Help on installation of PETSC+prometheus on Cygwin
Letian Wang
letian.wang at ghiocel-tech.com
Tue Feb 21 10:45:46 CST 2006
Satish:
Thank you very much for the help. Right now it works on cygwin shell after
removing the three lines.
Letian
-----Original Message-----
From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov]
On Behalf Of Satish Balay
Sent: Tuesday, February 21, 2006 11:22 AM
To: petsc-users at mcs.anl.gov
Subject: Re: Help on installation of PETSC+prometheus on Cygwin
These external packages are not tested on windows.
/home/feap/Library/petsc-2.3.1-p5/externalpackages/ParMetis/cygwin-c-real-op
t/include/parmetis.h:20:1: warning: "__cdecl" redefined
You could try removing the following code from
/home/feap/Library/petsc-2.3.1-p5/externalpackages/ParMetis/parmetis.h
and see if it helps
#ifndef _MSC_VER
#define __cdecl
#endif
However I'll recommend using linux instead [due to all the external
package requirements]
Satish
On Tue, 21 Feb 2006, Letian Wang wrote:
> Hello,
> I had problems to install PETSc-2.3.1-p5 and Prometheus on my notebook
under
> Cygwin environment. Here are the options I used:
> --with-blas-lapack-dir=$PETSC_DIR/externalpackages/fblaslapack/$PETSC_ARCH
> --with-debugging=0
> --with-mpi-dir=$HOME/mpich2-install
> --download-parmetis=1
> --download-prometheus=1
> --download-spooles=1
> --download-hypre=1
> I could download Parmetis and it seemed the compiling was ok because I saw
> files libparmetis.a and libmetis.a. However, PETSc complains the
downloaded
> Parmetis cannot be used. Attached is the configure.log file.
> Any helps are greatly appreciated. Thanks.
> Letian Wang
