attaching pathdb
Harald Pfeiffer
harald at tapir.caltech.edu
Tue Feb 28 14:22:52 CST 2006
-start_in_debugger pathdb brings up gdb?! Ditto with noxterm.
Harald
Barry Smith wrote:
> Then it should "just work", what happens when you run
> with -start_in_debugger noxterm,pathdb or
> -start_in_debugger pathdb? Please send all output from
> the error.
> Thanks
> Barry
> On Tue, 28 Feb 2006, Harald Pfeiffer wrote:
>> Hi Barry,
>> the usage seems to be similar or even identical to gdb:
>> Output of pathdb -help:
>>> usage: pathdb [option...] [program [core|pid]]
>> The man page is online under http://www.pathscale.com/docs/pathdb.html,
>> and there is also the full user guidem
>> http://www.pathscale.com/docs/PathDB_UserGuide.pdf (look at page 29).
>> Harald
>> Barry Smith wrote:
>>> Harald,
>>> We need to know the command line arguments for pathdb to attach
>>> properly (each debugger is a little different, hence the hardwiring).
>>> Please send us the pathdb man page and all the output when you
>>> run it with -help and we'll make a tenative patch for you to try.
>>> Barry
>>>> Hello,
>>>> I'd like to use the pathscale debugger, pathdb, when debugging
>>>> petsc-codes. However, petsc seems to have hardcoded the list of
>>>> debuggers:
>>>> -on_error_attach_debugger [gdb,dbx,xxgdb,ups,noxterm]
>>>> start the debugger in new xterm
>>>> -start_in_debugger [gdb,dbx,xxgdb,ups,noxterm]
>>>> start all processes in the debugger
>>>> How do I go about doing this?
>>>> Thanks,
>>>> Harald
Harald P. Pfeiffer harald at tapir.caltech.edu
Theoretical Astrophysics Phone (626) 395-8413
Caltech 130-33 Fax (626) 796-5675
Pasadena, CA 91125, USA
