SNES Problem
Nils Erik Svangård
nilserik at gmail.com
Tue Mar 14 14:37:27 CST 2006
On 3/14/06, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Hmm.. Ok so I could use my back-euler SNES implementation with my old
> > timestep calculation function (using time-accurate timestep)? And it
> > might work better.
> Nisse,
> First I'd like to see the PETSc rk code behaving pretty much the
> same as your RK (then move onto the implicit code). Do I understand
> that the PETSc rk code goes "non-physical" while your RK does not?
Yes
> If so, I was suggesting putting in YOUR timestep control into the
> PETSc rk (I listed the file below). Once the PETSc rk behaves like
> your rk we can move onto the implicit code. Reason: I want to confirm
> that the basic "translation" to PETSc is working, before dealing
> with the implicitness (which introduces its own difficulties).
I understand your suggestion, however I'm a bit unsure how to do that.
The timestep control function used in the old code (written in
Fortran) compares values from neigboring cells computing a value that
is scaled to proper size (which is then used as a timestep). The
time-accurate version of this uses the same algorithm but uses the
min() of all timesteps as timestep for all cells. I also dont have
access to the source code from this computer :-/
In the back-euler implementation, I think I just have to add one line
to get the stability checking of the timestep working.
/nisse
> Barry
> On Tue, 14 Mar 2006, Nils Erik Svangård wrote:
> >>> Yes, there is a difference between the old 3-stage RK-solver and the
> >>> SNESsolver using RK. In the old a timestep was calculatade for each
> >> Are you using PETSc's explicit RK? If so that does not use SNES.
> > Sorry, I meant TS.
> >>> cell based on a stability criteria and if chosen it could run in
> >>> time-accurate mode eg. the timestep is the same for each cell, in SNES
> >> Do you mean for backward Euler for the explicit RK? Or both?
> > Sorry again, using TS I use the same size of the timestep on every
> > cell (both when trying use back-euler and RK).
> > In my old 3-stage RK I can use both variable timestep and
> > time-accurate timestep.
> > In my seperate back-euler implementation using SNES I use the same
> > timestep on every cell.
> >>> I use a timestep that is the same for all cells and
> >>> changes only if it returns non-physical answers or the solution diverges.
> >> I think you need to put the "proper" computation of the time-step
> >> based on the stability criteria that you have in the "old" code.
> >> Unfortunately this is currently hardwired in src/ts/impls/explicit/rk/rk.c
> >> (search for "Computing next stepsize"). I think you need to use the minimum
> >> of the timestep computed here and what is needed for the "stability criteria".
> > might work better.
> > Thanks
> > /nisse
> >>> Another interesting observation is that when using back euler at the
> >>> moment when it bugs out petsc has assigned neigboring cells pressure
> >>> values that differs about 1 ATM, which is a very non physical value,
> >> Likely some stability problem.
> >> Barry
> >>> but I have no clue as to why petsc want such a value in thesolution.
> >>> /nisse
> >>> On 3/3/06, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >>>> There must be a difference between the two RKs. The initial
> >>>> timestep it uses, or algorithm for changing time step or slight
> >>>> difference in algorithms?
> >>>> Barry
> >>>> On Fri, 3 Mar 2006, Nils Erik Svangård wrote:
> >>>>> A interesting thing is when I change TS_BEULER to TS_RUNGE_KUTTA the
> >>>>> solver exits fast due to the non physical values. My original solver
> >>>>> is a 3-step Runge-Kutta which works flawlessly.
> >>>>> The error when running RK:
> >>>>> ./ImplicitG3D on a linux-gnu named sethnx004.vac.com by yy26539 Fri
> >>>>> Mar 3 10:31:27 2006
> >>>>> Libraries linked from /home/yy26539/work/NISSE/petsc-2.3.0/lib/linux-gnu
> >>>>> Configure run at Thu Oct 13 08:23:56 2005
> >>>>> Configure options --with-cc=gcc --with-fc="f77 -N109"
> >>>>> --download-mpich=1 --download-mpich-pm=gforker
> >>>>> --download-f-blas-lapack=1 --with-shared=0
> >>>>> [0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
> >>>>> Exception,probably divide by zero
> >>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> >>>>> [0]PETSC ERROR: likely location of problem given in stack below
> >>>>> [0]PETSC ERROR: --------------- Stack Frames ---------------
> >>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> >>>>> [0]PETSC ERROR: INSTEAD the line number of the start of the function
> >>>>> [0]PETSC ERROR: is given.
