep).
> So using the old timestep control function might make the code to work
> but probably will reach the solution much slower. So if this work, I
> probably have to rewrite the stability check to fit the implicit
> timestepping?
    Yes.
   Barry
> /nisse
>>     Barry
>>> /nisse
>>>>     Barry
>>>> On Tue, 14 Mar 2006, Nils Erik Svangård wrote:
>>>>>>> Yes, there is a difference between the old 3-stage RK-solver and the
>>>>>>> SNESsolver using RK. In the old a timestep was calculatade for each
>>>>>>      Are you using PETSc's explicit RK? If so that does not use SNES.
>>>>> Sorry, I meant TS.
>>>>>>> cell based on a stability criteria and if chosen it could run in
>>>>>>> time-accurate mode eg. the timestep is the same for each cell, in SNES
>>>>>>    Do you mean for backward Euler for the explicit RK? Or both?
>>>>> Sorry again, using TS I use the same size of the timestep on every
>>>>> cell (both when trying use back-euler and RK).
>>>>> In my old 3-stage RK I can use both variable timestep and
>>>>> time-accurate timestep.
>>>>> In my seperate back-euler implementation using SNES I use the same
>>>>> timestep on every cell.
>>>>>>> I use a timestep that is the same for all cells and
>>>>>>> changes only if it returns non-physical answers or the solution diverges.
>>>>>>     I think you need to put the "proper" computation of the time-step
>>>>>> based on the stability criteria that you have in the "old" code.
>>>>>> Unfortunately this is currently hardwired in src/ts/impls/explicit/rk/rk.c
>>>>>> (search for "Computing next stepsize"). I think you need to use the minimum
>>>>>> of the timestep computed here and what is needed for the "stability criteria".
>>>>> Hmm.. Ok so I could use my back-euler SNES implementation with my old
>>>>> timestep calculation function (using time-accurate timestep)? And it
>>>>> might work better.
>>>>> Thanks
>>>>> /nisse
>>>>>>> Another interesting observation is that when using back euler at the
>>>>>>> moment when it bugs out petsc has assigned neigboring cells pressure
>>>>>>> values that differs about 1 ATM, which is a very non physical value,
>>>>>>    Likely some stability problem.
>>>>>>     Barry
>>>>>>> but I have no clue as to why petsc want such a value  in thesolution.
>>>>>>> /nisse
>>>>>>> On 3/3/06, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>>>>    There must be a difference between the two RKs. The initial
>>>>>>>> timestep it uses, or algorithm for changing time step or slight
>>>>>>>> difference in algorithms?
>>>>>>>>     Barry
>>>>>>>> On Fri, 3 Mar 2006, Nils Erik Svangård wrote:
>>>>>>>>> A interesting thing is when I change TS_BEULER to TS_RUNGE_KUTTA the
>>>>>>>>> solver exits fast due to the non physical values. My original solver
>>>>>>>>> is a 3-step Runge-Kutta which works flawlessly.
>>>>>>>>> The error when running RK:
>>>>>>>>> ./ImplicitG3D on a linux-gnu named sethnx004.vac.com by yy26539 Fri
>>>>>>>>> Mar  3 10:31:27 2006
>>>>>>>>> Libraries linked from /home/yy26539/work/NISSE/petsc-2.3.0/lib/linux-gnu
>>>>>>>>> Configure run at Thu Oct 13 08:23:56 2005
>>>>>>>>> Configure options --with-cc=gcc --with-fc="f77 -N109"
>>>>>>>>> --download-mpich=1 --download-mpich-pm=gforker
>>>>>>>>> --download-f-blas-lapack=1 --with-shared=0
>>>>>>>>> [0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
>>>>>>>>> Exception,probably divide by zero
>>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>>>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>>>>>>> [0]PETSC ERROR: --------------- Stack Frames ---------------
>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>>>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>>>>>> [0]PETSC ERROR:       is given.
>>>>>>>>> [0]PETSC ERROR: [0] TS user right-hand-side function line 0 unknownunknown
>>>>>>>>> [0]PETSC ERROR: [0] TSComputeRHSFunction line 282 src/ts/interface/ts.c
>>>>>>>>> [0]PETSC ERROR: [0] TSRkqs line 256 src/ts/impls/explicit/rk/rk.c
>>>>>>>>> [0]PETSC ERROR: [0] TSStep_Rk line 322 src/ts/impls/explicit/rk/rk.c
>>>>>>>>> [0]PETSC ERROR: [0] TSStep line 1520 src/ts/interface/ts.c
>>>>>>>>> [0]PETSC ERROR: --------------------------------------------
>>>>>>>>> [0]PETSC ERROR: User provided function() line 0 in unknown directory
>>>>>>>>> unknown file
>>>>>>>>> [0]PETSC ERROR: Signal received!
