attaching pathdb
    Harald Pfeiffer
    harald at tapir.caltech.edu
    Tue Feb 28 15:38:33 CST 2006
Works now, thanks!
Barry Smith wrote:
>   Ahh yes, found the offensive code and it is offensive. In
> src/sys/error/adebug.c in PetscSetDebuggerFromString() is
> a horrible list of choices. We should fix this code to be more
> general. Anyway, you can just add another entry for pathdb
> and do make lib shared in that directory.
>   Please let us know if this does not resolve the problem,
>    Barry
> This will be fixed in our next 2.3.1 patch.
> On Tue, 28 Feb 2006, Harald Pfeiffer wrote:
>> -start_in_debugger pathdb  brings up gdb?! Ditto with noxterm.
>> Harald
>> Barry Smith wrote:
>>>   Then it should "just work", what happens when you run
>>> with -start_in_debugger noxterm,pathdb or
>>> -start_in_debugger pathdb? Please send all output from
>>> the error.
>>>    Thanks
>>>     Barry
>>>> Hi Barry,
>>>> the usage seems to be similar or even identical to gdb:
>>>> Output of pathdb -help:
>>>>>  usage: pathdb [option...] [program [core|pid]]
>>>> The man page is online under
>>>> http://www.pathscale.com/docs/pathdb.html,
>>>> and there is also the full user guidem
>>>> http://www.pathscale.com/docs/PathDB_UserGuide.pdf (look at page 29).
>>>> Harald
>>>> Barry Smith wrote:
>>>>>   Harald,
>>>>>    We need to know the command line arguments for pathdb to attach
>>>>> properly (each debugger is a little different, hence the hardwiring).
>>>>> Please send us the pathdb man page and all the output when you
>>>>> run it with -help and we'll make a tenative patch for you to try.
>>>>>    Barry
>>>>>> Hello,
>>>>>> I'd like to use the pathscale debugger, pathdb, when debugging
>>>>>> petsc-codes. However, petsc seems to have hardcoded the list of
>>>>>> debuggers:
>>>>>> -on_error_attach_debugger [gdb,dbx,xxgdb,ups,noxterm]
>>>>>>      start the debugger in new xterm
>>>>>> -start_in_debugger [gdb,dbx,xxgdb,ups,noxterm]
>>>>>>      start all processes in the debugger
>>>>>> How do I go about doing this?
>>>>>> Thanks,
>>>>>> Harald
Harald P. Pfeiffer                harald at tapir.caltech.edu
Theoretical Astrophysics          Phone (626) 395-8413
Caltech 130-33                    Fax   (626) 796-5675
Pasadena, CA 91125, USA