> >>>>> [0]PETSC ERROR: [0] TS user right-hand-side function line 0 unknownunknown
> >>>>> [0]PETSC ERROR: [0] TSComputeRHSFunction line 282 src/ts/interface/ts.c
> >>>>> [0]PETSC ERROR: [0] TSRkqs line 256 src/ts/impls/explicit/rk/rk.c
> >>>>> [0]PETSC ERROR: [0] TSStep_Rk line 322 src/ts/impls/explicit/rk/rk.c
> >>>>> [0]PETSC ERROR: [0] TSStep line 1520 src/ts/interface/ts.c
> >>>>> [0]PETSC ERROR: --------------------------------------------
> >>>>> [0]PETSC ERROR: User provided function() line 0 in unknown directory
> >>>>> unknown file
> >>>>> [0]PETSC ERROR: Signal received!
> >>>>> [0]PETSC ERROR: !
> >>>>> aborting job:
> >>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> >>>>> On 3/3/06, Nils Erik Svangård <nilserik at gmail.com> wrote:
> >>>>>> Hello again,
> >>>>>>> Is it just not compiling because PETSC_ERR_ARG_DOMAIN is not
> >>>>>>> defined? Or does it still not work even when you have put the number in?
> >>>>>>> What is the error? Or did you get it all working with SNES?
> >>>>>> It is not compiling because PETSC_ERR_ARG_DOMAIN is not defined:
> >>>>>> error on line 585 of SNESG3D2.F: data type is undefined for variable
> >>>>>> I tried putting a number in, then it compiles but complains while
> >>>>>> linking that the Push() and Pop() functions is not defined. I made a
> >>>>>> workaround by adding a variable in a common block and setting it
> >>>>>> before returning from a non physical value in the FormFunction. Now I
> >>>>>> can compile and when there is a non-physical value it returns and
> >>>>>> resumes with a smaller timestep.
> >>>>>> SNES still give non physical values which are hard to add checks for
> >>>>>> in the program (e.g sqrt(RO(L)-RO(L+1))).
> >>>>>> Did I understand correctly that SNES does a linesearch and probably
> >>>>>> goes for a solution which isnt the one I looking for? Does SNES use
> >>>>>> the linesearch algorithm when I use -snes_mf (which I use)?
> >>>>>>> It may work automatically with TS; you would just set TS with a
> >>>>>>> smaller timestep and call TSSolve again?
> >>>>>> OK, I'll add a check and put TSSolve in a while loop.