>>>>>>>>> [0]PETSC ERROR:  !
>>>>>>>>> aborting job:
>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>>>>>>> On 3/3/06, Nils Erik Svangård <nilserik at gmail.com> wrote:
>>>>>>>>>> Hello again,
>>>>>>>>>>>    Is it just not compiling because  PETSC_ERR_ARG_DOMAIN is not
>>>>>>>>>>> defined? Or does it still not work even when you have put the number in?
>>>>>>>>>>> What is the error? Or did you get it all working with SNES?
>>>>>>>>>> It is not compiling because PETSC_ERR_ARG_DOMAIN is not defined:
>>>>>>>>>> error on line 585 of SNESG3D2.F: data type is undefined for variable
>>>>>>>>>> I tried putting a number in, then it compiles but complains while
>>>>>>>>>> linking that the Push() and Pop() functions is not defined. I made a
>>>>>>>>>> workaround by adding a variable in a common block and setting it
>>>>>>>>>> before returning from a non physical value in the FormFunction. Now I
>>>>>>>>>> can compile and when there is a non-physical value it returns and
>>>>>>>>>> resumes with a smaller timestep.
>>>>>>>>>> SNES still give non physical values which are hard to add checks for
>>>>>>>>>> in the program (e.g sqrt(RO(L)-RO(L+1))).
>>>>>>>>>> Did I understand correctly that SNES does a linesearch and probably
>>>>>>>>>> goes for a solution which isnt the one I looking for? Does SNES use
>>>>>>>>>> the linesearch algorithm when I use -snes_mf (which I use)?
>>>>>>>>>>>    It may work automatically with TS; you would just set TS with a
>>>>>>>>>>> smaller timestep and call TSSolve again?
>>>>>>>>>> OK, I'll add a check and put TSSolve in a while loop.
>>>>>>>>>> My SNESSolve loop looks like this right now:
>>>>>>>>>>       call VecCreateSeq(PETSC_COMM_SELF,N,x,ierr)
>>>>>>>>>>       call VecDuplicate(x,r,ierr)
>>>>>>>>>>       call VecDuplicate(x,xb,ierr)
>>>>>>>>>>       call SNESCreate(PETSC_COMM_SELF,snes,ierr)
>>>>>>>>>>       call SNESSetFunction(snes,r,FormFunction,PETSC_NULL_OBJECT,ierr)
>>>>>>>>>>       call SNESSetFromOptions(snes,ierr)
>>>>>>>>>>       call FormInitialGuess(x,ierr)
>>>>>>>>>>       call VecCopy(x,xb,ierr)
>>>>>>>>>>       write(6,*)zero,dt,tmax,i1000
>>>>>>>>>>       step=0
>>>>>>>>>>       timestep=dt
>>>>>>>>>>       bang=0
>>>>>>>>>> C While loop
>>>>>>>>>>    10 if (step .le. 100) then
>>>>>>>>>> C        call PetscExceptionPush(87,ierr)
>>>>>>>>>> C         call PetscExceptionPush(PETSC_ERR_ARG_DOMAIN,ierr)
>>>>>>>>>>         call SNESSolve(snes,PETSC_NULL_OBJECT,x,ierr)
>>>>>>>>>>         ierr=bang
>>>>>>>>>> C        call PetscExceptionPop(87,ierr2)
>>>>>>>>>>          IF ( ierr .EQ. 87) THEN
>>>>>>>>>>            timestep=timestep/2
>>>>>>>>>>            call VecCopy(xb,x,ierr)
>>>>>>>>>>            write(6,*) "No physical solution, trying",
>>>>>>>>>>      .                " with smaller timestep: ",timestep
>>>>>>>>>>            bang=0
>>>>>>>>>>          ELSE
>>>>>>>>>>           call SNESGetConvergedReason(snes,reason,ierr)
>>>>>>>>>>           IF ( reason .LT. 0 ) THEN
>>>>>>>>>>             timestep=timestep/2
>>>>>>>>>>             write(6,*)"Solution diverged, trying with",
>>>>>>>>>>      .                " smaller timestep: ",timestep
>>>>>>>>>>           ELSE
>>>>>>>>>>             timestep=dt
>>>>>>>>>>             step=step+1
