Set values of symmetric matrices.
Hong Zhang
hzhang at mcs.anl.gov
Thu Jun 22 11:16:06 CDT 2006
Billy,
We support cg with MPIAIJ and MPISBAIJ format.
> I use MatCreateMPIAIJ to create parallel matrices. I would like to use KSPCG to
> solve a symmetric matrices. I tried to implement it but the program exits with
> no error.
Do you mean with error? If so, what error message?
>Do I need only to set values on the diagonal and upper diagonal only
> or continue to set all non-zero entries of the matrix?
If you use MPISBAIJ matrix format, then you only need to set the diagonal
and upper diagonals. Setting all non-zero entries of the matrix
also works - petsc ignores the lower triangular part.
Hong
