EXTERNAL: Re: Problems using external packages Spooles and Hy pre with PETSc v2. 3.1
Stephen R Ball
Stephen.R.Ball at awe.co.uk
Mon Jun 5 06:51:53 CDT 2006
Hi
Your example runs OK, as do some of my other problems. But with some
problems
PETSc v2.3.1 fails while PETSc v2.3.0 works. I have attached the output from
both PETSc versions for one of these problems. If you are interested,
perhaps
we could make arrangements for me sending you one of these problems.
Regards
Stephen
-----Original Message-----
Sent: 02 June 2006 14:47
To: petsc-users at mcs.anl.gov
Subject: EXTERNAL: Re: Problems using external packages Spooles and Hypre
with PETSc v2. 3.1
Stephen,
> I am using Spooles downloaded from the PETSc ftp site and built into
> PETSC_DIR/externalpackages. When solving a partcular problem I am
> getting the error:
> MatFactorNumeric_MPIAIJSpooles line 199
> src/mat/impls/aij/mpi/spooles/mpispooles.c
> MatLUFactorNumeric line 2200 src/mat/interface/matix.c KSPSetUp line
> 183 src/ksp/ksp/interface/itfunc.c KSPSolve line 305
May I have the complete error message after the crash?
Can you run
~petsc/src/ksp/ksp/examples/tutorials/ex5.c
with the cmd:
mpirun -np 2 ./ex5 -ksp_type preonly -pc_type lu -mat_type aijspooles?
Hong
> The problem also occurs in serial.
> I am using Hypre v1.10.0b downloaded from the LLNL site and built
> separatly to PETSc. When I have been using Pilut and Parasails as
> either global problem preconditioners of as sub preconditioners for
> ASM or BJACOBI, I have been getting errors indicating that there could
> be a memory access out of range. I suspect that there may be a memory
> overwrite or mismatch occuring somewhere. Note that BOOMERAMG and
> EUCLID seem to work OK. Again these problems were not apparent when I
> was using PETSc v2.3.0.
> Have there been any significant changes in the PETSc source that
> handles Spooles and Hypre between versions 2.3.0 and 2.3.1 that could
> be causing these problems? I don't really want to go back to using
> PETSc v2.3.0 if I can help it. I don't know if it makes any
> difference, but I am using the Fortran interface to PETSc.
> Hope you can help.
> Regards
> Stephen R. Ball
> ______________________________________________________________________
> _________
> The information in this email and in any attachment(s) is commercial
> in confidence. If you are not the named addressee(s) or if you receive
> this email in error then any distribution, copying or use of this
> communication or the information in it is strictly prohibited. Please
> notify us immediately by email at admin.internet(at)awe.co.uk, and
> then delete this message from your computer. While attachments are
> virus checked, AWE plc does not accept any liability in respect of any
> virus which is not detected.
> AWE Plc
> Registered in England and Wales
> Registration No 02763902
> AWE, Aldermaston, Reading, RG7 4PR
_______________________________________________________________________________
The information in this email and in any attachment(s) is commercial in confidence. If you are not the named addressee(s) or if you receive this email in error then any distribution, copying or use of this communication or the information in it is strictly prohibited. Please notify us immediately by email at admin.internet(at)awe.co.uk, and then delete this message from your computer. While attachments are virus checked, AWE plc does not accept any liability in respect of any virus which is not detected.
AWE Plc
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060605/cf833302/attachment.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060605/cf833302/attachment-0001.txt>