>>>>>>>>>>             write(6,*) "Solve success, going for step: ",step
>>>>>>>>>>             write(6,*) "Reason: ",reason," ierr: ",ierr
>>>>>>>>>>             reason=0
>>>>>>>>>>             ierr=0
>>>>>>>>>>           ENDIF
>>>>>>>>>>         ENDIF
>>>>>>>>>>        goto 10
>>>>>>>>>>       endif
>>>>>>>>>> C End While loop
>>>>>>>>>> And the check in the FormFunction:
>>>>>>>>>>               if (ET(L) .LT. 0) then
>>>>>>>>>>                 ierr = 87
>>>>>>>>>>                 bang = 87
>>>>>>>>>> C                SETERRQ(87,"Non physical value!",ierr)
>>>>>>>>>>                 return
>>>>>>>>>>               elseif ( RO(L) .LT. 0 ) then
>>>>>>>>>>                 ierr = 87
>>>>>>>>>>                 bang = 87
>>>>>>>>>>                 return
>>>>>>>>>>               endif
>>>>>>>>>> /nisse
>>>>>>>>>>>    Barry
>>>>>>>>>>>    I'm adding a petscerror.h for Fortran that includes these values
>>>>>>>>>>> Sorry I forgot we hadn't given them for Fortran.
>>>>>>>>>>> On Thu, 2 Mar 2006, Nils Erik Svangård wrote:
>>>>>>>>>>>> Hi again,
>>>>>>>>>>>> I realised that my implementation was a bit flawed so I have rewritten
>>>>>>>>>>>> it again, the push and pop() functions dont seem to work, and they are
>>>>>>>>>>>> keeping me from compiling the program, this is the main timestep loop:
>>>>>>>>>>>>      step=0
>>>>>>>>>>>>      timestep=dt
>>>>>>>>>>>> C While loop
>>>>>>>>>>>>           timestep=timestep/2
>>>>>>>>>>>>           VecCopy(xb,x,ierr)
>>>>>>>>>>>>        ELSE
>>>>>>>>>>>>           timestep=timestep/2
>>>>>>>>>>>>           VecCopy(xb,x,ierr)
>>>>>>>>>>>>         ELSE
>>>>>>>>>>>>           timestep=dt
>>>>>>>>>>>>           step=step+1
>>>>>>>>>>>>           VecCopy(x,xb,ierr)
>>>>>>>>>>>>         ENDIF
>>>>>>>>>>>>        ENDIF
>>>>>>>>>>>>       goto 10
>>>>>>>>>>>>      endif
>>>>>>>>>>>> C End While loop
>>>>>>>>>>>> And in my Formfunction I have added the following check:
>>>>>>>>>>>>                ierr = 87
>>>>>>>>>>>>                return
>>>>>>>>>>>>              endif
>>>>>>>>>>>> PETSC_ERR_ARG_DOMAIN didnt work:  error on line 6500 of SNESG3D2.F:
>>>>>>>>>>>> data type is undefined for variable PETSC_ERR_ARG_DOMAIN
>>>>>>>>>>>> Even thought I had petsc.h included.
>>>>>>>>>>>> Can I do this check when I use TS also? I have the sameproblem with
>>>>>>>>>>>> the values being negative when using TS.
>>>>>>>>>>>> /nisse
>>>>>>>>>>>> On 2/27/06, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>>>>>>>>>    SNES works by computing p = -approxinv(J)*F(uold) and
>>>>>>>>>>>>> then does a line search on unew = uold + lambda*p to get the
>>>>>>>>>>>>> new u. First it uses a test value of 1 for lambda so it
>>>>>>>>>>>>> tries to compute F(uold + p). It is possible that uold + p
>>>>>>>>>>>>> has some "non-physical" values in it.  There are two ways
>>>>>>>>>>>>> you can try handling it:
>>>>>>>>>>>>> 1) Before doing the linesearch SNES calls a "precheck" function,
>>>>>>>>>>>>> that can change the step if it decides there is a problem
>>>>>>>>>>>>> with the step (like it is too long). You can provide your
>>>>>>>>>>>>> own precheck function with SNESLineSearchSetPreCheck() it could,
>>>>>>>>>>>>> for example, shrink the Newton direction to make it remain physical.