> >>>>>> My SNESSolve loop looks like this right now:
> >>>>>> call VecCreateSeq(PETSC_COMM_SELF,N,x,ierr)
> >>>>>> call VecDuplicate(x,r,ierr)
> >>>>>> call VecDuplicate(x,xb,ierr)
> >>>>>> call SNESCreate(PETSC_COMM_SELF,snes,ierr)
> >>>>>> call SNESSetFunction(snes,r,FormFunction,PETSC_NULL_OBJECT,ierr)
> >>>>>> call SNESSetFromOptions(snes,ierr)
> >>>>>> call FormInitialGuess(x,ierr)
> >>>>>> call VecCopy(x,xb,ierr)
> >>>>>> write(6,*)zero,dt,tmax,i1000
> >>>>>> step=0
> >>>>>> timestep=dt
> >>>>>> bang=0
> >>>>>> C While loop
> >>>>>> 10 if (step .le. 100) then
> >>>>>> C call PetscExceptionPush(87,ierr)
> >>>>>> C call PetscExceptionPush(PETSC_ERR_ARG_DOMAIN,ierr)
> >>>>>> call SNESSolve(snes,PETSC_NULL_OBJECT,x,ierr)
> >>>>>> ierr=bang
> >>>>>> C call PetscExceptionPop(87,ierr2)
> >>>>>> IF ( ierr .EQ. 87) THEN
> >>>>>> timestep=timestep/2
> >>>>>> call VecCopy(xb,x,ierr)
> >>>>>> write(6,*) "No physical solution, trying",
> >>>>>> . " with smaller timestep: ",timestep
> >>>>>> bang=0
> >>>>>> ELSE
> >>>>>> call SNESGetConvergedReason(snes,reason,ierr)
> >>>>>> IF ( reason .LT. 0 ) THEN
> >>>>>> timestep=timestep/2
> >>>>>> write(6,*)"Solution diverged, trying with",
> >>>>>> . " smaller timestep: ",timestep
> >>>>>> ELSE
> >>>>>> timestep=dt
> >>>>>> step=step+1
> >>>>>> write(6,*) "Solve success, going for step: ",step
> >>>>>> write(6,*) "Reason: ",reason," ierr: ",ierr
> >>>>>> reason=0
> >>>>>> ierr=0
> >>>>>> ENDIF
> >>>>>> ENDIF
> >>>>>> goto 10
> >>>>>> endif
> >>>>>> C End While loop
> >>>>>> And the check in the FormFunction:
> >>>>>> if (ET(L) .LT. 0) then
> >>>>>> ierr = 87
> >>>>>> bang = 87
> >>>>>> C SETERRQ(87,"Non physical value!",ierr)
> >>>>>> return
> >>>>>> elseif ( RO(L) .LT. 0 ) then
> >>>>>> ierr = 87
> >>>>>> bang = 87
> >>>>>> return
> >>>>>> endif
> >>>>>> /nisse
> >>>>>>> Barry
> >>>>>>> I'm adding a petscerror.h for Fortran that includes these values
> >>>>>>> Sorry I forgot we hadn't given them for Fortran.
> >>>>>>> On Thu, 2 Mar 2006, Nils Erik Svangård wrote:
> >>>>>>>> Hi again,
> >>>>>>>> I realised that my implementation was a bit flawed so I have rewritten
> >>>>>>>> it again, the push and pop() functions dont seem to work, and they are
> >>>>>>>> keeping me from compiling the program, this is the main timestep loop:
> >>>>>>>> step=0
> >>>>>>>> timestep=dt
> >>>>>>>> C While loop
> >>>>>>>> timestep=timestep/2
> >>>>>>>> VecCopy(xb,x,ierr)
> >>>>>>>> ELSE
> >>>>>>>> timestep=timestep/2
> >>>>>>>> VecCopy(xb,x,ierr)
> >>>>>>>> ELSE
> >>>>>>>> timestep=dt
> >>>>>>>> step=step+1
> >>>>>>>> VecCopy(x,xb,ierr)
> >>>>>>>> ENDIF
> >>>>>>>> ENDIF
> >>>>>>>> goto 10
> >>>>>>>> endif
> >>>>>>>> C End While loop
> >>>>>>>> And in my Formfunction I have added the following check:
> >>>>>>>> ierr = 87
> >>>>>>>> return
> >>>>>>>> endif
> >>>>>>>> PETSC_ERR_ARG_DOMAIN didnt work: error on line 6500 of SNESG3D2.F:
> >>>>>>>> data type is undefined for variable PETSC_ERR_ARG_DOMAIN
> >>>>>>>> Even thought I had petsc.h included.
> >>>>>>>> Can I do this check when I use TS also? I have the sameproblem with
> >>>>>>>> the values being negative when using TS.
