***LOOPING MAIL*** PetscInitialize problem?
Mon Mar 13 13:36:03 CST 2006
According to the error message - the communicator is invalid.  You
might want to check that..
You should be able to call MPI_Comm_size() after PetscInitialize()
Check src/sys/examples/tutorials/ex1.c for an example of this usage.
BTW: Do PETSc examples run fine with your install?
Satish
On Mon, 13 Mar 2006, ziemer at lncc.br wrote:
> Hello,
> I would be very glad if someone could give me some direction:
> After the MPI_Comm_size function is called, I got this error:
> aborting job:
> Fatal error in MPI_Comm_size: Invalid communicator, error stack:
> MPI_Comm_size(110): MPI_Comm_size(comm=0x1, size=0xbfffdf78) failed
> MPI_Comm_size(69): Invalid communicator
> It seems that the MPI environment is not being correctly created by the function
> PetscInitialize.
> Does anyone have any idea?
> Best Regards.
> This message was sent using IMP, the Internet Messaging Program.