>>>>>>>>>>>>> or 2) when your form function detects an illegal value it calls
>>>>>>>>>>>>> SETERRQ(PETSC_ERR_ARG_DOMAIN,"Nonphysical function input"); Note:
>>>>>>>>>>>>> this is before it takes the square root of the negative number,
>>>>>>>>>>>>> so check the number and call the error before calling SETERRQ().
>>>>>>>>>>>>> (If using Fortran then simply set ierr = PETSC_ERR_ARG_DOMAIN and
>>>>>>>>>>>>> then immediately return). Then replace your call to SNESSolve with
>>>>>>>>>>>>>    ierr = PetscExceptionTry1(SNESSolve(snes,b,x),PETSC_ERR_ARG_DOMAIN);
>>>>>>>>>>>>>    if (PetscExceptionCaught(ierr,PETSC_ERR_ARG_DOMAIN)) {
>>>>>>>>>>>>>      /* this means your function found a non-physical value so
>>>>>>>>>>>>>         cut your time-step and continue through the loop again. */
>>>>>>>>>>>>>         Put code to do this here.
>>>>>>>>>>>>> If using fortran then do
>>>>>>>>>>>>> call SNESSolve(snes,b,x,ierr)
>>>>>>>>>>>>> call PetscExceptionPop(PETSC_ERR_ARG_DOMAIN,anotherierr)
>>>>>>>>>>>>> if (ierr == PETSC_ERR_ARG_DOMAIN) then
>>>>>>>>>>>>>    non-physical value so cut the time-step and try again
>>>>>>>>>>>>> else ! everything is normal so take the next time-step
>>>>>>>>>>>>>    Barry
>>>>>>>>>>>>> The Fortran interface may be missing PetscExceptionPush() and Pop()
>>>>>>>>>>>>> if so let us know and we'll provide the patch.
>>>>>>>>>>>>> On Mon, 27 Feb 2006, Nils Erik Svangård wrote:
>>>>>>>>>>>>>> Hi all,
>>>>>>>>>>>>>> I have problems solving some CFD problems using SNES and my custom
>>>>>>>>>>>>>> back-euler. I have 7 equations that I want to solve.
>>>>>>>>>>>>>> First my FormFunction copies the values from the Vec that SNES uses to
>>>>>>>>>>>>>> the variables that my code use:
>>>>>>>>>>>>>>      RO(L)=xx(1,L)
>>>>>>>>>>>>>>      RU(L)=xx(2,L)
>>>>>>>>>>>>>>      RV(L)=xx(3,L)
>>>>>>>>>>>>>>      RW(L)=xx(4,L)
>>>>>>>>>>>>>>      ET(L)=xx(5,L)
>>>>>>>>>>>>>>      RQ(L)= xx(6,L)
>>>>>>>>>>>>>>      REPS(L)=xx(7,L)
>>>>>>>>>>>>>> Here I also print the values of ET(2) for debugging:
>>>>>>>>>>>>>>      write(6,*)"ET(2) = xx(5,2) : ",ET(2)," = ",xx(5,2)
>>>>>>>>>>>>>> Then I get the fluxes by calling custom functions
>>>>>>>>>>>>>>      call AUXVR
>>>>>>>>>>>>>>      call VGRAD
>>>>>>>>>>>>>>      call FLUX
>>>>>>>>>>>>>>      call KESRC
>>>>>>>>>>>>>> Then I perform back-euler  save the new value to so that I can use it
>>>>>>>>>>>>>> in the next iterationi (TSF(L) is Time step function, which is set by
>>>>>>>>>>>>>> hand and is the same for all L):
>>>>>>>>>>>>>>      ff(1,L) = RO(L)-OLD(1,L)-TSF(L)*DRO(L)
>>>>>>>>>>>>>>      ff(2,L) = RU(L)-OLD(2,L)-TSF(L)*DRU(L)
>>>>>>>>>>>>>>      ff(3,L) = RV(L)-OLD(3,L)-TSF(L)*DRV(L)
>>>>>>>>>>>>>>      ff(4,L) = RW(L)-OLD(4,L)-TSF(L)*DRW(L)
>>>>>>>>>>>>>>      ff(5,L) = ET(L)-OLD(5,L)-TSF(L)*DET(L)
>>>>>>>>>>>>>>      ff(6,L) = RQ(L)-OLD(6,L)-TSF(L)*DRQ(L)
>>>>>>>>>>>>>>      ff(7,L) = REPS(L)-OLD(7,L)-TSF(L)*DREPS(L)
>>>>>>>>>>>>>> And save the new value of RO-REPS to use in the next iteration of back-euler:
>>>>>>>>>>>>>>      OLD(1,L)=RO(L)
>>>>>>>>>>>>>>      OLD(2,L)=RU(L)
>>>>>>>>>>>>>>      OLD(3,L)=RV(L)
>>>>>>>>>>>>>>      OLD(4,L)=RW(L)
>>>>>>>>>>>>>>      OLD(5,L)=ET(L)
>>>>>>>>>>>>>>      OLD(6,L)=RQ(L)
>>>>>>>>>>>>>>      OLD(7,L)=REPS(L)