> >>>>>>>> /nisse
> >>>>>>>> On 2/27/06, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >>>>>>>>> SNES works by computing p = -approxinv(J)*F(uold) and
> >>>>>>>>> then does a line search on unew = uold + lambda*p to get the
> >>>>>>>>> new u. First it uses a test value of 1 for lambda so it
> >>>>>>>>> tries to compute F(uold + p). It is possible that uold + p
> >>>>>>>>> has some "non-physical" values in it. There are two ways
> >>>>>>>>> you can try handling it:
> >>>>>>>>> 1) Before doing the linesearch SNES calls a "precheck" function,
> >>>>>>>>> that can change the step if it decides there is a problem
> >>>>>>>>> with the step (like it is too long). You can provide your
> >>>>>>>>> own precheck function with SNESLineSearchSetPreCheck() it could,
> >>>>>>>>> for example, shrink the Newton direction to make it remain physical.
> >>>>>>>>> or 2) when your form function detects an illegal value it calls
> >>>>>>>>> SETERRQ(PETSC_ERR_ARG_DOMAIN,"Nonphysical function input"); Note:
> >>>>>>>>> this is before it takes the square root of the negative number,
> >>>>>>>>> so check the number and call the error before calling SETERRQ().
> >>>>>>>>> (If using Fortran then simply set ierr = PETSC_ERR_ARG_DOMAIN and
> >>>>>>>>> then immediately return). Then replace your call to SNESSolve with
> >>>>>>>>> ierr = PetscExceptionTry1(SNESSolve(snes,b,x),PETSC_ERR_ARG_DOMAIN);
> >>>>>>>>> if (PetscExceptionCaught(ierr,PETSC_ERR_ARG_DOMAIN)) {
> >>>>>>>>> /* this means your function found a non-physical value so
> >>>>>>>>> cut your time-step and continue through the loop again. */
> >>>>>>>>> Put code to do this here.
> >>>>>>>>> If using fortran then do
> >>>>>>>>> call SNESSolve(snes,b,x,ierr)
> >>>>>>>>> call PetscExceptionPop(PETSC_ERR_ARG_DOMAIN,anotherierr)
> >>>>>>>>> if (ierr == PETSC_ERR_ARG_DOMAIN) then
> >>>>>>>>> non-physical value so cut the time-step and try again
> >>>>>>>>> else ! everything is normal so take the next time-step
> >>>>>>>>> Barry
> >>>>>>>>> The Fortran interface may be missing PetscExceptionPush() and Pop()
> >>>>>>>>> if so let us know and we'll provide the patch.
> >>>>>>>>> On Mon, 27 Feb 2006, Nils Erik Svangård wrote:
> >>>>>>>>>> Hi all,
> >>>>>>>>>> I have problems solving some CFD problems using SNES and my custom
> >>>>>>>>>> back-euler. I have 7 equations that I want to solve.
> >>>>>>>>>> First my FormFunction copies the values from the Vec that SNES uses to
> >>>>>>>>>> the variables that my code use:
> >>>>>>>>>> RO(L)=xx(1,L)
> >>>>>>>>>> RU(L)=xx(2,L)
> >>>>>>>>>> RV(L)=xx(3,L)
> >>>>>>>>>> RW(L)=xx(4,L)
> >>>>>>>>>> ET(L)=xx(5,L)
> >>>>>>>>>> RQ(L)= xx(6,L)
> >>>>>>>>>> REPS(L)=xx(7,L)
> >>>>>>>>>> Here I also print the values of ET(2) for debugging:
> >>>>>>>>>> write(6,*)"ET(2) = xx(5,2) : ",ET(2)," = ",xx(5,2)
> >>>>>>>>>> Then I get the fluxes by calling custom functions
> >>>>>>>>>> call AUXVR
> >>>>>>>>>> call VGRAD
> >>>>>>>>>> call FLUX
> >>>>>>>>>> call KESRC
> >>>>>>>>>> Then I perform back-euler save the new value to so that I can use it
> >>>>>>>>>> in the next iterationi (TSF(L) is Time step function, which is set by
> >>>>>>>>>> hand and is the same for all L):
> >>>>>>>>>> ff(1,L) = RO(L)-OLD(1,L)-TSF(L)*DRO(L)
> >>>>>>>>>> ff(2,L) = RU(L)-OLD(2,L)-TSF(L)*DRU(L)
