IS routines without a Fortran interface
Stephen R Ball Stephen.R.Ball at awe.co.uk
Tue Jun 13 09:35:43 CDT 2006
Hi
Thanks, that appears to work now.
Much appreciated.
Stephen
-----Original Message-----
Sent: 13 June 2006 01:39
To: petsc-users at mcs.anl.gov
Subject: EXTERNAL: Re: IS routines without a Fortran interface
   Sorry, my fault. It should be if (called).
   Also you need only compile in that one directory with
make lib shared
you do not need to rebuild all of PETSc.
   Barry
On Mon, 12 Jun 2006, Stephen R Ball wrote:
> Hi
> I have rebuilt PETSc using your new zisltogf.c. However,
> ISLocalToGlobalMpngGetInfoSize() does not appear to work for me. It
> seems to jump out at line 28:
> if (!called) {*ierr = PETSC_ERR_ARG_WRONGSTATE; return}
> I am using the following Fortran code:
> ISLocalToGlobalMapping :: mapping
> integer :: nproc, numprocmax
> integer,dimension,allocatable(:) :: procs, numprocs
> integer,dimension,allocatable(:,:) :: indices
> call ISLocalToGlobalCreate(PETSC_COMM_WORLD, nlt_rows,
> loc_to_glob_idx, mapping, ierr) call
> ISLocalToGlobalMpngGetInfoSize(mapping, nproc, numprocmax, ierr)
> allocate(procs(nproc), stat=alloc_err) allocate(numprocs(nproc),
> stat=alloc_err) allocate(indices(nproc, numprocmax), stat=alloc_err)
> call ISLocalToGlobalMappingGetInfo(mapping, nproc, procs, numprocs,
> indices,
> ierr)
> Where "nlt_rows" is the number of local elements and "loc_to_glob_idx"
> is the global index for each local element.
> Have you any ideas on what could be causing the problem? Is it just a
> little typo in your code, or something more serious?
> Regards
> Stephen
> From: Barry Smith [mailto:bsmith at mcs.anl.gov]
> Sent: 11 June 2006 05:13
>   Stephen,
>    The difficulty with this routine is that it returns an array (the
> procs and numprocs argument) and an array of arrays (2d array) as the
> last argument. Returning 2d arrays from C to Fortran is not doable.
>   Thus I have devised a slightly different calling sequence for Fortran;
>     Fortran Usage:
> $        ISLocalToGlobalMpngGetInfoSize(ISLocalToGlobalMapping,PetscInt
> nproc,PetscInt numprocmax,ierr) followed by
> $        ISLocalToGlobalMappingGetInfo(ISLocalToGlobalMapping,PetscInt
> nproc, PetscInt procs[nproc],PetscInt numprocs[nproc],
>           PetscInt indices[nproc][numprocmax],ierr)
>         There is no ISLocalToGlobalMappingRestoreInfo() in Fortran.
> You must make sure that procs[], numprocs[] and
>         indices[][] are large enough arrays, either by allocating them
> dynamically or defining static ones large enough.
>   Attached is the new code, just drop it into
> src/vec/is/utisl/ftn-custom to replace the current zisltogf.c and run
> "make lib shared" in that directory.
>   Please let us know if you have any difficulties with it,
>   Barry
> On Fri, 9 Jun 2006, Stephen R Ball wrote:
>> Hi
>> I am keen to use some of the indexing IS routines in my Fortan code
>> but have discovered that several of them do not have a Fortran
>> interface. In particular I would like to use
>> ISLocalToGlobalMappingGetInfo() and
>> ISLocalToGlobalMappingRestoreInfo(). Would it be possible for you to
>> include these, and possibly any other missing IS routines not having
>> a Fortran interface, in PETSc v2.3.1 as a new patch version.
>> Regards
>> Stephen
>> _____________________________________________________________________
>> _
>> _________
>> The information in this email and in any attachment(s) is commercial
>> in confidence. If you are not the named addressee(s) or if you
>> receive this email in error then any distribution, copying or use of
>> this communication or the information in it is strictly prohibited.
>> Please notify us immediately by email at admin.internet(at)awe.co.uk,
>> and then delete this message from your computer.  While attachments
>> are virus checked, AWE plc does not accept any liability in respect
>> of any virus which is not detected.
>> AWE Plc
>> Registered in England and Wales
>> Registration No 02763902
>> AWE, Aldermaston, Reading, RG7 4PR
> ______________________________________________________________________
> _________
> in confidence. If you are not the named addressee(s) or if you receive
> this email in error then any distribution, copying or use of this
> communication or the information in it is strictly prohibited.  Please
> notify us immediately by email at admin.internet(at)awe.co.uk, and
> then delete this message from your computer.  While attachments are
> virus checked, AWE plc does not accept any liability in respect of any
> AWE Plc
_______________________________________________________________________________
The information in this email and in any attachment(s) is commercial in confidence. If you are not the named addressee(s) or if you receive this email in error then any distribution, copying or use of this communication or the information in it is strictly prohibited.  Please notify us immediately by email at admin.internet(at)awe.co.uk, and then delete this message from your computer.  While attachments are virus checked, AWE plc does not accept any liability in respect of any virus which is not detected.
AWE Plc
