SNES Problem
Nils Erik Svangård
nilserik at gmail.com
Mon Feb 27 08:07:51 CST 2006
Hi all,
I have problems solving some CFD problems using SNES and my custom
back-euler. I have 7 equations that I want to solve.
First my FormFunction copies the values from the Vec that SNES uses to
the variables that my code use:
RO(L)=xx(1,L)
RU(L)=xx(2,L)
RV(L)=xx(3,L)
RW(L)=xx(4,L)
ET(L)=xx(5,L)
RQ(L)= xx(6,L)
REPS(L)=xx(7,L)
Here I also print the values of ET(2) for debugging:
write(6,*)"ET(2) = xx(5,2) : ",ET(2)," = ",xx(5,2)
Then I get the fluxes by calling custom functions
call AUXVR
call VGRAD
call FLUX
call KESRC
Then I perform back-euler save the new value to so that I can use it
in the next iterationi (TSF(L) is Time step function, which is set by
hand and is the same for all L):
ff(1,L) = RO(L)-OLD(1,L)-TSF(L)*DRO(L)
ff(2,L) = RU(L)-OLD(2,L)-TSF(L)*DRU(L)
ff(3,L) = RV(L)-OLD(3,L)-TSF(L)*DRV(L)
ff(4,L) = RW(L)-OLD(4,L)-TSF(L)*DRW(L)
ff(5,L) = ET(L)-OLD(5,L)-TSF(L)*DET(L)
ff(6,L) = RQ(L)-OLD(6,L)-TSF(L)*DRQ(L)
ff(7,L) = REPS(L)-OLD(7,L)-TSF(L)*DREPS(L)
And save the new value of RO-REPS to use in the next iteration of back-euler:
OLD(1,L)=RO(L)
OLD(2,L)=RU(L)
OLD(3,L)=RV(L)
OLD(4,L)=RW(L)
OLD(5,L)=ET(L)
OLD(6,L)=RQ(L)
OLD(7,L)=REPS(L)
Here I print the values of L=2 as above for debugging:
write(6,*)ff(5,2)," = ",ET(2),"-",OLD(5,2),"-",TSF(2),"*",DET(2)
The program exit abnormaly after 33 runs of the FormFunction. The
cause of this is that AUXVR tries to perform sqrt(ET(2)) when ET(2) is
negative, ET is the total energy and should never be negative. It
seems that all of a sudden the PETSc SNES solver decides to supply the
FormFunction with a negative ET value. I need help understanding why
and how to fix it (if it is fixable).
Here is the output of:
Which is in the beginning of my FormFunction.
And:
Which is in the end of my Formfunction.
1. ET(2) = xx(5,2) : 253250. = 253250.000000000
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4126563437192 =
253250. - 253250.000000000 - 1.000000E-07 * -2.941266E+08
2. ET(2) = xx(5,2) : 253250. = 253250.000010259
3. ET(2) = xx(5,2) : 253250. = 253249.999999988
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4132419437260 =
253250. - 253250.000000000 - 1.000000E-07 * -2.941324E+08
4. ET(2) = xx(5,2) : 253250. = 253250.000048432
5. ET(2) = xx(5,2) : 253250. = 253249.999999872
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4177283437784 =
253250. - 253250.000000000 - 1.000000E-07 * -2.941773E+08
6. ET(2) = xx(5,2) : 253250. = 253250.000071113
7. ET(2) = xx(5,2) : 253250. = 253249.999980115
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4453347441010 =
253250. - 253250.000000000 - 1.000000E-07 * -2.944533E+08
8. ET(2) = xx(5,2) : 253250. = 253250.000037298
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4082723436679 =
253250. - 253250.000000000 - 1.000000E-07 * -2.940827E+08
9. ET(2) = xx(5,2) : 253250. = 253249.999942706
10. ET(2) = xx(5,2) : 253250. = 253249.999948703
11. ET(2) = xx(5,2) : 253250. = 253250.000007808
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.7283811474088 =
253250. - 253250.000000000 - 1.000000E-07 * -2.972838E+08
12. ET(2) = xx(5,2) : 253250. = 253250.000018146
13. ET(2) = xx(5,2) : 253250. = 253250.000001865