> >>>>>>>>>> ff(3,L) = RV(L)-OLD(3,L)-TSF(L)*DRV(L)
> >>>>>>>>>> ff(4,L) = RW(L)-OLD(4,L)-TSF(L)*DRW(L)
> >>>>>>>>>> ff(5,L) = ET(L)-OLD(5,L)-TSF(L)*DET(L)
> >>>>>>>>>> ff(6,L) = RQ(L)-OLD(6,L)-TSF(L)*DRQ(L)
> >>>>>>>>>> ff(7,L) = REPS(L)-OLD(7,L)-TSF(L)*DREPS(L)
> >>>>>>>>>> And save the new value of RO-REPS to use in the next iteration of back-euler:
> >>>>>>>>>> OLD(1,L)=RO(L)
> >>>>>>>>>> OLD(2,L)=RU(L)
> >>>>>>>>>> OLD(3,L)=RV(L)
> >>>>>>>>>> OLD(4,L)=RW(L)
> >>>>>>>>>> OLD(5,L)=ET(L)
> >>>>>>>>>> OLD(6,L)=RQ(L)
> >>>>>>>>>> OLD(7,L)=REPS(L)
> >>>>>>>>>> Here I print the values of L=2 as above for debugging:
> >>>>>>>>>> write(6,*)ff(5,2)," = ",ET(2),"-",OLD(5,2),"-",TSF(2),"*",DET(2)
> >>>>>>>>>> The program exit abnormaly after 33 runs of the FormFunction. The
> >>>>>>>>>> cause of this is that AUXVR tries to perform sqrt(ET(2)) when ET(2) is
> >>>>>>>>>> negative, ET is the total energy and should never be negative. It
> >>>>>>>>>> seems that all of a sudden the PETSc SNES solver decides to supply the
> >>>>>>>>>> FormFunction with a negative ET value. I need help understanding why
> >>>>>>>>>> and how to fix it (if it is fixable).
> >>>>>>>>>> Here is the output of:
> >>>>>>>>>> Which is in the beginning of my FormFunction.
> >>>>>>>>>> And:
> >>>>>>>>>> Which is in the end of my Formfunction.
> >>>>>>>>>> 1. ET(2) = xx(5,2) : 253250. = 253250.000000000
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4126563437192 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.941266E+08
> >>>>>>>>>> 2. ET(2) = xx(5,2) : 253250. = 253250.000010259
> >>>>>>>>>> 3. ET(2) = xx(5,2) : 253250. = 253249.999999988
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4132419437260 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.941324E+08
> >>>>>>>>>> 4. ET(2) = xx(5,2) : 253250. = 253250.000048432
> >>>>>>>>>> 5. ET(2) = xx(5,2) : 253250. = 253249.999999872
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4177283437784 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.941773E+08
> >>>>>>>>>> 6. ET(2) = xx(5,2) : 253250. = 253250.000071113
> >>>>>>>>>> 7. ET(2) = xx(5,2) : 253250. = 253249.999980115
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4453347441010 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.944533E+08
> >>>>>>>>>> 8. ET(2) = xx(5,2) : 253250. = 253250.000037298
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4082723436679 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.940827E+08
> >>>>>>>>>> 9. ET(2) = xx(5,2) : 253250. = 253249.999942706
> >>>>>>>>>> 10. ET(2) = xx(5,2) : 253250. = 253249.999948703
> >>>>>>>>>> 11. ET(2) = xx(5,2) : 253250. = 253250.000007808
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.7283811474088 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.972838E+08
> >>>>>>>>>> 12. ET(2) = xx(5,2) : 253250. = 253250.000018146
> >>>>>>>>>> 13. ET(2) = xx(5,2) : 253250. = 253250.000001865
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 28.3742819315846 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.837428E+08
> >>>>>>>>>> 14. ET(2) = xx(5,2) : 253250. = 253249.999997296
> >>>>>>>>>> 15. ET(2) = xx(5,2) : 253250. = 253250.000000049
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 30.6548963582361 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -3.065490E+08
