Matrix input file format
Evrim Dizemen
gudik at ae.metu.edu.tr
Wed Jun 7 06:54:00 CDT 2006
Hi all,
First thanks for your comments. I still have the same problem but i
agree with you all that reading a matrix from a file is not parallel
programming. So i wonder if you can recommend an efficient and faster
way to read a 30000x30000 sparse matrix where i got those values from my
fortran code on aeroacoustics similation. I tried calling MatSetValues
as i attached below. I found that way from the ex11f.F in the matrix
examples and not sure if it is appropriate for my situation.
! do, i=1,n
! do, j=1,n
! value=Aval(i,j)
! if(value .ne. 0)then
! l=i-1
! m=j-1
! call MatSetValues(A,1,l,1,m,value,INSERT_VALUES,ierr)
! endif
! enddo
! enddo
Thanks soooooo much
EVRIM
