SNES Problem
Nils Erik Svangård nilserik at gmail.com
Fri Mar 3 03:58:27 CST 2006
A interesting thing is when I change TS_BEULER to TS_RUNGE_KUTTA the
solver exits fast due to the non physical values. My original solver
is a 3-step Runge-Kutta which works flawlessly.
The error when running RK:
./ImplicitG3D on a linux-gnu named sethnx004.vac.com by yy26539 Fri
Mar  3 10:31:27 2006
Libraries linked from /home/yy26539/work/NISSE/petsc-2.3.0/lib/linux-gnu
Configure run at Thu Oct 13 08:23:56 2005
Configure options --with-cc=gcc --with-fc="f77 -N109"
--download-mpich=1 --download-mpich-pm=gforker
--download-f-blas-lapack=1 --with-shared=0
[0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
Exception,probably divide by zero
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------- Stack Frames ---------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] TS user right-hand-side function line 0 unknownunknown
[0]PETSC ERROR: [0] TSComputeRHSFunction line 282 src/ts/interface/ts.c
[0]PETSC ERROR: [0] TSRkqs line 256 src/ts/impls/explicit/rk/rk.c
[0]PETSC ERROR: [0] TSStep_Rk line 322 src/ts/impls/explicit/rk/rk.c
[0]PETSC ERROR: [0] TSStep line 1520 src/ts/interface/ts.c
[0]PETSC ERROR: --------------------------------------------
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:  !
aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
On 3/3/06, Nils Erik Svangård <nilserik at gmail.com> wrote:
> Hello again,
>  >    Is it just not compiling because  PETSC_ERR_ARG_DOMAIN is not
> > defined? Or does it still not work even when you have put the number in?
> > What is the error? Or did you get it all working with SNES?
> It is not compiling because PETSC_ERR_ARG_DOMAIN is not defined:
> error on line 585 of SNESG3D2.F: data type is undefined for variable
> I tried putting a number in, then it compiles but complains while
> linking that the Push() and Pop() functions is not defined. I made a
> workaround by adding a variable in a common block and setting it
> before returning from a non physical value in the FormFunction. Now I
> can compile and when there is a non-physical value it returns and
> resumes with a smaller timestep.
> SNES still give non physical values which are hard to add checks for
> in the program (e.g sqrt(RO(L)-RO(L+1))).
> Did I understand correctly that SNES does a linesearch and probably
> goes for a solution which isnt the one I looking for? Does SNES use
> the linesearch algorithm when I use -snes_mf (which I use)?
> >    It may work automatically with TS; you would just set TS with a
> > smaller timestep and call TSSolve again?
> OK, I'll add a check and put TSSolve in a while loop.
> My SNESSolve loop looks like this right now:
>       call VecCreateSeq(PETSC_COMM_SELF,N,x,ierr)
>       call VecDuplicate(x,r,ierr)
>       call VecDuplicate(x,xb,ierr)
>       call SNESCreate(PETSC_COMM_SELF,snes,ierr)
>       call SNESSetFunction(snes,r,FormFunction,PETSC_NULL_OBJECT,ierr)
>       call SNESSetFromOptions(snes,ierr)
>       call FormInitialGuess(x,ierr)
>       call VecCopy(x,xb,ierr)
>       write(6,*)zero,dt,tmax,i1000
>       step=0
>       timestep=dt
>       bang=0
> C While loop
>    10 if (step .le. 100) then
> C        call PetscExceptionPush(87,ierr)
> C         call PetscExceptionPush(PETSC_ERR_ARG_DOMAIN,ierr)
>         call SNESSolve(snes,PETSC_NULL_OBJECT,x,ierr)
>         ierr=bang
> C        call PetscExceptionPop(87,ierr2)
>          IF ( ierr .EQ. 87) THEN
>            timestep=timestep/2
>            call VecCopy(xb,x,ierr)
>            write(6,*) "No physical solution, trying",
>      .                " with smaller timestep: ",timestep
>            bang=0
>          ELSE
>           call SNESGetConvergedReason(snes,reason,ierr)
>           IF ( reason .LT. 0 ) THEN
>             timestep=timestep/2
>             write(6,*)"Solution diverged, trying with",
>      .                " smaller timestep: ",timestep
>           ELSE
>             timestep=dt
>             step=step+1
>             write(6,*) "Solve success, going for step: ",step
>             write(6,*) "Reason: ",reason," ierr: ",ierr
>             reason=0
>             ierr=0
>           ENDIF
>         ENDIF
>        goto 10
>       endif
> C End While loop
> And the check in the FormFunction:
>               if (ET(L) .LT. 0) then
>                 ierr = 87
>                 bang = 87
> C                SETERRQ(87,"Non physical value!",ierr)
>                 return
>               elseif ( RO(L) .LT. 0 ) then
>                 ierr = 87
>                 bang = 87
>                 return
>               endif
> /nisse
> >    Barry
> >    I'm adding a petscerror.h for Fortran that includes these values
> > Sorry I forgot we hadn't given them for Fortran.
