Matrix convergence.
Matthew Knepley
knepley at mcs.anl.gov
Fri Mar 3 11:40:08 CST 2006
billy at dem.uminho.pt writes:
I don't understand. LAPACK does not have these iterative methods?
Matt
> Hi,
> I tried to solve the 18x18 matrix with laspack and the results are the following:
> Solver: GMRES, Preconditioning: NULL, Iterations: 500, Residual: 6.16E-2
> Solver: GMRES, Preconditioning: SSOR, Iterations: 500, Residual: 6.57E-2
> Solver: GMRES, Preconditioning: ILU, ERROR
> Solver: BiCGSTAB, Preconditioning: NULL, Iterations: 101, Residual: 8.88E-7
> Solver: BiCGSTAB, Preconditioning: SSOR, Iterations: 36, Residual: 9.87E-7
> Solver: BiCGSTAB, Preconditioning: ILU, ERROR
> Billy.
> Quoting Barry Smith <bsmith at mcs.anl.gov>:
>> Billy,
>> Most likely there is something wrong with the matrix being
>> generated. I would first look at the matrix entries and make
>> sure they make sense. Then I would solve the linear systems
>> with a direct solver -pc_type lu (on one processor and make
>> sure the solutions are reasonable and your simulation has
>> "correct" answers).
>> It is possible the parallel matrix generation is wrong,
>> Barry
>> On Thu, 2 Mar 2006, billy at dem.uminho.pt wrote:
>> > Hi,
>> > I have been testing my parallel implementation with a 2D case. I have used
>> the
>> > following grids with 2 and 4 processes: 4x4, 10x10, 16x16 and 18x18.
>> > It works for the first three (max. number of iterations to converge aprox.
>> 70)
>> > but when I increase to 18x18 the matrix does not converge. I have increased
>> the
>> > maximum number of iterations and I have used GMRES, BiCGSTAB with
>> > preconditioners ASM, JACOBI, etc.
>> > With KSPType = GMRES and PCType = ASM:
>> > Number of iterations: 500 Residual: +1.420471E-01
>> > With KSPType = GMRES and PCType = JACOBI:
>> > Number of iterations: 500 Residual: +2.351882E-02
>> > With KSPType = BCGS and PCType = ASM:
>> > Number of iterations: 136 Residual: +3.911446E+04
>> > With KSPType = BCGS and PCType = NULL:
>> > Number of iterations: 157 Residual: +3.254728E+03
>> > Is it normal that the convergence detiorates so much with such a slight
>> increase
>> > in the dimension of the matrix? Is there any optimization parameter that I
>> may
>> > be missing?
>> > Billy.
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec Guiness
