building libraries
Matt Funk mafunk at nmsu.edu
Thu Jun 1 12:03:31 CDT 2006
Thanks for the replies,
the whole mpicc is a little system specific. It build the libraries after all,
so it's fine.
However, now i got another question. I link the libraries into my program, and
then in my top level code i include petscksp.h. When i try to compile it, it
gives me the following error:
In file included
from /home2/users/mafunk/AMR/PETSC/petsc-2.3.1-p12/include/petscis.h:7,
from /home2/users/mafunk/AMR/PETSC/petsc-2.3.1-p12/include/petscvec.h:9,
from /home2/users/mafunk/AMR/PETSC/petsc-2.3.1-p12/include/petscmat.h:6,
from /home2/users/mafunk/AMR/PETSC/petsc-2.3.1-p12/include/petscpc.h:6,
from /home2/users/mafunk/AMR/PETSC/petsc-2.3.1-p12/include/petscksp.h:6,
                 from testNodePoisson.cpp:65:
/home2/users/mafunk/AMR/PETSC/petsc-2.3.1-p12/include/petsc.h:13:23:
petscconf.h: No such file or directory
The only include directory that i have specified is /include in the petsc root
directory. I couldn't find petscconf.h anywhere, so i was wondering if
somebody knows what i am doing wrong here.
thanks
mat
On Wednesday 31 May 2006 16:08, Matthew Knepley wrote:
> You can have PETSc install MPI using --download-mpich. You can make
> sure that it does not use mpicc using --with-mpi-compilers=0.
>    Matt
> On 5/31/06, Matt Funk <mafunk at nmsu.edu> wrote:
> > Hi,
> > i need to build PETsC on s sycld machine. Basically i need to have MPI
> > support
> > in PetsC but i need to switch from using mpicc to gcc.
> > I was wondering if someone could point to how i can do that. (Is there an
> > option that i overlooked?)
> > thanks
> > mat