> > On Thu, 2 Mar 2006, Nils Erik Svangård wrote:
> > > Hi again,
> > > I realised that my implementation was a bit flawed so I have rewritten
> > > it again, the push and pop() functions dont seem to work, and they are
> > > keeping me from compiling the program, this is the main timestep loop:
> > >      step=0
> > >      timestep=dt
> > > C While loop
> > >           timestep=timestep/2
> > >           VecCopy(xb,x,ierr)
> > >        ELSE
> > >           timestep=timestep/2
> > >           VecCopy(xb,x,ierr)
> > >         ELSE
> > >           timestep=dt
> > >           step=step+1
> > >           VecCopy(x,xb,ierr)
> > >         ENDIF
> > >        ENDIF
> > >       goto 10
> > >      endif
> > > C End While loop
> > > And in my Formfunction I have added the following check:
> > >                ierr = 87
> > >                return
> > >              endif
> > > PETSC_ERR_ARG_DOMAIN didnt work:  error on line 6500 of SNESG3D2.F:
> > > data type is undefined for variable PETSC_ERR_ARG_DOMAIN
> > > Even thought I had petsc.h included.
> > > Can I do this check when I use TS also? I have the sameproblem with
> > > the values being negative when using TS.
> > > /nisse
> > > On 2/27/06, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >>    SNES works by computing p = -approxinv(J)*F(uold) and
> > >> then does a line search on unew = uold + lambda*p to get the
> > >> new u. First it uses a test value of 1 for lambda so it
> > >> tries to compute F(uold + p). It is possible that uold + p
> > >> has some "non-physical" values in it.  There are two ways
> > >> you can try handling it:
> > >> 1) Before doing the linesearch SNES calls a "precheck" function,
> > >> that can change the step if it decides there is a problem
> > >> with the step (like it is too long). You can provide your
> > >> own precheck function with SNESLineSearchSetPreCheck() it could,
> > >> for example, shrink the Newton direction to make it remain physical.
> > >> or 2) when your form function detects an illegal value it calls
> > >> SETERRQ(PETSC_ERR_ARG_DOMAIN,"Nonphysical function input"); Note:
> > >> this is before it takes the square root of the negative number,
> > >> so check the number and call the error before calling SETERRQ().
> > >> (If using Fortran then simply set ierr = PETSC_ERR_ARG_DOMAIN and
> > >> then immediately return). Then replace your call to SNESSolve with
> > >>    ierr = PetscExceptionTry1(SNESSolve(snes,b,x),PETSC_ERR_ARG_DOMAIN);
> > >>    if (PetscExceptionCaught(ierr,PETSC_ERR_ARG_DOMAIN)) {
> > >>      /* this means your function found a non-physical value so
> > >>         cut your time-step and continue through the loop again. */
> > >>         Put code to do this here.
> > >> If using fortran then do
> > >> call SNESSolve(snes,b,x,ierr)
> > >> call PetscExceptionPop(PETSC_ERR_ARG_DOMAIN,anotherierr)
> > >> if (ierr == PETSC_ERR_ARG_DOMAIN) then
> > >>    non-physical value so cut the time-step and try again
> > >> else ! everything is normal so take the next time-step
> > >>    Barry
> > >> The Fortran interface may be missing PetscExceptionPush() and Pop()
> > >> if so let us know and we'll provide the patch.
