Matrix convergence.
Barry Smith
bsmith at mcs.anl.gov
Sat Mar 11 21:50:53 CST 2006
KSPGetPC(ksp,&pc);
PCBJacobiGetSubKSP(pc,&subksp); or PCASMGetSubKSP(..
KPSGetPC(subksp,&subpc);
PCSetType(subpc,PCLU);
On Sun, 12 Mar 2006, billy at dem.uminho.pt wrote:
> Hi,
> "-sub_pc_type"
> How do I set this option in the code?
> Billy.
> Quoting Barry Smith <bsmith at mcs.anl.gov>:
>> You did not type it right -sub_pc_type lu not -pc_type lu
>> On Fri, 3 Mar 2006, billy at dem.uminho.pt wrote:
>>> This is what I get:
>>> [0]PETSC ERROR: MatLUFactorSymbolic() line 2159 in
>> src/mat/interface/matrix.c
>>> [0]PETSC ERROR: No support for this operation for this object type!
>>> [0]PETSC ERROR: Matrix type mpiaij symbolic LU!
>>> [0]PETSC ERROR: PCSetUp_LU() line 252 in src/ksp/pc/impls/factor/lu/lu.c
>>> [0]PETSC ERROR: PCSetUp() line 798 in src/ksp/pc/interface/precon.c
>>> [0]PETSC ERROR: KSPSetUp() line 234 in src/ksp/ksp/interface/itfunc.c
>>> [0]PETSC ERROR: KSPSolve() line 334 in src/ksp/ksp/interface/itfunc.c
>>>> Run the parallel PETSc job with -ksp_type gmres -ksp_gmres_restart
>> 200
>>>> -sub_pc_type lu
>>>>> Hi,
>>>>> I tried to solve the 18x18 matrix with laspack and the results are the
>>>> following:
>>>>> Solver: GMRES, Preconditioning: NULL, Iterations: 500, Residual:
>> 6.16E-2
>>>>> Solver: GMRES, Preconditioning: SSOR, Iterations: 500, Residual:
>> 6.57E-2
>>>>> Solver: GMRES, Preconditioning: ILU, ERROR
>>>>> Solver: BiCGSTAB, Preconditioning: NULL, Iterations: 101, Residual:
>>>> 8.88E-7
>>>>> Solver: BiCGSTAB, Preconditioning: SSOR, Iterations: 36, Residual:
>>>> 9.87E-7
>>>>> Solver: BiCGSTAB, Preconditioning: ILU, ERROR
>>>>> Billy.
>>>>>> Billy,
>>>>>> Most likely there is something wrong with the matrix being
>>>>>> generated. I would first look at the matrix entries and make
>>>>>> sure they make sense. Then I would solve the linear systems
>>>>>> with a direct solver -pc_type lu (on one processor and make
>>>>>> sure the solutions are reasonable and your simulation has
>>>>>> "correct" answers).
>>>>>> It is possible the parallel matrix generation is wrong,
>>>>>> Barry
>>>>>> On Thu, 2 Mar 2006, billy at dem.uminho.pt wrote:
>>>>>>> Hi,
>>>>>>> I have been testing my parallel implementation with a 2D case. I have
>>>> used
>>>>>> the
>>>>>>> following grids with 2 and 4 processes: 4x4, 10x10, 16x16 and 18x18.
>>>>>>> It works for the first three (max. number of iterations to converge
>>>> aprox.
>>>>>> 70)
>>>>>>> but when I increase to 18x18 the matrix does not converge. I have
>>>> increased
>>>>>> the
>>>>>>> maximum number of iterations and I have used GMRES, BiCGSTAB with
>>>>>>> preconditioners ASM, JACOBI, etc.
>>>>>>> With KSPType = GMRES and PCType = ASM:
>>>>>>> Number of iterations: 500 Residual: +1.420471E-01
>>>>>>> With KSPType = GMRES and PCType = JACOBI:
>>>>>>> Number of iterations: 500 Residual: +2.351882E-02
>>>>>>> With KSPType = BCGS and PCType = ASM:
>>>>>>> Number of iterations: 136 Residual: +3.911446E+04
>>>>>>> With KSPType = BCGS and PCType = NULL:
>>>>>>> Number of iterations: 157 Residual: +3.254728E+03
>>>>>>> Is it normal that the convergence detiorates so much with such a
>> slight
>>>>>> increase
>>>>>>> in the dimension of the matrix? Is there any optimization parameter
>> that
>>>> I
>>>>>> may
>>>>>>> be missing?
>>>>>>> Billy.
