about ghosted vectors and there local representation
Matthew Knepley
knepley at gmail.com
Tue Jun 20 09:24:57 CDT 2006
In the DA we have some idea of topology, so we can make a sensible
reordered local vector. The VecGhost is a lower level construct. All it
does is maintain a vector of this form
[ local values | ghost values ]
The update maps from local values to ghost values with a scatter. The
VecGhostGetLocalForm() just pulls out the pointer. We could add code
which maps into a different local vector using an ordering, but this can
already be done with an AO as well.
Matt
On 6/20/06, Thomas Geenen <geenen at gmail.com> wrote:
> On Tuesday 20 June 2006 13:32, you wrote:
> > > I now expect the vector to be in the local form. That means that the
> > > positions
> > > that I created as ghost points are filled with the solution
> corresponding
> > > to
> > > the global solution. I expect that they are inserted in the position
> in
> > > my local vector corresponding to there corresponding global position.
> > Not sure what you mean here. The local form is the same as the global
> > vector
> > in the owned spots, and then has the ghost points at the end.
> oke so that means (4,5,3) ??
> So if I need the solution in the same positions as the ones that i filled
> with
> VecSetValuesLocal I will have to reorder the vector
> What does VecGhostGetLocalForm do? inserts the global solution in the
> ghost
> points at the end? I thought VecGhostUpdateBegin VecGhostUpdateEnd did
> that.
> thomas
> > Matt
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060620/6c000784/attachment.htm>