> > >> On Mon, 27 Feb 2006, Nils Erik Svangård wrote:
> > >>> Hi all,
> > >>> I have problems solving some CFD problems using SNES and my custom
> > >>> back-euler. I have 7 equations that I want to solve.
> > >>> First my FormFunction copies the values from the Vec that SNES uses to
> > >>> the variables that my code use:
> > >>>      RO(L)=xx(1,L)
> > >>>      RU(L)=xx(2,L)
> > >>>      RV(L)=xx(3,L)
> > >>>      RW(L)=xx(4,L)
> > >>>      ET(L)=xx(5,L)
> > >>>      RQ(L)= xx(6,L)
> > >>>      REPS(L)=xx(7,L)
> > >>> Here I also print the values of ET(2) for debugging:
> > >>>      write(6,*)"ET(2) = xx(5,2) : ",ET(2)," = ",xx(5,2)
> > >>> Then I get the fluxes by calling custom functions
> > >>>      call AUXVR
> > >>>      call VGRAD
> > >>>      call FLUX
> > >>>      call KESRC
> > >>> Then I perform back-euler  save the new value to so that I can use it
> > >>> in the next iterationi (TSF(L) is Time step function, which is set by
> > >>> hand and is the same for all L):
> > >>>      ff(1,L) = RO(L)-OLD(1,L)-TSF(L)*DRO(L)
> > >>>      ff(2,L) = RU(L)-OLD(2,L)-TSF(L)*DRU(L)
> > >>>      ff(3,L) = RV(L)-OLD(3,L)-TSF(L)*DRV(L)
> > >>>      ff(4,L) = RW(L)-OLD(4,L)-TSF(L)*DRW(L)
> > >>>      ff(5,L) = ET(L)-OLD(5,L)-TSF(L)*DET(L)
> > >>>      ff(6,L) = RQ(L)-OLD(6,L)-TSF(L)*DRQ(L)
> > >>>      ff(7,L) = REPS(L)-OLD(7,L)-TSF(L)*DREPS(L)
> > >>> And save the new value of RO-REPS to use in the next iteration of back-euler:
> > >>>      OLD(1,L)=RO(L)
> > >>>      OLD(2,L)=RU(L)
> > >>>      OLD(3,L)=RV(L)
> > >>>      OLD(4,L)=RW(L)
> > >>>      OLD(5,L)=ET(L)
> > >>>      OLD(6,L)=RQ(L)
> > >>>      OLD(7,L)=REPS(L)
> > >>> Here I print the values of L=2 as above for debugging:
> > >>>      write(6,*)ff(5,2)," = ",ET(2),"-",OLD(5,2),"-",TSF(2),"*",DET(2)
> > >>> The program exit abnormaly after 33 runs of the FormFunction. The
> > >>> cause of this is that AUXVR tries to perform sqrt(ET(2)) when ET(2) is
> > >>> negative, ET is the total energy and should never be negative. It
> > >>> seems that all of a sudden the PETSc SNES solver decides to supply the
> > >>> FormFunction with a negative ET value. I need help understanding why
> > >>> and how to fix it (if it is fixable).
> > >>> Here is the output of:
> > >>> Which is in the beginning of my FormFunction.
> > >>> And:
> > >>> Which is in the end of my Formfunction.