> >>>>>>>>>> 16. ET(2) = xx(5,2) : 253250. = 253250.000022870
> >>>>>>>>>> 17. ET(2) = xx(5,2) : 253250. = 253249.999999716
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.5326051451209 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.953260E+08
> >>>>>>>>>> 18. ET(2) = xx(5,2) : 253250. = 253250.000074328
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4165187437643 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.941652E+08
> >>>>>>>>>> 19. ET(2) = xx(5,2) : 253250. = 253250.000049809
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4085059436707 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.940851E+08
> >>>>>>>>>> 20. ET(2) = xx(5,2) : 253250. = 253250.000019253
> >>>>>>>>>> 21. ET(2) = xx(5,2) : 253250. = 253250.000000189
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.8851075492403 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.988511E+08
> >>>>>>>>>> 22. ET(2) = xx(5,2) : 253250. = 253249.999997897
> >>>>>>>>>> 23. ET(2) = xx(5,2) : 253250. = 253249.999975142
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.3961539435263 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.939615E+08
> >>>>>>>>>> 24. ET(2) = xx(5,2) : 253250. = 253250.000018324
> >>>>>>>>>> 25. ET(2) = xx(5,2) : 253250. = 253249.999987073
> >>>>>>>>>> 26. ET(2) = xx(5,2) : 253250. = 253249.999980982
> >>>>>>>>>> 27. ET(2) = xx(5,2) : 253250. = 253249.999994645
> >>>>>>>>>> 28. ET(2) = xx(5,2) : 253250. = 253249.999962364
> >>>>>>>>>> 29. ET(2) = xx(5,2) : 253250. = 253249.999999921
> >>>>>>>>>> 30. ET(2) = xx(5,2) : 253250. = 253250.000000058
> >>>>>>>>>> ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 28.4019971319085 =
> >>>>>>>>>> 253250. - 253250.000000000 - 1.000000E-07 * -2.840200E+08
> >>>>>>>>>> 31. ET(2) = xx(5,2) : 253250. = 253250.000040348
> >>>>>>>>>> 32. ET(2) = xx(5,2) : 253250. = 253250.000005245
> >>>>>>>>>> 33. ET(2) = xx(5,2) : 253250. = 253250.000005245
> >>>>>>>>>> 34. ET(2) = xx(5,2) : -848141. = -848141.388090847
> >>>>>>>>>> Petsc Release Version 2.3.0, Patch 32, April, 26, 2005
> >>>>>>>>>> See docs/changes/index.html for recent updates.
> >>>>>>>>>> See docs/faq.html for hints about trouble shooting.
> >>>>>>>>>> See docs/index.html for manual pages.
> >>>>>>>>>> ./SNESG3D2 on a linux-gnu named sethnx004.vac.com by yy26539 Mon Feb
> >>>>>>>>>> 27 14:21:13 2006
> >>>>>>>>>> [0]PETSC ERROR: [0] SNES user function line 0 unknownunknown
> >>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeFunction line 788 src/snes/interface/snes.c
> >>>>>>>>>> [0]PETSC ERROR: [0] SNESLineSearchCubic line 514 src/snes/impls/ls/ls.c
> >>>>>>>>>> unknown file
> >>>>>>>>>> [0]PETSC ERROR: !
> >>>>>>>>>> Suggestions and tips are very welcome!
> >>>>>>>>>> /nisse
> >>>>>>>>>> Nils-Erik Svang�rd
> >>>>>>>>>> MSN: schweingaard at hotmail.com
> >>>>>>>>>> Skype: schweingaard
> >>>>>>>> Nils-Erik Svangård
> >>>>>>>> Skype: schweingaard
> >>>>>> Nils-Erik Svangård
> >>>>>> E-Mail: nilserik at gmail.com
> >>>>>> Skype: schweingaard
> >>>>>> Mobil: +46-(0)70-3612178
> >>>>> Nils-Erik Svangård
> >>>>> Skype: schweingaard
> >>> Nils-Erik Svangård
> >>> Skype: schweingaard
> > Nils-Erik Svangård
> > Skype: schweingaard
Nils-Erik Svangård
Skype: schweingaard
