Matrix operation
    Matthew Knepley
    knepley at mcs.anl.gov
    Mon Feb 20 17:15:34 CST 2006
Hong Zhang <hzhang at mcs.anl.gov> writes:
     I would recommend the later
  MatGetDiagonal(A, diag);
  VecPointwiseMult(w, diag, u);
  MatMult(A, u, v);
  VecAXPY(w, -1.0, v);
             Matt
> Billy,
> You can do
> MatGetDiagonal(A,diag);
> MatMult(A,u,&vtmp);
> VecGetArray(diag,diag_array);
> VecGetArray(vtmp,vtmp_array);
> VecGetArray(u,u_arrar);
> VecGetArray(h,h_array);
> VecGetLocalSize(h,&n);
> for (i=0; i<n; i++){
>   h_array[i] += diag_array[i]*u_array[i] - vtmp_array[i];
> VecRestoreArray(h,h_array);
> VecRestoreArray()
> or you can use VecPointwiseMult() got get
> Diag(A)*u.
> Hong
> On Mon, 20 Feb 2006 billy at dem.uminho.pt wrote:
>> Hello,
>> I would like to do the following matrix-vector operation in PETSc:
>> h += (Diag(A) - A) * u
>> where A is a matrix, Diag(A) is a matrix and h, u are vectors. It is the
>> multiplication of a matrix with diagonals set to zero with a vector.
>> How can I do this in PETSc? because MatGetDiagonal gives a vector not a matrix.
>> Billy.
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec Guiness