>>>>>>>>>>>>>> Here I print the values of L=2 as above for debugging:
>>>>>>>>>>>>>>      write(6,*)ff(5,2)," = ",ET(2),"-",OLD(5,2),"-",TSF(2),"*",DET(2)
>>>>>>>>>>>>>> The program exit abnormaly after 33 runs of the FormFunction. The
>>>>>>>>>>>>>> cause of this is that AUXVR tries to perform sqrt(ET(2)) when ET(2) is
>>>>>>>>>>>>>> negative, ET is the total energy and should never be negative. It
>>>>>>>>>>>>>> seems that all of a sudden the PETSc SNES solver decides to supply the
>>>>>>>>>>>>>> FormFunction with a negative ET value. I need help understanding why
>>>>>>>>>>>>>> and how to fix it (if it is fixable).
>>>>>>>>>>>>>> Here is the output of:
>>>>>>>>>>>>>> Which is in the beginning of my FormFunction.
>>>>>>>>>>>>>> And:
>>>>>>>>>>>>>> Which is in the end of my Formfunction.
>>>>>>>>>>>>>> 1. ET(2) = xx(5,2) :   253250.  =   253250.000000000
>>>>>>>>>>>>>>   ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4126563437192  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.941266E+08
>>>>>>>>>>>>>> 2. ET(2) = xx(5,2) :   253250.  =   253250.000010259
>>>>>>>>>>>>>> 3. ET(2) = xx(5,2) :   253250.  =   253249.999999988
>>>>>>>>>>>>>>   ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4132419437260  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.941324E+08
>>>>>>>>>>>>>> 4. ET(2) = xx(5,2) :   253250.  =   253250.000048432
>>>>>>>>>>>>>> 5. ET(2) = xx(5,2) :   253250.  =   253249.999999872
>>>>>>>>>>>>>>   ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4177283437784  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.941773E+08
>>>>>>>>>>>>>> 6. ET(2) = xx(5,2) :   253250.  =   253250.000071113
>>>>>>>>>>>>>> 7. ET(2) = xx(5,2) :   253250.  =   253249.999980115
>>>>>>>>>>>>>>   ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4453347441010  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.944533E+08
>>>>>>>>>>>>>> 8. ET(2) = xx(5,2) :   253250.  =   253250.000037298
>>>>>>>>>>>>>>   ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4082723436679  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.940827E+08
>>>>>>>>>>>>>> 9. ET(2) = xx(5,2) :   253250.  =   253249.999942706
>>>>>>>>>>>>>> 10. ET(2) = xx(5,2) :   253250.  =   253249.999948703
>>>>>>>>>>>>>> 11. ET(2) = xx(5,2) :   253250.  =   253250.000007808
>>>>>>>>>>>>>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.7283811474088  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.972838E+08
>>>>>>>>>>>>>> 12. ET(2) = xx(5,2) :   253250.  =   253250.000018146
>>>>>>>>>>>>>> 13. ET(2) = xx(5,2) :   253250.  =   253250.000001865
>>>>>>>>>>>>>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   28.3742819315846  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.837428E+08
>>>>>>>>>>>>>> 14. ET(2) = xx(5,2) :   253250.  =   253249.999997296
>>>>>>>>>>>>>> 15. ET(2) = xx(5,2) :   253250.  =   253250.000000049
>>>>>>>>>>>>>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   30.6548963582361  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -3.065490E+08
>>>>>>>>>>>>>> 16. ET(2) = xx(5,2) :   253250.  =   253250.000022870
>>>>>>>>>>>>>> 17. ET(2) = xx(5,2) :   253250.  =   253249.999999716
>>>>>>>>>>>>>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.5326051451209  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.953260E+08