> > >>> 1. ET(2) = xx(5,2) :   253250.  =   253250.000000000
> > >>>   ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4126563437192  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.941266E+08
> > >>> 2. ET(2) = xx(5,2) :   253250.  =   253250.000010259
> > >>> 3. ET(2) = xx(5,2) :   253250.  =   253249.999999988
> > >>>   ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4132419437260  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.941324E+08
> > >>> 4. ET(2) = xx(5,2) :   253250.  =   253250.000048432
> > >>> 5. ET(2) = xx(5,2) :   253250.  =   253249.999999872
> > >>>   ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4177283437784  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.941773E+08
> > >>> 6. ET(2) = xx(5,2) :   253250.  =   253250.000071113
> > >>> 7. ET(2) = xx(5,2) :   253250.  =   253249.999980115
> > >>>   ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4453347441010  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.944533E+08
> > >>> 8. ET(2) = xx(5,2) :   253250.  =   253250.000037298
> > >>>   ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4082723436679  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.940827E+08
> > >>> 9. ET(2) = xx(5,2) :   253250.  =   253249.999942706
> > >>> 10. ET(2) = xx(5,2) :   253250.  =   253249.999948703
> > >>> 11. ET(2) = xx(5,2) :   253250.  =   253250.000007808
> > >>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.7283811474088  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.972838E+08
> > >>> 12. ET(2) = xx(5,2) :   253250.  =   253250.000018146
> > >>> 13. ET(2) = xx(5,2) :   253250.  =   253250.000001865
> > >>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   28.3742819315846  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.837428E+08
> > >>> 14. ET(2) = xx(5,2) :   253250.  =   253249.999997296
> > >>> 15. ET(2) = xx(5,2) :   253250.  =   253250.000000049
> > >>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   30.6548963582361  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -3.065490E+08
> > >>> 16. ET(2) = xx(5,2) :   253250.  =   253250.000022870
> > >>> 17. ET(2) = xx(5,2) :   253250.  =   253249.999999716
> > >>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.5326051451209  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.953260E+08
> > >>> 18. ET(2) = xx(5,2) :   253250.  =   253250.000074328
> > >>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4165187437643  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.941652E+08
> > >>> 19. ET(2) = xx(5,2) :   253250.  =   253250.000049809
> > >>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.4085059436707  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.940851E+08
> > >>> 20. ET(2) = xx(5,2) :   253250.  =   253250.000019253
> > >>> 21. ET(2) = xx(5,2) :   253250.  =   253250.000000189
> > >>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.8851075492403  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.988511E+08
> > >>> 22. ET(2) = xx(5,2) :   253250.  =   253249.999997897
> > >>> 23. ET(2) = xx(5,2) :   253250.  =   253249.999975142
> > >>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   29.3961539435263  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.939615E+08
> > >>> 24. ET(2) = xx(5,2) :   253250.  =   253250.000018324
> > >>> 25. ET(2) = xx(5,2) :   253250.  =   253249.999987073
> > >>> 26. ET(2) = xx(5,2) :   253250.  =   253249.999980982
> > >>> 27. ET(2) = xx(5,2) :   253250.  =   253249.999994645
> > >>> 28. ET(2) = xx(5,2) :   253250.  =   253249.999962364
> > >>> 29. ET(2) = xx(5,2) :   253250.  =   253249.999999921
> > >>> 30. ET(2) = xx(5,2) :   253250.  =   253250.000000058
> > >>>    ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) :   28.4019971319085  =
> > >>> 253250. -  253250.000000000 -  1.000000E-07 * -2.840200E+08
> > >>> 31. ET(2) = xx(5,2) :   253250.  =   253250.000040348
> > >>> 32. ET(2) = xx(5,2) :   253250.  =   253250.000005245
> > >>> 33. ET(2) = xx(5,2) :   253250.  =   253250.000005245
> > >>> 34. ET(2) = xx(5,2) :  -848141.  =  -848141.388090847
> > >>> Petsc Release Version 2.3.0, Patch 32, April, 26, 2005
> > >>> See docs/changes/index.html for recent updates.
> > >>> See docs/faq.html for hints about trouble shooting.
> > >>> See docs/index.html for manual pages.
> > >>> ./SNESG3D2 on a linux-gnu named sethnx004.vac.com by yy26539 Mon Feb
> > >>> 27 14:21:13 2006
> > >>> [0]PETSC ERROR: [0] SNES user function line 0 unknownunknown
> > >>> [0]PETSC ERROR: [0] SNESComputeFunction line 788 src/snes/interface/snes.c
> > >>> [0]PETSC ERROR: [0] SNESLineSearchCubic line 514 src/snes/impls/ls/ls.c
> > >>> unknown file
> > >>> [0]PETSC ERROR:  !
> > >>> Suggestions and tips are very welcome!
> > >>> /nisse
> > >>> Nils-Erik Svang�rd
> > >>> MSN: schweingaard at hotmail.com
> > >>> Skype: schweingaard
> > > Nils-Erik Svangård
> > > Skype: schweingaard
> Nils-Erik Svangård
> E-Mail: nilserik at gmail.com
> Skype: schweingaard
> Mobil: +46-(0)70-3612178
Nils-Erik Svangård
Skype: schweingaard