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 28.3742819315846 =
253250. - 253250.000000000 - 1.000000E-07 * -2.837428E+08
14. ET(2) = xx(5,2) : 253250. = 253249.999997296
15. ET(2) = xx(5,2) : 253250. = 253250.000000049
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 30.6548963582361 =
253250. - 253250.000000000 - 1.000000E-07 * -3.065490E+08
16. ET(2) = xx(5,2) : 253250. = 253250.000022870
17. ET(2) = xx(5,2) : 253250. = 253249.999999716
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.5326051451209 =
253250. - 253250.000000000 - 1.000000E-07 * -2.953260E+08
18. ET(2) = xx(5,2) : 253250. = 253250.000074328
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4165187437643 =
253250. - 253250.000000000 - 1.000000E-07 * -2.941652E+08
19. ET(2) = xx(5,2) : 253250. = 253250.000049809
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.4085059436707 =
253250. - 253250.000000000 - 1.000000E-07 * -2.940851E+08
20. ET(2) = xx(5,2) : 253250. = 253250.000019253
21. ET(2) = xx(5,2) : 253250. = 253250.000000189
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.8851075492403 =
253250. - 253250.000000000 - 1.000000E-07 * -2.988511E+08
22. ET(2) = xx(5,2) : 253250. = 253249.999997897
23. ET(2) = xx(5,2) : 253250. = 253249.999975142
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 29.3961539435263 =
253250. - 253250.000000000 - 1.000000E-07 * -2.939615E+08
24. ET(2) = xx(5,2) : 253250. = 253250.000018324
25. ET(2) = xx(5,2) : 253250. = 253249.999987073
26. ET(2) = xx(5,2) : 253250. = 253249.999980982
27. ET(2) = xx(5,2) : 253250. = 253249.999994645
28. ET(2) = xx(5,2) : 253250. = 253249.999962364
29. ET(2) = xx(5,2) : 253250. = 253249.999999921
30. ET(2) = xx(5,2) : 253250. = 253250.000000058
ff(5,2) = ET(2)-OLD(5,2)-TSF(2)*DET(2) : 28.4019971319085 =
253250. - 253250.000000000 - 1.000000E-07 * -2.840200E+08
31. ET(2) = xx(5,2) : 253250. = 253250.000040348
32. ET(2) = xx(5,2) : 253250. = 253250.000005245
33. ET(2) = xx(5,2) : 253250. = 253250.000005245
34. ET(2) = xx(5,2) : -848141. = -848141.388090847
Petsc Release Version 2.3.0, Patch 32, April, 26, 2005
See docs/changes/index.html for recent updates.
See docs/faq.html for hints about trouble shooting.
See docs/index.html for manual pages.
./SNESG3D2 on a linux-gnu named sethnx004.vac.com by yy26539 Mon Feb
27 14:21:13 2006
Libraries linked from /home/yy26539/work/NISSE/petsc-2.3.0/lib/linux-gnu
Configure run at Thu Oct 13 08:23:56 2005
Configure options --with-cc=gcc --with-fc="f77 -N109"
--download-mpich=1 --download-mpich-pm=gforker
--download-f-blas-lapack=1 --with-shared=0
[0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
Exception,probably divide by zero
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------- Stack Frames ---------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] SNES user function line 0 unknownunknown
[0]PETSC ERROR: [0] SNESComputeFunction line 788 src/snes/interface/snes.c
[0]PETSC ERROR: [0] SNESLineSearchCubic line 514 src/snes/impls/ls/ls.c
[0]PETSC ERROR: --------------------------------------------
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR: !
Suggestions and tips are very welcome!
/nisse
Nils-Erik Svang�rd
MSN: schweingaard at hotmail.com
Skype: schweingaard
