VecGetValues and tutorail?
Fri Feb 24 11:56:45 CST 2006
On Fri, 24 Feb 2006, billy at dem.uminho.pt wrote:
> Hello,
> "VecGetValues - Gets values from certain locations of a vector. Currently can
> only get values on the same processor"
> How can I get a value of the vector belonging to a different processor?
> I am trying to learn how to adapt my code to work in parallel. Have looked at
> src/snes/examples/tutorials/ex10d/ex10.c, but I am still confused on how to use
> petsc with unstructured meshes. Is there any simple step-by-step tutorial?
Basically - you'll have to use VecScatter routines to specify the
communication required. Then use VecScatterBegin/End() to invoke this
communication. Some of this info is in the tutorial slides [check
arround slide 150] in:
http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/tutorials/PetscTu06.pdf
Not usre if there is an unstructured grid example code. [but there are
examples using VecScatters in src/dm/da/examples/tutorials]
Satish
