attaching pathdb
Harald Pfeiffer
harald at tapir.caltech.edu
Tue Feb 28 14:05:47 CST 2006
Hi Barry,
the usage seems to be similar or even identical to gdb:
Output of pathdb -help:
> usage: pathdb [option...] [program [core|pid]]
The man page is online under http://www.pathscale.com/docs/pathdb.html,
and there is also the full user guidem
http://www.pathscale.com/docs/PathDB_UserGuide.pdf (look at page 29).
Harald
Barry Smith wrote:
> Harald,
> We need to know the command line arguments for pathdb to attach
> properly (each debugger is a little different, hence the hardwiring).
> Please send us the pathdb man page and all the output when you
> run it with -help and we'll make a tenative patch for you to try.
> Barry
> On Tue, 28 Feb 2006, Harald Pfeiffer wrote:
>> Hello,
>> I'd like to use the pathscale debugger, pathdb, when debugging
>> petsc-codes. However, petsc seems to have hardcoded the list of
>> debuggers:
>> -on_error_attach_debugger [gdb,dbx,xxgdb,ups,noxterm]
>> start the debugger in new xterm
>> -start_in_debugger [gdb,dbx,xxgdb,ups,noxterm]
>> start all processes in the debugger
>> How do I go about doing this?
>> Thanks,
>> Harald
Harald P. Pfeiffer harald at tapir.caltech.edu
Theoretical Astrophysics Phone (626) 395-8413
Caltech 130-33 Fax (626) 796-5675
Pasadena, CA 91125, USA
