Using the Spooles Cholesky solver via PETSc in serial
Barry Smith
bsmith at mcs.anl.gov
Fri Jun 2 12:47:27 CDT 2006
Stephen,
This was an error in our last release and did not properly fixed
in a patch (why?). It will be in the next release.
You can edit include/finclude/petscmat.h and add
PetscEnum MAT_USE_COMPRESSEDROW,MAT_DO_NOT_USE_COMPRESSEDROW
PetscEnum MAT_IGNORE_LOWER_TRIANGULAR,MAT_ERROR_LOWER_TRIANGULAR
PetscEnum MAT_GETROW_UPPERTRIANGULAR
parameter (MAT_USE_COMPRESSEDROW=89)
parameter (MAT_DO_NOT_USE_COMPRESSEDROW=90)
parameter (MAT_IGNORE_LOWER_TRIANGULAR=91)
parameter (MAT_ERROR_LOWER_TRIANGULAR=92)
parameter (MAT_GETROW_UPPERTRIANGULAR=93)
then it should work properly.
Barry
On Fri, 2 Jun 2006, Stephen R Ball wrote:
> Hi
> I am using PETSc v2.3.1 (patch 9) via the Fortran interface. When I use the
> Spooles CHOLESKY solver in serial I get the error:
> MatSetValues_MPIBAIJ_MatScaler() line 259 in
> src/mat/impls/sbaij/mpi/mpisbaij.c
> Lower triangular value cannot be set for sbaij format. Ignoring
> these values, run with -mat_ignore_lower_triagular or call
> MatSetOption(mat,MAT_IGNORE_LOWER_TRIANGULAR)
> MatSetValues() line 827 in src/mat/interface/matrix
> The command line option works fine but when I try to use MatSetOption() with
> the MAT_IGNORE_LOWER_TRIANGULAR flag I get the error:
> This name does not have a type, and must have an explicit type.
> [MAT_IGNORE_LOWER_TRIANGULAR]
> Can you tell me if use of the MAT_IGNORE_LOWER_TRIANGULAR flag is supported
> in the Fortran interface for MatSetOption()?
> Regards
> Stephen R. Ball
> _______________________________________________________________________________
> The information in this email and in any attachment(s) is commercial in confidence. If you are not the named addressee(s) or if you receive this email in error then any distribution, copying or use of this communication or the information in it is strictly prohibited. Please notify us immediately by email at admin.internet(at)awe.co.uk, and then delete this message from your computer. While attachments are virus checked, AWE plc does not accept any liability in respect of any virus which is not detected.
> AWE Plc
> Registered in England and Wales
> Registration No 02763902
> AWE, Aldermaston, Reading, RG7 4PR