>>>>>>>>>>>>>> 18. ET(2) = xx(5,2) :   253250.  =   253250.000074328
>>>>>>>>>>>>>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4165187437643  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.941652E+08
>>>>>>>>>>>>>> 19. ET(2) = xx(5,2) :   253250.  =   253250.000049809
>>>>>>>>>>>>>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4085059436707  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.940851E+08
>>>>>>>>>>>>>> 20. ET(2) = xx(5,2) :   253250.  =   253250.000019253
>>>>>>>>>>>>>> 21. ET(2) = xx(5,2) :   253250.  =   253250.000000189
>>>>>>>>>>>>>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.8851075492403  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.988511E+08
>>>>>>>>>>>>>> 22. ET(2) = xx(5,2) :   253250.  =   253249.999997897
>>>>>>>>>>>>>> 23. ET(2) = xx(5,2) :   253250.  =   253249.999975142
>>>>>>>>>>>>>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.3961539435263  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.939615E+08
>>>>>>>>>>>>>> 24. ET(2) = xx(5,2) :   253250.  =   253250.000018324
>>>>>>>>>>>>>> 25. ET(2) = xx(5,2) :   253250.  =   253249.999987073
>>>>>>>>>>>>>> 26. ET(2) = xx(5,2) :   253250.  =   253249.999980982
>>>>>>>>>>>>>> 27. ET(2) = xx(5,2) :   253250.  =   253249.999994645
>>>>>>>>>>>>>> 28. ET(2) = xx(5,2) :   253250.  =   253249.999962364
>>>>>>>>>>>>>> 29. ET(2) = xx(5,2) :   253250.  =   253249.999999921
>>>>>>>>>>>>>> 30. ET(2) = xx(5,2) :   253250.  =   253250.000000058
>>>>>>>>>>>>>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   28.4019971319085  =
>>>>>>>>>>>>>> 253250. -  253250.000000000 -  1.000000E-07 * -2.840200E+08
>>>>>>>>>>>>>> 31. ET(2) = xx(5,2) :   253250.  =   253250.000040348
>>>>>>>>>>>>>> 32. ET(2) = xx(5,2) :   253250.  =   253250.000005245
>>>>>>>>>>>>>> 33. ET(2) = xx(5,2) :   253250.  =   253250.000005245
>>>>>>>>>>>>>> 34. ET(2) = xx(5,2) :  -848141.  =  -848141.388090847
>>>>>>>>>>>>>> Petsc Release Version 2.3.0, Patch 32, April, 26, 2005
>>>>>>>>>>>>>> See docs/changes/index.html for recent updates.
>>>>>>>>>>>>>> See docs/faq.html for hints about trouble shooting.
>>>>>>>>>>>>>> See docs/index.html for manual pages.
>>>>>>>>>>>>>> ./SNESG3D2 on a linux-gnu named sethnx004.vac.com by yy26539 Mon Feb
>>>>>>>>>>>>>> 27 14:21:13 2006
>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNES user function line 0 unknownunknown
>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeFunction line 788 src/snes/interface/snes.c
>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESLineSearchCubic line 514 src/snes/impls/ls/ls.c
>>>>>>>>>>>>>> unknown file
>>>>>>>>>>>>>> [0]PETSC ERROR:  !
>>>>>>>>>>>>>> Suggestions and tips are very welcome!
>>>>>>>>>>>>>> /nisse
>>>>>>>>>>>>>> Nils-Erik Svang�rd
>>>>>>>>>>>>>> MSN: schweingaard at hotmail.com
>>>>>>>>>>>>>> Skype: schweingaard
>>>>>>>>>>>> Nils-Erik Svangård
>>>>>>>>>>>> Skype: schweingaard
>>>>>>>>>> Nils-Erik Svangård
>>>>>>>>>> E-Mail: nilserik at gmail.com
>>>>>>>>>> Skype: schweingaard
>>>>>>>>>> Mobil: +46-(0)70-3612178
>>>>>>>>> Nils-Erik Svangård
>>>>>>>>> Skype: schweingaard
>>>>>>> Nils-Erik Svangård
>>>>>>> Skype: schweingaard
>>>>> Nils-Erik Svangård
>>>>> Skype: schweingaard
>>> Nils-Erik Svangård
>>> Skype: schweingaard
> Nils-Erik Svangård
> Skype: schweingaard
